Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EF and EF-S Lenses > Lens Sample Photo Archive
Reply
Thread Tools Display Modes
Old 2nd of April 2007 (Mon)   #1
jacobsen1
jacobsen1's Avatar
Default Sigma 12-24mm EX DG - Popeye
I was just looking on the lens sample images archive thread (that's a mouthful/fingerful!) and noticed the Sigma 12~24mm wasn't on the list. I figured I'd start a thread with some samples of what I've done with it.
I have some reviews up on my Pbase account, you can find this lenses review here:
http://www.pbase.com/benjacobsen/sigma_12_24mm
all the reviews are linked in my signature.
on to some test shots:
on my old 10D:
HDRi with my 1DmII
and this is what it looks like:
Ben
jacobsen1 is offline   Reply With Quote
Old 2nd of April 2007 (Mon)   #2
joshandlauri
joshandlauri's Avatar
Default Re: -= Archive =- Sigma 12-24mm EX DG images.
Excellent Idea, can't wait to see more pics.
Canon 350/xt ,50mm 1.8, Sigma 17-70mm, Sigma 70-300mm DG Macro, Sigma Super Flash Canon Backpack, Ebay tubes (awesome), Cheap tripod and a Sony DSC-S40 and a lot of hope and dreams of more gear.
And in 3 Months either a Canon 70-200 f/4 or a 70-300 IS still debating.
joshandlauri is offline   Reply With Quote
Old 2nd of April 2007 (Mon)   #3
august23
Sensitive + Shopoholic = chick?
august23's Avatar
Does the Sigma 12-24 work on FF? I mean I expect rediculous vignetting wide open but zoomed to say 16-20?
august23 is offline   Reply With Quote
Old 2nd of April 2007 (Mon)   #4
jacobsen1
jacobsen1's Avatar
yep. I know seeing as much info, first hand experience, and test shots as you can always helps. The other thing I'd love to see, is this lens compared on 3 different sensor sizes. I might be getting a XTi here soon, and if so I'll also post up some shots with that combination. I know of some guys using this on 5Ds too, so it gets really wide there...
I've realized the more I look at my shots with this lens, I tend to use it at 12mm more than all other FLs combined... Interesting.
The other test I'd love to see, is this on a 1.3 cropped sensor, versus a 10~22 on a 1.6 and then toss in a 17~40mm or 16~35mm on a FF body just to see how they all compare.... Obviously different resolutions will effect the outcome a bit, but if you "water" them all down to say 8mp (or whatever the lowest of the bunch was) and compare them, I'd be very curious to see how they stack up. I like the idea of a super lightweight travel setup with a XT/XTi with the 10~22....
Ben
Old 2nd of April 2007 (Mon)   #5
jacobsen1
jacobsen1's Avatar
From what I've seen it "works" fine on a FF and only has slight vinetting. I loaned mine to a friend with a 5D for like 10 minutes and that was enough for him to go buy one.
Ben
Old 1st of May 2007 (Tue)   #6
cjm
cjm's Avatar
Ben
PLEASE get your friend to post some FF shots at 12mm. We are all dying to see I think.
Christopher J Martin
Gear: 1D MKIII - 60D - 40D - G9 - 24mm f1.4 L
- 24-70mm F2.8 L - 70-200mm IS f2.8 L - 100-400 f4.5-5.6 IS L and more...
cjm is offline   Reply With Quote
Old 2nd of May 2007 (Wed)   #7
Lani Kai
"blissfully unaware"
Lani Kai's Avatar
1D Mark II, 12mm, 1/40s, f/11
SmugMug | Facebook | Twitter | Google+ | 500px
Equipment list | Colorburn
Founder, Canon Digital Photography group on Facebook
Lani Kai is offline   Reply With Quote
Old 2nd of May 2007 (Wed)   #8
hmv
Yes. And moderate vignetting wide open ... not the kind you get from a lens not intended to cover a full frame. Both of the following were taken on a 1Ds :-
Just to point out the weak point in my equipment list is the stuff behind the camera
Mike Meredith, Gallery: http://zonky.org/gallery2
Take anything I say with a big pinch of salt ... I don't know what I'm talking about
hmv is offline   Reply With Quote
Old 2nd of May 2007 (Wed)   #9
jacobsen1
jacobsen1's Avatar
Now on my 5D (all at 12mm):
Old 3rd of May 2007 (Thu)   #10
cjm
cjm's Avatar
Wow that isnt too bad at all. Heck my 10-22 does that sometimes when I put a filter on it and I don't mind because it takes very little time to correct it when shooting with RAW. NICE when I go FF someday I am buying this lens. Amazing stuff.
Old 3rd of May 2007 (Thu)   #11
bowlesbe
Wow, 12 on a 5d is definately wider than 10 on a crop.
*the perfect crop setup*
30d / 10-22 / 17-50 / 60 macro / 70-300 IS
bowlesbe is offline   Reply With Quote
Old 3rd of May 2007 (Thu)   #12
Mr. Clean
Mr. Clean's Avatar
Considerably. 16mm of FL compared to 12 on the wide end is huge.
I'm sold on this lens completely now. Especially since it's the only true UWA lens for 1.3 crop.
Mike
some shots @ Zenfolio
Mr. Clean is offline   Reply With Quote
Old 4th of May 2007 (Fri)   #13
Kraig C
Kraig C's Avatar
Alot of great examples, much wider than the kit lense, I've decided that after seeing this... I need a wider lens!
Kraig C is offline   Reply With Quote
Old 4th of May 2007 (Fri)   #14
jacobsen1
jacobsen1's Avatar
Yeah, that's why I got it originally is I knew I'd go FF eventually, but had a 1.3 so it was the only way to get to ~16mm there...
I'm keeping this, but I think I also want the 17~40L for filter use and so I don't get too dependant on the whole 12mm super wide angle (seems when I use this lens 99% of the shots are at 12mm....)
Ben
Old 11th of May 2007 (Fri)   #15
jojet
I had the 12-24 with me in China. I didn't use it most of the time (that was the 24-105) but 12 mm on FF (i shoot with 5d).... boy what an angle!
12mm, f11
An another in the Jaden Boeddhaa temple, Shanghai
12 mm, f 4.5
john
jojet is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Popeye fxk Canon EF and EF-S Lenses 14 5th of September 2008 (Fri) 07:39
sigma 14mm or sigma 12-24mm? datadump Canon EF and EF-S Lenses 3 28th of December 2007 (Fri) 13:10
Sigma 12-24mm MaDProFF Canon EF and EF-S Lenses 18 12th of November 2007 (Mon) 13:07
SIGMA 12-24MM F4.5-5.6 AF ZOOM vs SIGMA 10-20mm F4-5.6 EX DC ClickClick Canon EF and EF-S Lenses 15 24th of August 2006 (Thu) 20:53
