Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 21st of March 2007 (Wed)   #1
mxp
mxp's Avatar
Default cross-type AF point on 10D ?
does the eos 10D have a cross-type AF point ?
mxp is offline   Reply With Quote
Old 21st of March 2007 (Wed)   #2
John_B
John_B's Avatar
Default Re: cross-type AF point on 10D ?
mxp,
Yes on the center AF point only
John_B is offline   Reply With Quote
Old 21st of March 2007 (Wed)   #3
Doug Pardee
As John said, yes the center AF point is cross-type. However, it doesn't have the triple-precision f/2.8 sensor that the 9-point AF on the 20D/30D/XTi/400D has.
Doug Pardee is offline   Reply With Quote
Old 22nd of March 2007 (Thu)   #4
bauerman
discount on value meals
Can someone go into more detail regarding this topic - its interesting to me and I would like to learn more. What exactly is a cross-type AF point vs. the other AF points in the 10D or any other camera for that matter?
bauerman is offline   Reply With Quote
Old 22nd of March 2007 (Thu)   #5
Doug Pardee
Most AF sensors are only sensitive to edges that go in one general direction: either horizontal edges or vertical edges, but not both. A cross-type sensor is sensitive to both horizontal edges and vertical edges.
Old 22nd of March 2007 (Thu)   #6
bauerman
But this functionality is only available within the confines of certain apertures? Does that change depending on the lens that you have attached to the body?
(Thanks that explanation by the way - makes a lot of sense and is not something I was familiar with before now.)
Old 22nd of March 2007 (Thu)   #7
Doug Pardee
The autofocus system on the 10D, as on all of the Canon DSLRs except the 1-series, is designed for lenses of f/5.6 or faster. Yes, it depends on the lens (and often on the current focal length setting), because autofocus is done with the aperture wide open. What counts is how wide the lens aperture can go (at the current focal length setting).
There are some third-party zoom lenses that are f/6.3 at the long end, but lie to the camera and claim that they're f/5.6 so that the camera will autofocus.
The 9-point AF system used on the 20D, 30D, and XTi/400D also has a triple-precision non-cross sensor—sensitive to vertical edges only—at the center AF point that is turned on when a lens of f/2.8 or faster is fitted. So with an f/2.8 lens, the center AF point is still cross-type and therefore still sensitive to both horizontal and vertical edges, but it gives more precise results with vertical edges. This triple-precision sensor is not present on the 10D or any of the other Canon DSLRs with the 7-point AF system.
Old 22nd of March 2007 (Thu)   #8
bauerman
Excellent information Doug - and much appreciated. It makes a lot of sense and I especially liked the bit about the "lying lenses" that fibbed that they were f5.6 so the camera would autofocus.
Are there any links or websites that you know of that explain this subject in more detail that you could point me to? Thanks.
Old 22nd of March 2007 (Thu)   #9
adas
adas's Avatar
I would stay away from those lenses. If they're lying they were f/5.6, they most likely "pretending" they achieve consistent focus. It's not Canon who's set a limit at f/5.6 for AF. It's the geometry of the AF sensor that won't allow a smaller aperture.
I don't have links, but you can google for PHASE DETECTION AUTOFOCUS.
adas is offline   Reply With Quote
Old 22nd of March 2007 (Thu)   #10
bauerman
Thanks adas - I will do that.
Old 22nd of March 2007 (Thu)   #11
Hellashot
User is banned from forums
Then you are telling people to stay away from the Bigma. I have it and it sure does get AF right.
Hellashot is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mark III doesn't have cross focus point @ 5.6 ?? outdoorphoto.ca Canon EOS Digital Cameras 31 30th of May 2007 (Wed) 12:28
what does 2.8 aperture lens do with cross type sensors kriskent Canon EF and EF-S Lenses 2 14th of July 2006 (Fri) 03:24
20D cross-type AF sensor PacAce Canon EOS Digital Cameras 2 20th of August 2004 (Fri) 14:21
10D Active Focus Point (without flash) influence exposure? dpanicc1 Canon EOS Digital Cameras 15 17th of July 2004 (Sat) 20:18
10D out dated? By consumer Point and shoots?? photography By Evangelos Canon EOS Digital Cameras 12 5th of September 2003 (Fri) 21:12
