Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 30th of March 2007 (Fri)   #1
purelithium
Blithering Idiot
purelithium's Avatar
Default Time Lapse
I couldn't figure out if I should put this here or in the Camera forum, so I decided on here.
I want to make a time lapse of 1 second intervals with my 300D. Can I use the Canon remote (with the LCD..)? or Will I have to use the software method?
Does the Canon Software for the Mac have the time-lapse capability as well, or am I out of luck?
Thanks a lot!
R.M. Gelan Hopkins
5D|Voigtlander 20 3.5|EF 50mm 1.8 Mk I|430EX
third element photography | Gear
purelithium is offline   Reply With Quote
Old 30th of March 2007 (Fri)   #2
Mike
ugly when I'm sober
Mike's Avatar
Default Re: Time Lapse
I think the timer control remote switch should work. I believe that they can be programmed to take photos at a pre-detemined interval.
www.mikegreenphotography.co.uk
Gear
UK South Easterners
flickr Blog 5∞px
Quis custodiet ipsos custodes? ::: A closed mouth gathers no foot.
Mike is offline   Reply With Quote
Old 30th of March 2007 (Fri)   #3
purelithium
Blithering Idiot
I looked at the compatibility list on the B&H site, and it doesn't say anything about the 300D in the compatibility list... grr...
R.M. Gelan Hopkins
Old 30th of March 2007 (Fri)   #4
SWPhotoImaging
SWPhotoImaging's Avatar
Th Canon TC80N3 timer remote doesn't work with the 300D. It's just as well, because the shortest interval it will accept is 10 seconds.
The other problem you will have wiith a shot every second is that you'll run out of buffer because the camera can't keep up with writing them to CF card at 1FPS for very long.
The specs say that the 300D can shoot 2.5fps for 4 shots. That would imply that the buffer is four shots deep. At 1fps, you might get five in before hitting the "full buffer" error.
I don't know how long a movie you want to make, but 60 frames in a minute, played back at a typical 29 fps, will be a 2 second movie.
There is a software package called "iStopMotion" that will remotely control your camera via USB from a computer, that will allow all kinds of settings, but you are still constrained by the limits of how fast the camera can write files.
SWPhoto-Imaging
SWPhotoImaging is offline   Reply With Quote
Old 30th of March 2007 (Fri)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
Depends on the quality setting, no? I wonder what it would be at medium jpg, which might be OK for web video.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 30th of March 2007 (Fri)   #6
SWPhotoImaging
True, specs are for large/fine.
Small could probably go much longer, but the 300d is very slow at writing to memory, so testing would be in order.
SWPhoto-Imaging
Old 30th of March 2007 (Fri)   #7
purelithium
Blithering Idiot
I would be working in Small/Fine. it's still a high enough resolution at 1536 x 1024 to even be HD compliant after some cropping. Most likely I would make them into a 640x480 movie anyhow.
Thanks for the tip on the software, I'll test that this weekend. thanks a lot!
R.M. Gelan Hopkins
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
time lapse jiggling_john Canon EOS Digital Cameras 4 6th of April 2006 (Thu) 20:24
Time Lapse CanonCam The Business of Photography 6 29th of March 2006 (Wed) 14:07
Time lapse w/G3 joebunda Canon G-series Digital Cameras 6 29th of April 2003 (Tue) 09:57
Time lapse? ShoelessOne Small Compact Digitals by Canon 1 3rd of October 2002 (Thu) 00:19
TIME LAPSE johnwaite Canon G-series Digital Cameras 3 23rd of August 2002 (Fri) 08:33
