FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 09 Apr 2007 (Monday) 11:26
Prev/next
Quarter inch in metric?(thread size for tripod mount)
perfect_pixel
perfect_pixel's Avatar
Salisbury, UK
Apr 09, 2007 11:26 |  #1
Hi,
Probably a really simple question but I've been to three DIY stores and can't find a bolt that will fit into the tripod mount on the bottom of my camera.
I know it is a standard quarter inch thread but can anyone tell me what I should be looking for in metric terms and how many threads per inch it is?
Thanks in advance :D!
Steve
"...Most things in life are moments of pleasure and a lifetime of embarrassment; photography is a moment of embarrassment and a lifetime of pleasure..." ~Tony Benn
Michael
Michael's Avatar
Perth, Western Australia
Apr 09, 2007 11:28 |  #2
1 Inch is 2.54 cm, or 254 mm.
Michael
Michael
Michael's Avatar
Apr 09, 2007 11:29 |  #3
So, you are looking for a 63.5mm thread??
Michael
cosworth
I'm comfortable with my masculinity
cosworth's Avatar
Duncan, BC, Canada
Apr 09, 2007 11:31 |  #4
The thread in all modern camera bottoms is 1/4 -20.
This is a very common bolt. You need to find a better store! Maybe your threads are damaged. A 1/4 -20 should go right in.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
perfect_pixel
Salisbury, UK
Apr 09, 2007 11:46 |  #5
Thanks for the quick replies...
So I would be looking (in metric terms) for a 63.5mm diameter bolt with 7.87 threads per centimetre (20 threads per inch)?
Does anyone know what this equates to in terms of M3, M4, M5, M6 or which of THESE (external link) it would be.
Something so simple and I am completely lost.....
The stores I tried were B&Q, Focus and Homebase I even took my grip along and opened the packets to try them at the first two. I was popular when I walked out with nothing :D!
Thanks again,
Steve
cosworth
cosworth's Avatar
Duncan, BC, Canada
Apr 09, 2007 11:49 |  #6
I'm not sure why you'd need a metric bolt since the threads in your camera are NOT metric.
JWright
JWright's Avatar
Joined Dec 2004
Apr 09, 2007 11:53 as a reply to perfect_pixel's post |  #7
Having worked in the hardware department of a Home Depot here, I don't think there is a standard metric bolt that is an exact match for a 1/4-20 thread. My suggestion would be to see if you could order it from a US supplier on-line.
IMO, one of the dumbest things the United States ever did was NOT adopting the metric system...
John
perfect_pixel
Salisbury, UK
Apr 09, 2007 11:59 |  #8
cosworth wrote in post #3010785 (external link)
Because I live in a metric country where even market traders get fined for showing weights in imperial...:rolleyes:
Every bolt I have seen (even online) is described in metric and are what I assume are standardised sizes (i.e. the M4, M5 etc).
If I am completely missing the point then please tell me and if anyone can point me in the right direction for getting some then p l e a s e do - this is beginning to take over my life!!
IMAGE NOT FOUND IMAGE IS A REDIRECT OR MISSING!
HTTP response: 404 | Byte size: ZERO
Steve
cosworth
cosworth's Avatar
Duncan, BC, Canada
Apr 09, 2007 12:08 |  #9
You are missing the point. I live in a metric coutry as well and it's DEAD EASY for me to find a 1/4- 20 bolt, nut etc. It's quite possibly the most common standard size.
I think you are looking in the wrong spot. Your local fasterner supplier will set you up. Maybe your local machine shop can point you in the right direction if you can't locate them in the phone book.
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Apr 09, 2007 12:27 |  #10
Seriously, whether you're in a metric-only country or not, you're going to need to find a 1/4"-20 thread screw. There is no metric descriptor.
Jon
Cocker Spaniels
perfect_pixel
Salisbury, UK
Apr 09, 2007 12:34 |  #11
Okay, thanks again for the help everyone. If there is no metric equivalent then I will try a smaller non-superstore-chain shop and see what they have - as Cosworth says I must be looking in the wrong place with the larger stores.
Thanks,
Steve
SimonG
SimonG's Avatar
Kitchener, ON
Apr 09, 2007 12:45 |  #12
Sinkrate wrote in post #3010676 (external link)
Close. It's 25.4 mm to an inch.
-- Michael (a.k.a. SimonG)
EOS 5D | 17-40 f/4L | 24-105 f/4L | 40 f/2.8 | 50 f/1.4 | 85 f/1.4 | 430EX | Zenfolioexternal link
Nanscombe
Nanscombe's Avatar
Kent, UK
Apr 09, 2007 13:36 |  #13
Hi Steve,
It may be a daft question, but ... why do you need a bolt to go into the Tripod mount of your camera?
You may be better off looking in camera stores, they will have all sorts of camera mountings, as you may find something that you can adapt. Something like a cheap quick release plate or the like in an oddments bin.
Or perhaps a boot fair.
Regards
Nigel
Nigel
flickrexternal link, antBlogexternal link
montreal
montreal's Avatar
Trondheim, Norway
Apr 09, 2007 13:48 |  #14
SimonG wrote in post #3011106 (external link)
:D I was about to say...
5D - 17-40L, 70-200L f4, 50 f1.4, PowerShot A430
alexlex
alexlex's Avatar
Belgrade, Serbia
Apr 09, 2007 15:45 |  #15
:) :) :) u Ouisses needs to rework on some issues, nhf mate :)
Canon / 5DII / TS-E 24L / 50 1.4 / 100L / 16-35L f4 / 24-105L /
40,108 views & 1 like for this thread
made in Finland
by Pekka Saarinen
Spent 0.00102 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is Alfred Butz
986 guests, 447 members online
