#1 |
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
Does anyone know if Canon can or will be able to clean/repair a lens that has "Very slight haze" on the elements?
I understand this will cost either way.. but think of a really good deal on a 400mm f/2.8 because fo the haze... if they could fix it it would be a super bargain. Can Canon clean it/fix it? |
| sponsored links |
#2 |
Canon Fanosapien
I suspect that they could clean it up for you, but I have no idea of the cost. I would guess that depending on where the haze is, it may require a good deal of disassembly or it could be more simple.
Tom 5D III, 7D, & various lenses |
#3 |
Honorary Moderator Join Date: Dec 2003
Nope, they cannot do that. You might was well send me the lens and I'll use it as a door stop
Ian (Duck Photographer) Have You Hugged Your Mallard Today? More Images- My Gear New Image Posting Rules (please read) |
| sponsored links |
#4 |
Admin
Based on my experience with the 'gravitationally challenged' 100-400, Canon uses a flat rate for lens repairs. In the case of my lens, it's $299 plus any parts. I would guess that it's the same policy with the 400 f/2.8, although the flat rate is probably different.
My understanding is that they will do whatever is necessary including complete disassembly, reassembly, and calibration. If the haze can simply be cleaned off the optics, the repair should be no more than the flat rate. If the haze is 'terminal, replacing the optics will no doubt be brutally expensive. Of course I am strictly guessing, but the correct answer probably is, 'depends'. (Somehow, the mention of adult diapers seems appropriate when talking about a cheap 400 f/2.8. I know it would have that effect on me.)
I'm not short. I'm concentrated awesome!
#5 |
Moderator
CDS, give them a call and ask them. If you call the general number, you'll get the customer service located in Somewhere, USA but they should be able to tell you if the one in NJ, if that's the closest one to you, can fix/clean the lens for you. They might even be able to give you a qoute on the price.
...Leo |
#6 |
If you were lucky, then the haze might be some simple water vapor on internal surfaces of the lenses. Cleaning would get that.
If you were unlucky, then the haze might be from magnesium fluoride removed from the front surface of the foremost lens element. ---Bob Gross--- |
#7 |
Thanks... hmm much to ponder...
| Thread Tools | |
| Display Modes | |
| info on lens and camera calibration at Canon Service | kosin | Canon EF and EF-S Lenses | 9 | 24th of July 2007 (Tue) 21:53 |
| Can Lens Warranty service question | ronan_zj | Canon EF and EF-S Lenses | 0 | 16th of June 2007 (Sat) 00:22 |
| Recommend best UK service centre to calibrate lens? | paulhillion | Canon EF and EF-S Lenses | 3 | 25th of June 2005 (Sat) 07:09 |
| How long to get lens from Sigma Service? | rebel61021 | The POTN Lounge | 5 | 16th of February 2005 (Wed) 17:25 |
| Great service from Canon Service Center in Irvine | tannoy | Canon EOS Digital Cameras | 4 | 11th of March 2004 (Thu) 10:16 |
