Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 17th of April 2007 (Tue)   #1
ChrisBlaze
ChrisBlaze's Avatar
Default Canon updates EOS Digital Rebel XTi / 400D Firmware
dpreview
http://www.dpreview.com/news/0704/07...os400dfirm.asp
Canon
http://www.canon.co.jp/Imaging/eosdi...irmware-e.html
firmware update (Version 1.0.5) incorporates the following fixes and improvement.:
1. Fixes the printing of lens names when using PictBridge.
2. [Redeye 1] can now be selected when connecting with specific printers.
3. Improves the reliability of communication with the Speedlite 380EX.
This firmware update applies to cameras with firmware versions up to 1.0.4 installed. If your camera's firmware is already version 1.0.5, it is not necessary to perform this update.
Canon 1D Mark II N/5D Mark III/ 6D/ 7D /85mm f1.2L Mk1/ 24-70 f2.8L/ 70-200mm f2.8L IS USM/ 100mm Macro f/2.8
Honolulu POTN
ChrisBlaze is offline   Reply With Quote
Old 17th of April 2007 (Tue)   #2
StaticThought
Male (verified)
StaticThought's Avatar
Default Re: Canon updates EOS Digital Rebel XTi / 400D Firmware
Cool, Thanks for that. Now updating
Regards
Chris
Static Thought Photography
"Static In Thought, Static In Being - You Will Know when the time comes, Grasp it and hold on for all your worth because it is Once in A Life time Chance" Have No Regrets - Chris Lee 2007
StaticThought is offline   Reply With Quote
Old 17th of April 2007 (Tue)   #3
evandavies
evandavies's Avatar
Location: Chair Room House UK Earth SOL MilkyWay Space ..?
Thanks for the links Chris.
Not much of an update tho...
I don't think I'll bother
EDIT: its true that Canon may have sneaked in some bug fixes. Even though I don't have the "exposure problem" I will update just in case there is something else in there.
E:ŹD
_____________________________
- Gallery -
= Gear =
Lens focuses the light,
camera records the light,
you make it art.
evandavies is offline   Reply With Quote
Old 17th of April 2007 (Tue)   #4
MKII
MKII's Avatar
Default 400D/XTI NEW FIRMWARE... 1.0.5
Take a look......http://web.canon.jp/Imaging/eosdigit...irmware-e.html
MKII is offline   Reply With Quote
Old 17th of April 2007 (Tue)   #5
ettlz
Just updated. No noticable difference (since I don't use direct print, it's painfully slow with my printer). First time I tried (with a CF reader) it failed with an error message in a big yellow box and I had to take out the battery. Second try with the EOS Utility worked like a charm.
ettlz is offline   Reply With Quote
Old 17th of April 2007 (Tue)   #6
Jonathan
Jonathan's Avatar
LMAO. So much fuss was being made about this on othetr boards. They had it fixing everything from under exposure to the Arab/Israeli crisis. What a non-event!
"Don't believe everything you read on the Internet" - Winston Churchill
My blog site
My Gear List
My Flickr
Jonathan is offline   Reply With Quote
Old 17th of April 2007 (Tue)   #7
fs454
Well, at least now someone can try to reverse engineer it and add features.
Gear: 5D Mark II, Carl Zeiss ZE 50mm 1.4, Sigma 20mm f/1.4, Canon 24-105L f/4 IS, Canon 50mm f/1.8 Mk1, Canon 100mm f/2.8 Macro, Rokinon 35mm f/1.4
fs454 is offline   Reply With Quote
Old 18th of April 2007 (Wed)   #8
steve maec
took only a few minutes and works fine.
steve maec is offline   Reply With Quote
Old 19th of April 2007 (Thu)   #9
Skids
Is it advisable to upgrade the firmware even if the fixes are not relevant to me in the fact that I do not use pictbridge and I do not have a 380 flash?
Skids is offline   Reply With Quote
Old 19th of April 2007 (Thu)   #10
StewartR
"your nose is too big"
StewartR's Avatar
It could be. Some manufacturers tend to slip in minor bug fixes etc. to firmware updates, but don't necessarily advertise the fact. I don't know whether Canon does this, but no doubt some of the more tech-savvy people here will.
www.LensesForHire.co.uk - complete with matching POTN discussion thread
Photos: Cats | London by day | London by night I My POTN photo sharing threads | Official "Where Am I Now?" archive
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
StewartR is offline   Reply With Quote
Old 19th of April 2007 (Thu)   #11
creel
Default EOS 400d firmware upgrade
Hi,
Canon have released an update of the firmware for the EOS 400, go tothe following link
cheers
creel is offline   Reply With Quote
Old 20th of April 2007 (Fri)   #12
gavcam
gavcam's Avatar
Yeh what he said,
Im not going to bother if the firmware only fixes those 2 things.
5DMkiii/50L/200mm F2.8L Mkii/2Xiii/24-70L F4 IS
gavcam is offline   Reply With Quote
Old 20th of April 2007 (Fri)   #13
sOid
I agree. I've read on some German forums that the 1.05 firmware might solve the underexposure problem which some 1.04 DSLR's have.
sOid is offline   Reply With Quote
Old 20th of April 2007 (Fri)   #14
Hilandor
Hi folks, i know im going to seem dumb here, is this a upgrade for the 350d, im on ver 1.0.2 and have a 380ex so could be beneficial, but dont want to bollox my camera trying in case its not.
Many thanks
Hilandor is offline   Reply With Quote
Old 20th of April 2007 (Fri)   #15
StewartR
StewartR's Avatar
No. It's only for the 400D.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon EOS 400D (Rebel XTi) Macro Lens netint Canon EOS Digital Cameras 2 17th of June 2007 (Sun) 04:33
Please help - New to SLR - Canon EOS Digital Rebel XTi/400 D frailwit Canon EOS Digital Cameras 5 24th of February 2007 (Sat) 19:24
Canon Digital Rebel XTi / Canon 400D gking Canon EOS Digital Cameras 11 20th of November 2006 (Mon) 17:14
Newbie - EOS 400D Digital Rebel XTi jay123 Canon EOS Digital Cameras 3 26th of September 2006 (Tue) 00:57
