#1 |
One thing I can't comprehend about the 580EX zoom settings is that how would I know what zoom setting I have to set it? The manual says, "The flash coverage can be set to match the lens focal length from 24mm to 105mm". I have a 24-105 lens, do I have to set it at 24mm or 105mm? Or do I have to set it by what it says on the lens zoom readout like for example I am at 70mm, do I have to set the flash zoom to 70mm? Hey what about lenses like 70-200 which are not covered by the flash range which is 24mm to 105mm only? How do you handle that? any help is much appreciated. thanks guys.
5D mk1 + Grip | 24-105L | 85L II | 135L | 70-200L mk2 | Kenko 1.4X TC | 580EX II "Imagination is more important than knowledge..."--Albert Einstein |
| sponsored links |
#2 |
Don't get pissy with me
If it's on auto it will zoom automatically. If you're bouncing it won't zoom.
How do you know it's on auto you ask? There is no "M" next to the focal length on the LCD.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid! |
#3 |
I guess I didn't make myself clear. Let's say I am using manual mode. I set the Flash Zoom to say 24mm. My question is that is this the right settings if I am using 24-105 lens? I mean, how would I kow the right flash zoom settings?
| sponsored links |
#4 |
Like I said, let it zoom automatically. And don't worry about it.
#5 |
i have problem in auto mode. the pics came out kinda dark instead of flash filled.in fact, there's a thread for this 580EX issue here. i just can't find it anymore so i can learn from it. at the time i read the thread, i was not using flash yet so i didn't pay attention to it.
#6 |
#7 |
#8 | |
Master Flasher
In the meantime, the links that cdifoto provided are highly recommended.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
| Thread Tools | |
| Display Modes | |
| Very confused with my Colour management settings | dave_bass5 | RAW, Post Processing and Printing | 18 | 11th of May 2007 (Fri) 05:36 |
| Adobe CS2 - Color Settings Confused? | picworx | RAW, Post Processing and Printing | 14 | 16th of January 2007 (Tue) 04:09 |
| ISO settings? Why...it's digital...I'm confused | Redman | Canon EOS Digital Cameras | 17 | 5th of December 2005 (Mon) 20:02 |
| 20 D settings and confused. | Salleke | Canon EOS Digital Cameras | 2 | 18th of April 2005 (Mon) 05:45 |
| New G2 confused with settings | haroldontherocks | Canon G-series Digital Cameras | 3 | 27th of December 2002 (Fri) 18:33 |
