Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 17th of March 2007 (Sat)   #1
tomd
tomd's Avatar
Default markIIN; 2 card slots question:
For optimnal performance; is it essential that the card speed in the two slots be the same? In other words, have them both be ultra II? If one is a "normal" speed card and the other an ultra II, will that slow down the write speed?
I don't yet have this body, but I'm learing all I can in advance of purchase!
Thanks, Tom
mark iin; mark iid(S); 7d; G10: Canon 17-40, nifty 50, Canon 24-70L, Canon 10-22, Canon 70-200/2.8 L II, 300 2.8, 400/5.6, L 135, Canon 85/1.8: Canon 100 macro, tubes, Canon 1.4 tele conv.
=======>>> play W.A.I.N.
tomd is offline   Reply With Quote
Old 17th of March 2007 (Sat)   #2
Zilly
Zilly's Avatar
Default Re: markIIN; 2 card slots question:
wow never thought of this dont think so but never pay'ed attention to it
Dom
Zilly is offline   Reply With Quote
Old 17th of March 2007 (Sat)   #3
tomd
tomd's Avatar
For example if you have the camera set to write RAW files to the CF and back up with jpeg to the sd slot, should both cards be the same? With the high frame per second this camera is capable of, will a slow(normal) card in one of the slots effect the shooting speed?
Old 17th of March 2007 (Sat)   #4
Zilly
Zilly's Avatar
it would but I think you would struggle to put it in a real life situation where it get to the point of causing a problem. how ever if you chimp and shoot big bursts your going to be weighting for a while no matter what card youve got in
Dom
Old 17th of March 2007 (Sat)   #5
CyberDyneSystems
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
CyberDyneSystems's Avatar
Thanks, Tom
I never use them this way, BUT if you are using the "RAID feature, ie: writing the same data to both cars, then yes the slower card will will be the weak link in a buffer flush.
In the Raw on one card and jpeg on another.. just make sure the jpegs are going to the slower card to prevent the bottleneck. (jpegs so much smaller that the slower card most likely won't be so slow that the jpeg can;t make the transfer before the RAW file. )
In any case, anytime your writing to both, the bottleneck will be created on the card where the data is not getting written slowest.
As mentioned, the buffer on the MkII is pretty huge and fast, but I have run into it under normal use. The faster the card the better.
CyberDyneSystems is offline   Reply With Quote
Old 17th of March 2007 (Sat)   #6
CoolToolGuy
Boosting Ruler Sales
CoolToolGuy's Avatar
An interesting question. Testing might be helpful, but make sure to check Rob Galbraith's card performance database rather than matching up, for example, an Extreme III SD card with an Extreme III CF card. The SD cards perform much better in the 1D MKII N than CF cards. You can get the details here:
http://www.robgalbraith.com/bins/mul...?cid=6007-8200
Have Fun,
Rick
My Gear list
CoolToolGuy is offline   Reply With Quote
Old 18th of March 2007 (Sun)   #7
petrolhead
petrolhead's Avatar
Have Fun,
Interesting site. From what I can see there is very little advantage to buying Extreme IV over Ultra cards for the 1D
petrolhead is offline   Reply With Quote
Old 18th of March 2007 (Sun)   #8
Tareq
"I am very lazy, a normal consumer"
Tareq's Avatar
I did that once and really it was so slow to write to SD but it was fast enough to write RAW to CF, i will buy more CF and SD cards so i can use both formats mostly for sports because one of my friends asking me to have jpeg shots instead of RAW so that i have to use both formats shooting.
I will get all Extreme or faster for now.
Tareq is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Are there LCD with CF slots? (More inside) NorCalAl Accessories & Storage 3 12th of March 2007 (Mon) 12:45
Dual Card Slots Canonshooter Canon EOS Digital Cameras 16 2nd of September 2006 (Sat) 15:38
Glory Slots Idoitforfree Urban Life & Travel 8 28th of March 2006 (Tue) 18:24
I wonder about the 1D MarkIIn fstop11.net Canon EOS Digital Cameras 15 29th of November 2005 (Tue) 08:54
Loose Slots Downtown Vegas Radtech1 Critique Corner 1 25th of November 2005 (Fri) 16:54
