Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 9th of April 2004 (Fri)   #1
maderito
maderito's Avatar
Default Canon ICC Profile Guide - Something New for Canon Printers
Today I again set out to update my previously fruitless search for Canon documentation on use of ICC profiles. To my surprise, I discovered this thread (follow the thread for a couple of posts).
The author of the thread summarizes his frustrations with Canon non-documentation, promises to contact Canon directly, and gets a PDF document from Canon which he helpfully posts.
Wow! The Canon ICC Profiles Guide is the first I have seen from Canon that addresses issues of color management when using generic or dedicated ICC profiles in Photoshop.
Canon suggests the following Photoshop settings when printing:
In Photoshop "Print With Preview":
#1: When NOT using dedicated, printer/media specific profiles:
1. Source space: Adobe RGB (or sRGB)
2. Print space: Printer Color Management
3. Print Driver: Select correct media, choose desired print quality, check manual color adjustment, select "Set...", and check "Enable ICM".
#2: When using a dedicated media-specific profile:
2. Print space: Select the media-specific ICC profile*
3. Printer Driver: Select correct media, check manual color adjustment, select "Set...", and select "None" for "Print Type". Do not enable ICM.
*Check here for free media-specific Canon ICC profiles for the S900/S9000, probably OK for the S820/S800, and possibly good for current models i950/960,i910/i9100.
The second workflow makes sense and is commonly recommended. Color management is disabled in the printer and left solely to Photoshop.
The first workflow is a bit of a surprise since it is commonly suggested to bypass ICM - operating system color management. It is consistent with the recommendation by Bruce Fraser ("Photoshop Color Management") for Epson printers when using generic profiles.
Background
Until recently, Canon provided only a generic profile with their printer driver software. This profile appeared to be used by the printer driver. The generic profile was selectable in Photoshop for soft proofing and printing, but did not seem to work properly. That is, the generic profile did not function to permit a smooth and accurate workflow from soft proofing to final print. Users were therefore driven to ad hoc solutions, typically turning off printer color management and using custom printer driver settings. I had opted to use default print driver settings ("auto" color management) after experimenting by trial and error with other approaches and getting unsatisfactory results.
Most frustratingly, there was NO Canon documentation on these issues...until now.
maderito is offline   Reply With Quote
Old 13th of April 2004 (Tue)   #2
IanD
Honorary Moderator
IanD's Avatar
Default
Some interesting info in the PDF. Many thanks for the link
Ian (Duck Photographer)
Have You Hugged Your Mallard Today?
More Images- My Gear
New Image Posting Rules (please read)
IanD is offline   Reply With Quote
Old 15th of April 2004 (Thu)   #3
ryuwulf
Default
WOWSERS!!!!!!!!
thanks, i own the S900 and ive been trying to tweak the crap out of it for a while. I even went so far as to buy a Sypder to calibrate my monitor.
This should help. Thanks!!!!!!!!!
ryuwulf is offline   Reply With Quote
Old 17th of April 2004 (Sat)   #4
iwatkins
Default
Excellent info.
I actually tried method #1, i.e. "Enable ICM" (even though it goes against everything I've read in the past). The results are a lot closer to what I see on screen compared to using the the same settings but with ICM off. Blues and greens are especially much better without having to resort to boosting the colours or intensity slider in the print driver.
Sorry, Photoshop CS to Canon i9100.
Cheers
Ian
iwatkins is offline   Reply With Quote
Old 27th of December 2004 (Mon)   #5
Robesse
Thumbs up Re: Canon ICC Profile Guide - Something New for Canon Printers
This is too funny. I just spent HOURS experimenting with color management in PSE 2 and my S520 to find out that doing what the ICC profiles guide reccomends is what works best. Oh well, I least I can attest to the fact that it is indeed what works the best!
-- Rob
Robesse is offline   Reply With Quote
Old 28th of December 2004 (Tue)   #6
Dale
Dale's Avatar
Default Re: Canon ICC Profile Guide - Something New for Canon Printers
If you use Qimage for your printing with the i9900 grab this:
http://www.photokaechler.com/files/Qimage_i9900.pdf
Regards,
Dale
Canon 20D, BG-E2, 580EX, collection of lenses, and empty pockets.
"If you aren't the lead dog the scenery never changes"
Dale is offline   Reply With Quote
Old 28th of December 2004 (Tue)   #7
maderito
maderito's Avatar
Some updated thoughts after re-reading my original post of April 2004.
The Canon ICC profile guide is intended for Canon printers that come with print media ICC profiles, which are specific to Canon papers and printer driver settings.
PR1 = Photo Paper Pro (print quality level 1)
PR2 = Photo Paper Pro (quality level 2)
SP1 = Photo Paper Plus Glossy (quality level 1)
MP1 = Matte Photo Paper (quality level 1)
I have the i950 printer which is not supplied with these profiles. So I downloaded and installed the i960 printer driver (the printers are nearly identical), which has the profiles. I configured my computer to use the i950 driver as my default printer driver. All this just to get the Canon media profiles! Now I can soft proof and print with Photoshop using the profiles. I have a calibrated monitor.
My test:
I used an Adobe RGB color space image file PDI Target_AdobeRGB.jpg and isolated the babies in the image to compare skin tones.
Images were printed on a Canon i950 with Photo Paper Pro and "Source Space: Document: Adobe RGB" selected in the Print with Preview color management options dialog.
1. Print space: printer color management
Printer driver color mgt: auto
- Results in a print with desaturated colors - which is to be expected when printing or displaying an Adobe RGB color space image on an sRGB device. This printed result can be visually duplicated by soft proofing (View>Proof Setup>Custom), selecting any profile, and checking "preserve color numbers." In other words, the printer assumes the image is in sRGB and thus performs no color space conversion.
2. Print space: printer color management
Printer driver color mgt: manual, enable ICM
- Good result, the same as if the file was converted to sRGB space - which apparently is what the printer driver does.
- This result may differ for i960/i9100/i9900 printer drivers. Maybe the newer printer drivers convert image data directly from the Adobe RGB image space to the print space specified in the Canon media-specific profiles. I don't know.
3. Print space: PR2 ICC profile (there are several options for rendering intent - see below)
Printer driver color mgt: Print Quality High (2); turn off color management (see my first post)
- Perceptual rendering - best result; slightly more saturated colors than #2
- Relative colorimetric - IMO oversaturated colors
- Each rendering intent can be set with or w/o black point compensation. I preferred the conversion w/o black point compensation.
- The printed images have a good match to my CRT monitor with soft proofing against the Canon ICC profiles.
Conclusions:
If working with Adobe RGB files,
1. Follow Canon's recommendations in the ICC profile guide. If you choose the "enable ICM" workflow, results may vary depending on whether your printer driver can use Canon's media-specific ICC profiles. If not, the image file is apparently converted to sRGB before printing and then printed with a generic Canon ICC profile.
2. If you use Canon or third party media-specific ICC profiles, you may have to try different combinations of rendering intents and black point compensation. The Canon guide suggestion - perceptual rendering with no black point compensation - worked well on the image I was using (using the Canon profiles; results probably differ with other profiles).
Much of the above also applies to sRGB image files. However, default ("auto") settings should work fine. In other words, in its default mode, my Canon i950 printer expects an sRGB file.
Old 19th of January 2005 (Wed)   #8
kevinma
I use Mac OSX and the Mac drivers have a different set of option to Windows e.g. no options re ICM. Does anyone have suggestions similar to the above for the Mac drivers?
Kevin.
kevinma is offline   Reply With Quote
Old 9th of February 2005 (Wed)   #9
johnleveritt
Kevin.
The link above and below, gives instructions for Windows, and Mac.
http://homepage.mac.com/renard/ls/Ca...file_Guide.pdf
Go to section 4 and read 4-2
See Ya,
John
johnleveritt is offline   Reply With Quote
Old 21st of November 2007 (Wed)   #10
drexal77
Kevin.
Hi Kevin, please please help, i'm having the exactly the same problem, the pdf instructions from canon are for pc based driver/printer set up screens and all the 'print with preview' instructions, are also totally different to a mac, so there is no ICM button or icc profiles showing up on my mac os x version of the latest i9100 driver/printer set-up, please let me know if you managed to solve the problem, i have 3 portfolio appointments next week and desperatly need to print my latest photography work by monday.
Thanks,
Ben
drexal77 is offline   Reply With Quote
Old 21st of November 2007 (Wed)   #11
kevinma
Thanks,
Ben
Ben, what I do - and it seems to work - is the following, re the key options that my setup gives me:
Color Sync - set to Standard
Quality and Media - enter the paper type and select the "printing a top quality photo" button
Color Options - set Color Correction to None
This works for me.
Now, if only I could get Lightroom to print a decent looking image.....
Old 22nd of November 2007 (Thu)   #12
drexal77
Hi again thanks for getting back to me so soon, and thanks for the awsum advice, i cant believe how much more detailed the drivers are for the pc, it's crazy, i will try and follow your advice and to hope for the best, one last thing, i know there's the issue with ICM button, but also, ive tried down loading about 3 or 4 different drivers, just so i can try to get the canon ICC profiles to show up in my print with preview, set printer profile box, but i cant get a single one to show up, what do you set your printer profile as, thanks again for all the help, and i will look into light room for you, i use it, but i never print from it.
B
Old 22nd of November 2007 (Thu)   #13
René Damkot
Moderator
René Damkot's Avatar
What software?
PSCS3: Click
PSCS2: Click
PS7: see a few post back: maderito posted the link.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 8th of February 2005 (Tue)   #14
Darth
Darth's Avatar
I can't get any of the profiles to come anywhere close on my Canon 950i. I have gone through hundreds of photo paper (Kodak Ultima, and Office Depot Premium) with pretty much the same results. I used the PDI Target_AdobeRGB.jpg to eliminate any mis calibration on my monitor (which appears right on anyway).
Using the Canon profiles, I get yellowish green cast with a blue-green cast to the greys. Using any of the downloaded Office Depot profile suggested above (as well as a Kodak Pro profile from their web site) I get a strong yellow skin color (somewhat natural looking but not like the redish original) and still the blue-green greys.
All this is pretty much the same whether using the profile in Photoshop Elements with ICM turned off in the Printer driver or setting PSE to Printer profile and enabling ICM (set to one of the different profiles).
I have tried using the Printer driver sliders to compensate even to the point of turning the Cyan down as far as it would go (-50%) with no satisfaction. As a note, the sliders don't seem to have much effect until you get to around 30-40% .
Any ideas?
Darth is offline   Reply With Quote
Old 8th of February 2005 (Tue)   #15
maderito
maderito's Avatar
I had similar problems until I got my monitor properly calibrated. Only then did I stop wasting paper. If you do enough printing, the investment in calibration and profiling hardware & software pays for itself. I thought my monitor was perfectly calibrated (by eye) also. It wasn't!
Even if it's not your monitor, you can only make progress on printing-related problems by controling for this critical variable in your color management workflow as you experiment with other variables.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon S820 ICC Color Profile mnj200g RAW, Post Processing and Printing 2 22nd of June 2008 (Sun) 05:25
ICC profile for Canon Glossy Photo paper mercurius RAW, Post Processing and Printing 4 15th of November 2006 (Wed) 15:50
Where To Get Canon i950 ICC Profile picworx RAW, Post Processing and Printing 2 29th of June 2005 (Wed) 18:39
G3 ICC Profile TibbySF Canon G-series Digital Cameras 4 29th of December 2002 (Sun) 14:30
ICC profile Reinhard Canon G-series Digital Cameras 6 12th of February 2002 (Tue) 04:28
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
