Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Weddings and Other Family Events Talk
Reply
Thread Tools Display Modes
Old 24th of March 2007 (Sat)   #1
tim
Light Bringer
tim's Avatar
Default Tims Wedding Workflow
I've had a few requests for information about my wedding workflow, so here goes. I can usually get color corrected images from a wedding onto the web within 12 hours of starting this process: 6 hours of my time to cull, 6 hours to color correct, plus 1 hour of computer processing time/upload time. When I started doing this it took a LOT longer, perhaps 20 hours: you get a lot faster with practice and experience. The better you are at shooting good exposures the less time it'll take. If you do printed proofs just use the JPGs produced by step 7, let the lab worry about downsizing.
Hardware:
- Intel 2600K, 16GB RAM, three hard drives, two SSDs Windows 7 64 bit (self built)
- External USB2 card reader (you can use two at once if you want). Sandisk Extreme 3 card readers are pretty quick.
- Transcend 16GB 300X cards.
Software:
- Fast Picture Viewer (incredibly fast culling)
- Adobe CS4 Bridge/Photoshop
- Photographers shopping cart
- FileZilla ftp client - http://filezilla.sourceforge.net
Shooting/setup stuff:
- Synchronise the times of each camera with your PC clock using EOS viewer (or whatever Canon software replaced it) BEFORE each wedding. This is ESSENTIAL. With Nikon you use Nikon Transfer.
- Shoot RAW (please don't turn this into a JPG/RAW thread, I won't answer queries about this. This is what I do and it works for me).
- Since I started shooting with manual exposure my post processing time has decreased. I still use Av mode and partial metering for situations where the lighting changes more rapidly than I can meter manually. Sometimes I just use the histogram instead of the light meter. I never focus manually.
Philosophy: I used to use this to make proofs, reasonable quality, not fully finished. That means another pass later to do final correction. I've found this inefficient, so I now do full color correction in this workflow. I correct everything to color, then apply my sepia preset to some images.
I do a first pass in Fast Picture Viewer to do the initial cull, then I do a pass in Bridge to color correct. I do a second pass in Bridge with the thumbnails small as anything not quite right stands out better that way.
Steps:
1) Copy each card to a subfolder of the customers event folder on my hard drive. Manually check image counts and that file sizes aren't zero (I had that problem once with a dodgy card reader). The CS4 Bridge download function is faulty, it only downloads some of the images, don't use it. Once verified copy all images to root of customers folder.
2) Point bridge at the folder and give it some time to create thumbnails. Wait until after the images have all copied else thumbnail generation sometimes goes weird.
3) Check to see all images are present. You can check using image numbers or visually, preferably both ways.
4) Change the bridge sort order to by date modified and visually check the images are in the correct order. If they're not change the sort order to by date. I never remember which one actually works. If they're still not you didn't do the pre-shooting stuff listed above. Sort them manually.
5) Use the bridge batch rename function to rename your images to something meaningful to you. I use a combination of the customer initials and initially a 4 digit number. This way I can sort by filename during processing, which is faster/more reliable than sorting by date, especially once psd files are created (though I don't make many of them).
6) Close Bridge and start Fast Picture Viewer and cull the images.
- Hit the keys 1-5 to indicate how good the image is. My system is 1=unusable for a technical reason, 2=duplicate image or not worth showing, 3=good image, 4=image that will probably go into an album, 5=image that will go into my portfolio. You can use any system you like.
- Label the images if something needs to be done. eg I might have labels "photoshop work required", "apply a special effect later", etc.
- I cull my assistant/second shooters images separately, by putting them into a different folder. I find this speeds things up heaps, for both the culling pass and the color correction pass.
7) Open bridge and use the filter panel to select images as follows. Images I rated 1* are deleted immediately, images I rated 2* are kept in case I need to do a head transplant or eye transplant (ie swap eyes/heads between pics). I rate duplicate images 2* and I rate quickly so I keep the dupes just in case I choose a blurry one or something. Customers aren't told I do this, one saw them once and they want copies of every image, usually I explain why they don't need them but on occasion i've given them out.
8) Now I do color correction. This means I can make albums, prints, and a high res CD from the JPGs, I generate now without having to go back to the RAW image. Color temp presets can be helpful, but I usually adjust from the preset. I often use the highlight recovery and fill light sliders to reduce the extreme bright and dark patches of the image, as it's to much dynamic range for print (to my eye). Using too much of the highlight reduction tool turns white to grey, I find the shadow highlight tool with highlights set to 10/10 more effective, but I only do this for images going in an album.
- By experience i've found that I don't want the histogram to quite touch the right hand side, else my prints come back brighter than I prefer. Exception is when the main subject isn't the brightest part of the image. I've done a whole bunch of 6x4" test prints with my lab with different brightnesses and color temps, and have discovered that what I see on my calibrated screen isn't quite what I get back, so I recommend doing similar tests. Take 2-3 images, bracket the white balance by -2000, -1000, 1000, and 2000, and for brightness by -1.5, -1, -.5, .5, 1, 1.5, and anything else you want to try.
- I have presets defined for B&W images & sepia. To make a B&W preset for this open any RAW image, drag saturation to -100, then tweak the sliders in the calibration tab to make the image look bettter. Hit the right arrow thingy, hit save settings subset, and tick the boxes you want to tick. I have a half dozen different presets, including one that resets all settings except the main tab ones. For prints I take the color photo into photoshop and use the channel mixer. In CS4 use the B&W checkbox, and split toning, both highlights and shadows set to orange with saturation of 10-15%
- Image is straightened if it needs it (shortcut key is A)
- I do a bit of clone tool type work in the ACR tool too (shortcut key is B). I think it's called blemish removal or something.
- A few images are taken into photoshop and played with, the result saved as a PSD in the same directoy as the RAW images. The RAW I worked from is moved to a subdirectory called "RAW Processed" (or something like that). This is so when I batch the directory I don't get two copies of the same file.
9) The order of using the sliders is important. Exposure comes first, in conjunction with blacks - they control the left and right hand edges of the histogram, and stretch the histogram as necessary. Highlight recovery comes in there somewhere too. The brightness comes next, it shifts the center of the histogram. Only then can color temperature be accurately set - of course you need a calibrated monitor. Once this is done you can start playing with contrast, and vibrance/saturation, or do your B&W/Sepia conversions.
10) Renumber all the keepers for the customer so they're sequential. This is important, if you don't do it the customer wants to see the "missing" images.
11) Any required photoshop work is done at this point. Mostly I do eye swaps, head swaps, basic things like that. I save the edited files as PSD files, in the Adobe RGB color space, mostly because my album company wants Adobe RGB. Most people should use sRgb. Once the edits are done I keep the psd files in the image directory, and I move the RAW files to a "Processed" subdirectory so I keep the RAWs in case I need them in future.
12) Once all images are rated I filter for 3 star or better images, select them all, right click and choose "open in bridge". I then hit select all, set sRgb, hit save, choose the proofs folder, set quality to ten, and hit go. This can take 10-30 minutes depending on the number of images (down from 1-2 hours with my old PC). The PSD files need to be done using image processor.
13) I pour myself a rum, relax, and let the computer do its thing. Wait until this finished before going onto the next step.
14) Use image processor to batch the images to 600pixels on the longest side for web proofing. I put them into about ten folders to correspond to parts of
the day (ceremony, portraits, reception, etc).
15) The generated jpg images are uploaded to my website, after creating the gallery in the shopping cart. 500 proofs are about 30MB. I use FileZilla since it can upload a number of files at the same time, which speeds things up hugely because of latency and how ftp works.
16) The images created in step 7 are used to create a DVD slide show of proofs, using Proshow Gold. Very simple show, bit of royalty free music, default transition, "\f" as the caption to put the filename onto each image.
17) Backups: until I have my images stored offsite on another hard drive I keep the cards with me at all times. I mirror my hard drive onto an external hard drive, which I keep in a secure location OUTSIDE of the building I work in. If it's in the same place a fire can destroy everything. I only delete the images from your cards once the offsite backups have been done. I've never lost an image, and I doubt I ever will. See the backups section below.
18) The album is predesigned using PhotoJunction remix, the customer see this when they come to see their images (a slide show of about 100 images set to music, on my 40" LCD TV with a nice surround sound system). This is a sales tool. The basic steps of working with PJ are:
- Export my 4* and 5* images into an "album" subdirectory
- Create the PJ project, import the images, categorise into parts of the day
- Design album
- Export as PSD files
- Sharpen and retouch
- Send to album supplier
For more on album design visit wedding album design tutorial.
Also see how to photograph wedding receptions.
Folder Structure
My commercial images are all on one drive. I have a root folder called "photos", under that I have folders for Weddings and Portraits. Under Each of those folders I have the year, then under each year I have the client name. This would have to be altered if I did multiple jobs for one customer, but so far it's fine.
My RAW files go into the root directory. Subdirectories include:
- Album files
- Rejected Images
- Graphics
- Documents
- Proofs
- Web proofs
All the folder names are shortened. I have a template folder structure which has things like templates for DVD labels, etc, which I copy into each customer folder.
Backups
Backups are critical. My philosophy with backups is to have one copy of the images for as little time as possible, and to have at least one copy offsite ASAP. Even after I copy the cards to my PC I put the cards back into a case which goes into my car, which is away from my house. The next day I run an offsite backup.
Hard drives are the only practical backup mechanism at the moment, DVDs and even blu ray are too small and too much hassle, and cloud backup isn't yet economic or fast enough given our data volumes.
I like to have as few hard drives as possible, mostly for simplicity of organisation. If a drive fills up I buy a new one 2-3 times larger, copy the data onto it, and put the old one into a drawer as an extra backup. Currently my PC has the follow disks inside it:
- System drive (60GB OWC SSD, 20GB free after all software installed)
- Personal data drive (1.5TB)
- Commercial data drive (1.5TB)
- Media drive (2TB)
- ACR/Bridge cache/scratch/swap (SSD, 120GB, mostly empty)
My offsite drives are as follows:
- Offsite mirror (2TB). Backs up all my internal drives, personal and commercial data. It's almost full, and i'm not backing up all my media files, so a 3-4TB drive is on the cards.
- A mirror of my archive drive. The difference is I convert the images to DNG for this copy, just to hedge my bets. I also keep jpeg versions of the files, and any psd files.
- I have another copy of my archive drive in a second offsite location. Just to be safe.
Mirrored data's copied to my offsite disks using Robocopy, but it's set to copy new files and update existing ones, but not delete files that are removed from the source disk... just in case. This is done after every significant event, or once a month if I haven't photographed a wedding or done any processing.
My archiving process is manual, I do it once or twice a year. My offsite mirror is done after every significant event. I use RoboCopy to do the backup mirroring, set not to delete anything off the backup drives. That means I end up with duplicate images with different filenames on the drive, but I manually cull those. There's heaps of different software to use for backups.
I have the free version of Mozy back up my album designs nightly, as these change fairly regularly. Mozy also backs up my contracts, financial information, and other random bits and pieces. I don't let it back up images, they're way too big. Mozy's been giving me some problems lately, not backing up modified or new files, so I'm investigating other options, such as CrashPlan.
If you need a color calibration system the Colorvision Spyder Express 4 is effective and reasonably priced.
I have lots of information available via FAQs i've written, there's a list here.
That's it I think. I'm happy to answer questions or hear comments and suggestions to improve my workflow. I'm happy with the workflow and can't see anything that needs improving. Snarky comments or flames will be ignored if i'm in a good mood, if i'm in a bad mood i'll call you names and insult your mother ;)
Hopefully this helps some of you out :) If you'd like to see some of my photos check out my website, Wellington Wedding Photography.
tim is offline   Reply With Quote
Old 24th of March 2007 (Sat)   #2
xmacvicar
Mr. Wizard "B.D.B on POTN"
xmacvicar's Avatar
Default Re: Tims Wedding Workflow
Great! Thank for the contribution....I am very stoked to try the jalbum and eos template for my proofing technique....DOH, another thing to keep me up all night learning!
Bodies: Canon 40D & Grip, Canon 5D
Lenses: Canon 70-200 2.8L IS, Canon 24-70, Canon 50L 1.2, Canon 85 f/1.8, Sigma 50mm Macro
Flash: Canon 580ex II, Pocket Wizard Plus II (2)
http://www.davidmacvicar.com/blog
xmacvicar is offline   Reply With Quote
Old 24th of March 2007 (Sat)   #3
PuR HART
PuR HART's Avatar
Great one man
Just in time for my next wedding.
a couple quickies, So on your proof site is that a site where you upload full high res jpegs and are they like smugmug were they print and ship or how does that work with uploading your proofs for your couple?
About how many pics do u let them choose from? because of server space?
thanks man sure I will have more
www.ryancharlesphotography.com
Bodies:
20D and 30D
Lenses: 17-55 2.8IS,70-200 2.8IS,17-85 4-5.6IS,50 1.8,100 2.8
macro
PuR HART is offline   Reply With Quote
Old 24th of March 2007 (Sat)   #4
PuR HART
PuR HART's Avatar
ok after looking at a few of your proof sites I see you upload apporx 350 pics give or take are these all high res?
Bodies:
20D and 30D
macro
Old 24th of March 2007 (Sat)   #5
Ray Marrero
Ray Marrero's Avatar
I encountered a couple who do not have internet access. What then? I did mention they could use a friend's or the library, but felt silly. Do you ever print proofs?
Ray
Canon 7D, 30D - 550ex & 580ex, Nikon SB-28's x3, AB800 x3, Canon 10-22mm, 18-55mm, 50mm 1.8, 85mm 1.8, 24-70mm 2.8L, 70-200mm 2.8L IS, Sigma 28-105mm 2.8, Tamron 28-75mm 2.8, CyberSyncs.
Ray Marrero is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #6
lil_miss
lil_miss's Avatar
Yikes that sounds like hard work.. lol
A bunch of Canon bits and pieces.
lil_miss is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #7
tim
Light Bringer
tim's Avatar
Originally Posted by PuR HART View Post
Great one man
I upload my quick proofs, when an order is placed i'm emailed the image numbers, I fully process them from the RAW, print them at my lab, and courier them out.
My proofs also go into a proshow DVD, and I can burn the web pages to CD. I also offer printed proofs and proof books, which are really easy to do.
Old 25th of March 2007 (Sun)   #8
Wazza
Wazza's Avatar
Translation?
1) Drink bourbon
2) Drink bourbon
3) Fall asleep.
Jokes aside, that's a nice workflow you have there. I'm really considering buying CS3 when it's official? Something like Rawshooter for tweaking raws, but fully functional to output to fully edited jpegs ready for printing. I hate double handling my images, and PS7 is so painful at times.
Wazza is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #9
S-S
frustrating simple something
S-S's Avatar
what about lightroom - rather than bridge and jalbum, would lightroom 1 be a suitable replacement? it also generates proof galleries of images in either html or flash format. only prob i have had was using dreamweaver to upload the completed gallery which was about 24mb: it timed out and refused to upload any of it (quite unlike any of my other web work) - so i would have had to put the whole gallery on cd and hand it to the couple. wold filezilla bypass that issue or is it something i would need to discuss with my hosting company?
I reject your reality, and substitute my own!
anything is possible if you don't know what you're talking about
S-S is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #10
tim
Light Bringer
tim's Avatar
EOS is an ordering system. Only looked at lightroom a little not really sure. Flash limits who can see your site so I don't use it. I'd talk to your host, filezilla is just an FTP client nothing too special.
Old 25th of March 2007 (Sun)   #11
LeesaB
"Patience is a what? "
LeesaB's Avatar
Tim, thanks for sharing, and I understand this is how YOU do things..there are alot of good key things in your sharing...Thanks...
Some of the things you have done, I do by hand...and will be looking into it a bit more as time goes on. My workflow will not begin to flow for a month yet..so I have time to experiment and try things out. UGh..more to do.
thanks again
LeesaB is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #12
Dachbean
Dachbean's Avatar
Hi Tim, Thanks for posting your workflow. It really helps people starting out, whent hey are trying to figure out their own workflow. I do have a couple questions for you.
1> what is the benefit of using DIM as opposed to just dragging and dropping the files into a folder? Is it due to the 3 hardrives you have?
2> Can you explain why it is essential to syncronize the time on your camera with your computer? Also are you doing this manually or are you hooking the camera up to the computer to do it? If so how do you do this?
Thanks again Tim for everything you post. you are a great guide.
Todd
30D, 24-105 f4 L IS, 50 f1.8, Sig 10-20, 580 EX & 430EX
Dachbean is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #13
Mike Reynolds
Mike Reynolds's Avatar
great help there thanks!
a special thanks to the Big Guy upstairs
http://mikereynoldsmotorsports.com/
my gear
http://photography-on-the.net/forum/...&postcount=289
Mike Reynolds is offline   Reply With Quote
Old 25th of March 2007 (Sun)   #14
tim
Light Bringer
tim's Avatar
1. It's easier, you can just insert the card and it copies it automatically. Also verifies. No great gain.
2. If you shoot with two cameras then sort by time order then the images are out of order, which is really annoying in the proofs, and for if you're looking for an image later. You do it with EOS viewer.
Old 25th of March 2007 (Sun)   #15
-MasterChief-
- B E L I E V E -
-MasterChief-'s Avatar
excellent list Tim! i specially appreciate this one:
"Synchronise the times of each camera with your PC clock using EOS viewer BEFORE each wedding. This is ESSENTIAL."
i keep forgetting to check the internal time on my two bodies before a shoot. it stinks when the shots from both bodies when combined are not in chronological order!
beginners argue about bodies, pros argue about glass, seasoned veterans let the pictures argue for themselves.
.:EOS 5D Mark II, EOS 50D, 17-40 f/4L, 24-105 f/4L 100 f/2.8L Macro, 70-200 f/2.8L IS:.
-MasterChief- is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tims recommended books tim General Photography Talk 55 23rd of October 2011 (Sun) 14:09
Wedding Workflow bcap Weddings and Other Family Events 12 30th of March 2007 (Fri) 14:13
Wedding Photographers Workflow extrememc Weddings and Other Family Events 13 26th of November 2006 (Sun) 00:50
Wedding Workflow rkphotography Weddings and Other Family Events 20 3rd of August 2006 (Thu) 03:53
wedding proof workflow philpereira Weddings and Other Family Events 3 23rd of December 2005 (Fri) 08:05
