Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Nature & Landscapes
Reply
Thread Tools Display Modes
Old 12th of March 2007 (Mon)   #1
illy
illy's Avatar
Default Wales
Fullsize:
http://ic1.deviantart.com/fs14/f/200...illyafresh.jpg
This is the only shot I managed to get whilst camping for my DOE Silver in the Breacon Beacons, Wales. As this was my training session I wasn't allowed to take photographs during the actual walk, also my rubbish-flaky-ramshackled-tripod broke down so I had even more trouble: I could only take a horizontal shot; so I had to zoom out to around 20mm to include the sky, and I took 5 shots. Stitching is meant to be done for vertical photographs taken at a focal length where the distortion is low (so either a prime or mid-way on a zoom), hence I had HORRIBLE distortions at the side and stitching them together was nightmare (hate two leave two shots behind).
Still, nevermind. My practise session is in two weeks (and I have allready ordered a proper Manfrotto tripod with Head).
350D
17-50mm f/2.8 (@ 22mm x 3)
f/11
1/6
Edit:
Here is the same shot where I exposed for the sky:
Fullsize:
http://ic3.deviantart.com/fs13/f/200...illyafresh.jpg
Flickr
600D, 17-50, 50, 60, 100, 70-200, 430EX
illy is offline   Reply With Quote
Old 12th of March 2007 (Mon)   #2
StewartR
"your nose is too big"
StewartR's Avatar
Default Re: Wales
Nice panos, both of them. It's nice to see two different versions of the same scene both working so well!
However I'm a little surprised by the difficulties you had stitching it. I have a 350D and have made panoramas using an 18mm lens. What software are you using?
www.LensesForHire.co.uk - complete with matching POTN discussion thread
Photos: Cats | London by day | London by night I My POTN photo sharing threads | Official "Where Am I Now?" archive
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
StewartR is offline   Reply With Quote
Old 12th of March 2007 (Mon)   #3
illy
illy's Avatar
Default Re: Wales
I stitched it manually in PS. On the one exposed for the land; the lamp post on the first was curving to the right and on the second it was curving to the left. So I had to rotate it a bit and change the perspective to get it work.
Thanks for the comment
Flickr
Old 12th of March 2007 (Mon)   #4
StewartR
StewartR's Avatar
Default Re: Wales
Ah. That would explain it! If you use stitching software such as AutoStitch or PTAssembler (both of which are free) then they will correct the distortion and allow you to use wide-angle lenses in your panoramas.
Old 12th of March 2007 (Mon)   #5
illy
illy's Avatar
Default Re: Wales
Ah. I see I was used to the inferior quality of the PS one that I trained myself to do it manually. Now I can go even wider! Gosh 10 shots at 17mm
Flickr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anyone from Wales? Pricey POTN Member Activities 22 24th of October 2009 (Sat) 16:13
Wales Rally GB darren h Motorsports 14 14th of December 2006 (Thu) 03:58
North Wales swiftybilko Nature & Landscapes 29 26th of December 2005 (Mon) 03:17
Snowdonia, Wales swiftybilko Nature & Landscapes 9 21st of October 2005 (Fri) 06:53
From Wales (4 photos) ndh Nature & Landscapes 8 20th of May 2005 (Fri) 04:45
