Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 8th of April 2004 (Thu)   #1
mikeg
mikeg's Avatar
Default Sto-fen bounce
Hello,
Could you tell me the main differences between the Sto-fen 2-Way Bounce Unit and the omni bounce ?
Which one should be the best ?
I'll use it on a 550ex.
Thanks,
MikeG
MikeG
Canon 1D , 1D MkIII, 24-70 2.8 sigma, 50 1.8II, 70-200 2.8 L IS, 100-400 L IS,st-e2, 500D,
17-40L, 580exII, Lowepro backpacks and stuff...
http://mikeg.frameit.be
mikeg is offline   Reply With Quote
Old 8th of April 2004 (Thu)   #2
Scottes
Trigger Man - POTN Retired
Scottes's Avatar
Default
Take this with a grain of salt since I'm not a portrait taker. I primarily use these products on my cats and for macro lighting.
Personally I don't get the Two Way. OK, so you can bounce light without a ceiling. Looks like a good way to bounce light into a lot of places you don't want it. It really doesn't make a much larger light source to give softer flash. I'd think it would be a little softer, but not a whole lot.
The Omni Bounce is OK is you want to lose light and diffuse it a little. I have one, and I don't like it so much. It certainly does have an effect, but it has more effect at reducing light rather than softening IMHO. I'm not knocking it completely - it's a handy product and definitely does have an effect. I don't go anywhere without it and I'm glad I have it.
I've got a Lumiquest Pocket Bounce which is more or less like the Omni Two Way. However, it directs all the light forward and makes for a much larger light area without so much light going places that you don't want it. Very little light loss, but since the light is spread over a much larger area of course you'll get less light on the subject. Lumiquest says light loss is 1-1/3 stops.
I also just ordered a Lumiquest Ultra Soft which is a Pocket Bounce with a milky panel over the front. So now take the Pocket Bounce and lose some more light and diffuse it more. Lumiquest says light loss is 2-1/3 stops.
Lumiquest also makes a couple different Soft Boxes for flash that look useful.
The Omni Bounce, Ultra Soft and Lumiquest Soft Boxes will diffuse light and spread it over a larger area. Diffusion will cause less harsh highlights. Nice for soft shadows at a cost of a lot of light. The Two Way and the Pocket Bounce spread the light over a larger area without so much light loss. Glare is a little harsher much much less than flasy alone, shadows are softer than flash but not as soft as diffusion types.
The Lumiquest system is much larger than the Sto-Fen stuff and is more difficult to put on the flash. The Omni Bounce fits in your pocket easilyand pops on the flash in a couple seconds. Very convenient.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info
Finally, I have a Gallery!
Follower of Fidget - Joined the cult of HAMSTTR
Scottes is offline   Reply With Quote
Old 8th of April 2004 (Thu)   #3
scottbergerphoto
scottbergerphoto's Avatar
Default
I have the Lumiquest Pocket Bouncer and the Stoffen Omnibounce. I feel that the Lumiquest gives a much more pleasant look. The Omnibounce seems to mostly reduce light.
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography
scottbergerphoto is offline   Reply With Quote
Old 9th of April 2004 (Fri)   #4
mikeg
mikeg's Avatar
Default
Thank you guys for your replies
MikeG
Old 9th of April 2004 (Fri)   #5
VonClev
Default
I have used some of the above mentioned products and were not terribly happy with them. For the buck, I really like the new Adorama "Strobo-Sock". They do a pretty good job diffusing both direct and bounced light (think of them as a mini-soft box for your flash), they're cheap, and you can fold and wash them.
Chuck
VonClev is offline   Reply With Quote
Old 9th of April 2004 (Fri)   #6
jcsorensen
Default
Just call me cheap. I cut a large rectangle out of a plastic gallon milk jug, curve it over the head of my flash and attach it with a couple of rubber bands. Seems to soften/diffuse the light somewhat and definitely cheap.
jcsorensen is offline   Reply With Quote
Old 9th of April 2004 (Fri)   #7
Scottes
Scottes's Avatar
Default
Ok, you're cheap.
If the milk jug is close to the flash then all you're doing is cutting down the light. A primary idea behind softening light is to get it to come from a larger source. So if that pice of milk jug were 6"x8" and 4" from the front of the flash, well NOW you'd be producing light from a larger light source and you'll be softening it.
That's the idea behind the Lumiquest stuff, and why the OmniBounce doesn't work so well. The OmniBounce is practically the same size as the flash, so it really doesn't come from a larger source, so it doesn't soften much. The lumiquest stuff makes the light bounce from a much larger area.
If you want to be cheap just bend an index card a bit, use an elastic to hold it to the flash, and point the flash straight up. The flash will bounce off the index card, thus the light will come from a larger area, thus it will be softened.
Old 10th of April 2004 (Sat)   #8
scottbergerphoto
Default
Ok, you're cheap.
I have seen many old time reporters do this. In addition, Nikon includes a pull out white card on their speedlights for this purpose. I wonder why Canon doesn't?
Scott
Best Regards,
Scott
Old 17th of April 2004 (Sat)   #9
lensecap
Default
just cause they used to do it and just cause nikon does it doesn't mean it works. You do need sme spce in there.
lensecap is offline   Reply With Quote
Old 17th of April 2004 (Sat)   #10
scottbergerphoto
Default
Well it does work quite well actually, and I hope you had a good nap! This thread is a little dusty.
Scott
Best Regards,
Scott
Old 17th of April 2004 (Sat)   #11
MediaMagic
Default
Scott
Agreed. I've used both and the Lumiquest Pocket Bouncer is the one I prefer as well.
MediaMagic is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sto-Fen Omni-Bounce necessary? jargaguy Small Flash and Studio Lighting 20 22nd of November 2006 (Wed) 18:18
Sto-Fen Omni-Bounce rosco1971 Small Flash and Studio Lighting 15 8th of September 2006 (Fri) 16:01
Sto-Fen Omni Bounce samvent Small Flash and Studio Lighting 2 4th of August 2005 (Thu) 15:44
STO FEN OMNI BOUNCE oursds Small Flash and Studio Lighting 23 29th of March 2005 (Tue) 17:27
Sto-fen Two-Way Bounce markubig Canon EOS Digital Cameras 0 13th of January 2005 (Thu) 22:08
