Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 7th of April 2007 (Sat)   #1
totalbeginner
totalbeginner's Avatar
Default Flash metering.
Does the metering mode you set on your camera effect how the flash is metered?
The reason I ask, is becasue I was experimenting with fill flash yesterday. I set my camera to spot, so that I could judge the ambient exposure on my friends face. With my camera set to "M", I dialed in -1 2/3rd FEC and took the shot.
When I reviewed the image, the face was completely blown-out. Was this because when the shot was taken, the spot metering circle was over the background and not the face?
View my gear list HERE
Don't submit to stupid rules, be yourself and not a fool. Don't accept average habits, open your heart and PUSH THE LIMITS!
totalbeginner is offline   Reply With Quote
Old 7th of April 2007 (Sat)   #2
PacAce
Moderator
PacAce's Avatar
Default Re: Flash metering.
How did you set the aperture and shutter speed in Manual mode and what settings did you use? Do you have a sample shot you can post?
But to answer your question, no, the metering mode set on the camera does not affect how the flash is metered. That is controlled by what you have C.Fn-14 set to. Of course, if you use flash exposure lock (FEL) then the flash metering will be done using the spot meter.
...Leo
PacAce is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flash Metering Help jnksherman Small Flash and Studio Lighting 5 28th of February 2007 (Wed) 23:10
evaluative flash metering sambahri Small Flash and Studio Lighting 1 3rd of November 2005 (Thu) 15:01
Question of flash metering J.A.F. Doorhof Small Flash and Studio Lighting 29 1st of July 2005 (Fri) 16:00
Flash metering with 10D Jesper Canon EOS Digital Cameras 5 17th of November 2004 (Wed) 16:42
G5-flash-metering jjoejr Canon G-series Digital Cameras 3 27th of December 2003 (Sat) 16:24
