Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Performing Arts Talk
Reply
Thread Tools Display Modes
Old 24th of April 2007 (Tue)   #1
Brandon James
Default Concert lenses...
Hey everyone,
So I am thinking that I am going to buy the 30D, which I am really excited about. Anyways, I got a position at this online magazine, Tommy2.net (more pop music based), where I will be dong photography in addition to some other things. It will be a good way to add to my very minimal portfolio.
Sooo, onto my question... I am wondering what lenses you all might suggest for concerts. he concerts will ary from clubs, to arenas, so I need something versatile. I am not sure if I can get both in one lense, but if someone can suggest some good lenses, that would be fantastic. Thanks,
-Brandon
-Brandon
http://www.flickr.com/photos/brandonsammons
Brandon James is offline   Reply With Quote
Old 24th of April 2007 (Tue)   #2
RTMiller
RTMiller's Avatar
Default Re: Concert lenses...
I guess it depends on how close you can get. The 24-70L 2.8 will work well if you can get close to the action. The 70-200L 2.8 will work well if you are further away. You just need something fast. At least 2.8.
Todd
www.PHOTODDGRAPHY.com
Equipment List
Everyone is beautiful if you squint.
RTMiller is offline   Reply With Quote
Old 24th of April 2007 (Tue)   #3
Brandon James
Yea, I can get credentials, so pretty close, thanks for the reply
-Brandon
-Brandon
Old 24th of April 2007 (Tue)   #4
EORI
EORI's Avatar
It also obviously depends on the lighting conditions at the venue. I primarily use a 70-200 2.8IS for my daughters' classical concerts, as I typically take photos from the balcony section, where I can more freely move about, albeit at a distance. Even with the lens wide open, I'm usually shooting ISO 800-1000 there.
You should read what this pro has to say about concert photography: http://photo.net/learn/concerts/mirarchi/concer_i
35 Years of Canon GEAR
EORI is offline   Reply With Quote
Old 24th of April 2007 (Tue)   #5
freakeystyley34
you'll probably want a fast prime too, maybe a 50 1.4 or 85 1.8, as some stage lighting is awful! I've found myself at 1600 at 1.8 a couple of times, just to get 1/100!
Canon 30d, 17-55 2.8 IS, 85mm 1.8, 50mm 1.4, Contax 139 and Zeiss 50mm 1.7
(semi) realistic wish-list: 10-22, 580EX.
Unrealistic wish-list: 24L, 35L, 85L, 5dmk2
freakeystyley34 is offline   Reply With Quote
Old 24th of April 2007 (Tue)   #6
gasrocks
gasrocks's Avatar
Since you can get close and are going to do clubs as well, get the efs 17-55/2.8 IS. Run your ISO up as needed.
gasrocks is offline   Reply With Quote
Old 24th of April 2007 (Tue)   #7
Brandon James
Thanks everyone
-Brandon
Old 24th of April 2007 (Tue)   #8
Brandon James
I have done some research on the efs 17-55/2.8 IS after being suggested this lense. Everything I read was good, except that it is prone to many dust problems. And that it was too expensive, and something about an L series. I am fairly new to photography, so insight from anyone would be much appreciated
-Brandon
-Brandon
Old 24th of April 2007 (Tue)   #9
René Damkot
Moderator
René Damkot's Avatar
I second the 17-55 if you are doing clubs.
If lighting is good, you might be able to get by with only zooms.
For bigger stages a 70-200 is a must IMO.
There is a FAQ in the performing Arts section
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: Canon EOS EF lenses (see exact lenses in listing) klynam Classifieds: Buy 3 11th of July 2007 (Wed) 17:20
Concert Lenses Brandon James Performing Arts Talk 7 15th of June 2007 (Fri) 14:08
lenses for portraits and concert photography? xd0nnax Performing Arts Talk 9 28th of April 2007 (Sat) 10:11
Concert Photography Lenses german Performing Arts Talk 15 26th of March 2007 (Mon) 22:11
small venue - hard rock concert - which lenses to use roundsquare1 Performing Arts 14 6th of January 2007 (Sat) 08:34
