Reply
Thread Tools Display Modes
Old 8th of April 2007 (Sun)   #1
beachbum2277
beachbum2277's Avatar
Default Which lens for portrait work?
Canon 28mm/1.8 or Sigma 30mm/1.4
I'm looking for a lens to do portrait work on my 1.6 crop camera. What do you think? Anyone with experience with both of these lenses?
Bryan Docter Fine Art Photography - www.bd-photos.com
beachbum2277 is offline   Reply With Quote
Old 8th of April 2007 (Sun)   #2
Psychic1
Psychic1's Avatar
Default Re: Which lens for portrait work?
Personally, I think both are too short and your 50-1.8 might be better suited for the task. I use the 135L on the 5D at F4 when doing Corporate portrait work, and for that reason I'd recommend the 85-1.8 or the 85L. The 75-300 would also work.
I shoot F4 because it's corporate, at f2 -you get blurry ears. Practice, practice, practice.
1DsIII - 1DIII - TS-E24L - 35L - 24/70L - 24/105L IS - 70/200L IS 2.8 - 400L 5.6 - 580EX II & CP-E3 - 430EX - 2x 270EX II - ST-E3 - 1.4xII - 25mm Ext.
Psychic1 is offline   Reply With Quote
Old 8th of April 2007 (Sun)   #3
splitfyre
85 1.8 on a crop body is great for head shots, while the 50 1.4 is great for 3/4 length portrait work on a crop.
Digital: Canon 5D2,5Dc,40D
Film: Yashica FX-2
Lenses: Canon 35L, 50 1.4, 85 1.8, and Canon 135L
splitfyre is offline   Reply With Quote
Old 8th of April 2007 (Sun)   #4
liza
User is banned from forums
Excellent advice. The 24-70L is also a great portrait lens.
liza is offline   Reply With Quote
Old 8th of April 2007 (Sun)   #5
morehtml
morehtml's Avatar
On a 1.6 crop the 50 f/1.4 or 85 1.8 will do fine. 35mm or less is fairly wide except for full body shots.
"Allen's Visions of Nature Gallery"
www.allensvisions.com
more glass than I need
morehtml is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #6
Pasukun
Pasukun's Avatar
For the shoulder and above shot, 85.8 is the gem to use.
"the things we touch have no permanence.. as there is nothing we can hold onto in this world.. only by letting it go can we truly possess what is real.."
My Gears
Pasukun is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #7
cdifoto
Don't get pissy with me
cdifoto's Avatar
Agreed. I ditched my primes. Might buy 'em again for lowlight stuff, but the 24-70L makes them redundant for portraits. 30mm is too short unless you're doing an intentionally distorted perspective shot and/or on a small space with your subject with no room to back up.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #8
steved110
steved110's Avatar
28mm and 30mm are too short for portrait use unless you are quite far from the subject - they are both wide angle lenses and this is unaffected by the crop dfactor - so if you are close to the subject things like noses, chins and hands look huge - thus very unflattering.
They make good group portrait lenses however.
In the main for a crop camera the best choices are 50mm, 85mm and 100mm if you have a little room.
For film/ full frame, the 85mm, 100mm and 135mm are the most popular lenses. These lenses actually flatten the perspective, and give the most pleasing proportions to facial features.
I actually use my 70-200 f/4 as my first choice portrait lens - it produces stunning results, especially outdoors or with flash.
20D, Eos 100
Canon EF-S 18-55 IS, Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L and 70-200 f/4 L
Speedlite 580EX and some bags'n pods'n stuff
steved110 is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #9
digitaljoe
24-70 - all the way - My moneymaker lens!
digitaljoe is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #10
poah
used the 30mm sigma and its fine. distortion depends on how close you go in.
the FL you get depends on how far away you can get from the subject lol zooms are good and you'll not normally be shooting wide open as you'll not get enough DOF.
Free printer profiles PM me for info
poah is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #11
SkipD
SkipD's Avatar
While the focal length recommendations in this post are right on the money, there is a misunderstanding that I think needs clearing up. That is the myth that different focal lengths have perspective characteristics associated with them.
No focal length has any perspective characteristic associated with it. Longer lenses do not "flatten" perspective, for example, any more than shorter lenses do - at least not by themselves.
Perspective is totally controlled by the distance between the viewer (or the camera) and the subject. If you are too close to the subject, then a nose will look larger relative to the rest of the face than if you are further away. If you move further away, the perspective becomes more pleasing. However, this has nothing to do with the chosen focal length except for the fact that most folks choose a focal length and THEN choose the distance to the subject to fill the frame. At the same camera-to-subject distance, all lenses ("fisheye" and other specialty lenses excepted) will provide precisely the same perspective. The only difference will be how much of the frame is filled with the subject.
This can be proven easily with this experiment:
1) Set your camera up on a tripod in front of a subject that has objects that are at various distances from the camera. Establish a distance that would let you take a photo including the nearest and the furthest objects with a long lens.
2) Take a series of photos with various focal lengths including a wide-angle lens. DO NOT MOVE THE CAMERA between shots.
3) Now, print the image taken with the longest lens.
4) Crop the rest of the images so that all of them show precisely the same amount of the subject as the shot taken with the longest lens in the series.
5) Print all of the images.
6) You will see that the perspective with all the shots (relationship of sizes between near and far objects) is identical.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #12
Psychic1
Psychic1's Avatar
[quote=No focal length has any perspective characteristic associated with it. Longer lenses do not "flatten" perspective, for example, any more than shorter lenses do - at least not by themselves.[/quote]
Well said, Thank you for correcting that myth.
Old 9th of April 2007 (Mon)   #13
ken_vs_ryu
you can do half body shots with the 28 and 30 with a crop.
ken_vs_ryu is offline   Reply With Quote
Old 9th of April 2007 (Mon)   #14
Wilt
Wilt's Avatar
I agree with what SkipD posted...a focal length has no inherent perspective; perspective is controlled by camera position. Real examples from experience...
...I do not like group photos at weddings with a 40mm lens on 645 medium format SLR because of perspective exaggerating bellies and butts on people who are closer to the lens than people who are farther away...86 degree angle of view on the lens which gives a 7.7x10' area of view at subject distance of 7'.
...I do not like group photos at weddings with a 24mm lens on 35mm SLR because of perspective exaggerating bellies and butts on people who are closer to the lens than people who are farther away...84 degree angle of view on the lens which gives a 6.9x10.4' area of view at subject distance of 7'.
...I do not like group photos at weddings with a 15mm lens on APS-C dSLR because of perspective exaggerating bellies and butts on people who are closer to the lens than people who are farther away...84 degree angle of view on the lens which gives a 7.9x10.4' area of view at subject distance of 7'.
What is in common with all of the above examples is the 7' shooting distance for groups, and the fact that the bride's mother who is 5' away will have her posterior size made apparently bigger than her portly husband with the beer belly standing 7' away.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is online now   Reply With Quote
Old 9th of April 2007 (Mon)   #15
angryhampster
"Got a thick monopod?"
angryhampster's Avatar
Anything between 30-100mm on a crop camera with a wider aperture than f/4.
That gives you a lot of options. There is no "best" portrait lens. It's all about how you use it. I've seen stunning portraits from a 300-800mm Sigma before...AT 800mm!
angryhampster is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For those of you that do portrait work... Photolistic The Business of Photography 4 28th of November 2006 (Tue) 11:40
Do you use your lens hood indoor for portrait work? TMR Design Canon EF and EF-S Lenses 28 3rd of November 2006 (Fri) 18:24
Ready to purchase another lens or two for portrait work mgplus2 Canon EF and EF-S Lenses 3 11th of April 2006 (Tue) 18:24
Portrait Work minatophase3 Critique Corner 4 12th of July 2004 (Mon) 13:39
Portrait w/ PS Work Mashuri Critique Corner 10 14th of December 2003 (Sun) 21:29
