Reply
Thread Tools Display Modes
Old 30th of April 2004 (Fri)   #1
Scottes
Trigger Man - POTN Retired
Scottes's Avatar
Default Excellent article on Teleconverters with examples
Bob Atkins over at photo.net put this one out:
http://www.photo.net/learn/optics/tc2/index.html
Also has a link to a Tamron 1.4 vs Canon 1.4 article:
http://www.photo.net/learn/optics/2tcs/index.html
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info
Finally, I have a Gallery!
Follower of Fidget - Joined the cult of HAMSTTR
Scottes is offline   Reply With Quote
Old 30th of April 2004 (Fri)   #2
PhotoSlacker
Default
Good article... great info for an amature like me
thanks.
PhotoSlacker is offline   Reply With Quote
Old 30th of April 2004 (Fri)   #3
FJC
Default
Yes, excellent article, really cleared up a lot of questions I had about using TC's, and how much they'd really affect the image quality.
I'm still a bit fuzzy (lol) about what happens with autofocusing when using these, though.
FJC is offline   Reply With Quote
Old 30th of April 2004 (Fri)   #4
billhercus
billhercus's Avatar
Default
... Ordered a Sigma EX 1.4TC (Thank goodness) yesterday for my Sigma 100-300 EX f4.
Many 'lessons' on TC's in this Forum led me to this decision. Nothing in that excellent article challenges anything I have read here - thank goodness!
7D, G1X,
EF70-200 f2.8L IS ll USM,15-85 IS,USM, Nifty 50,Canon EF x 2 lll TC, 580EX, 420EX, 270EX
Elements 11. LR4
Far too much interest in techniques, not nearly enough photographs taken!!
billhercus is offline   Reply With Quote
Old 30th of April 2004 (Fri)   #5
Scottes
Scottes's Avatar
Default
There's a couple of things that happen to AF when using TCs. (At least that I can think of right now...) And others correct me if I'm wrong...
1a) Canon TC on a DRebel/10D: If the maximum aperture is smaller than f/5.6 the camera will disable AF.
1b) One a EOS3 (?), 1D family this is changed to f/8.
1c) You can tape off a couple/few contacts on the TC to stop the camera from knowing the TC exists, so AF will still be attempted. It's not necessarily reliable, it can hunt a lot, and I've heard reports of lenses going back to Canon for service (which may or may not be related, but is suspicious, and may be due to AF motors burning out due to execessive hunting).
2a) Non-Canon TC on any lens: The TC doesn't report the existence of itself to the camera, so the camera doesn't know that it's not supposed to AF. So AF will still be attempted. It's not necessarily reliable, and it can hunt a lot.
2b) Well, at least that seems to be true about older Tamron TCs, and the exact specifics may be otherwise for newer TCs.
I *think* that's it, and I *think* that's accurate.... If nobody jumps on my case in the next day or two then it's accurate.
Edited to clarify aperture - Even though I know what I'm doing, I'm a math guy, and an aperture f/5.6 is "greater" than f/4 even though in reality f/5.6 is a smaller aperture. You know what I mean? I'm sure you do, but it is confusing, and I'll try to stop this in the future. Thanks PaulB.
Old 30th of April 2004 (Fri)   #6
FJC
Default
SO - given that, let's test my knowledge now.
If I put a Canon 1.4x TC on my 70-200mm f/4, it becomes a 98mm-280mm f/5.6 (not counting the DRebel 1.6 crop factor), and will still autofocus fine.
However, if I put a Canon 2x TC on that lens, it becomes a 140-400mm f/8 and now autofocus won't work (but manual will).
Correct?
Old 30th of April 2004 (Fri)   #7
PaulB
Default
Scottes wrote:
1a) Canon TC on a DRebel/10D: If the maximum aperture is greater than f/5.6 the camera will disable AF.
A greater aperture than f5.6 is f4 whilst f8 is a smaller aperture than f5.6.
I think that you really mean that if the effective maximum aperture of the lens + Extender (Canon) is larger or equal to f5.6 then the camera will autofocus; if the effective maximum aperture is smaller than f5.6 then a Rebel/10D will not autofocus.
Hate to be pendantic about it but if we start to mix up accepted nomenclature then no-one will really understand what we are talking about.
FJC has got it spot on though so all was not lost.
PaulB is offline   Reply With Quote
Old 30th of April 2004 (Fri)   #8
billhercus
billhercus's Avatar
Default
Just tested above Sigma 1.4 TC which arrived 5 mins ago. It is a dreich (miserable, misty) day here with poor light.
No problem autofocusing at most normal apertures tried this minute on 300D with 100-300 f4 EX HSM (Now 140-420 of course)
Paperwork that comes with this converter doesn't even mention this lens but Sigma site fortunately does.
7D, G1X,
Elements 11. LR4
Old 30th of April 2004 (Fri)   #9
Cadwell
Moderator
Cadwell's Avatar
Default
Just for clarification... the Sigma 2x and 1.4x TCs DO affect AF in the same way that the Canon units do.
So, for example, a Canon EF 70-200mm F/4L + Sigma 2x TC will yield a maximum aperture of F/8 and so this combo will NOT autofocus on a 300D/10D.
Glenn
My Pictures: Motorsport/Canoe Polo/Other Stuff
Cadwell is offline   Reply With Quote
Old 30th of April 2004 (Fri)   #10
Pekka
El General Moderator
Pekka's Avatar
Default
Has anyone tried Canon 1.4X MkII + Canon 1.4X MkII + 70-200L?
This signature signifies my significance significantly
Photo Gallery
Pekka is online now   Reply With Quote
Old 30th of April 2004 (Fri)   #11
Nigel Wallace
Default
Yes, I have a 70-200 f4 L and a canon 1.4 TC mk2 and it is in my opinion great. Autofocus no problem. i am very pleased with this combo
Nigel Wallace is offline   Reply With Quote
Old 1st of May 2004 (Sat)   #12
Cadwell
Moderator
Cadwell's Avatar
Default
Why would you want to?
200x1.4x1.4 = 392mm (lose two stops)
200x2.0 = 400mm (lose two stops)
Glenn
Old 1st of May 2004 (Sat)   #13
Pekka
Pekka's Avatar
Default
Because theoretically that would give better quality.
Photo Gallery
Old 1st of May 2004 (Sat)   #14
PacAce
Moderator
PacAce's Avatar
Default
Scott, I think you just confused yourself. f/5.6 is NOT greater than f/4 just like 1/3 is NOT greater 1/2.
...Leo
PacAce is online now   Reply With Quote
Old 1st of May 2004 (Sat)   #15
PacAce
Moderator
PacAce's Avatar
Default
Pekka, 1.4x over 2.0x might give you better quality but how do you figure that 2 1.4x combined would give you better quality (theoretically)? IMHO, I would think that the more external elements you combine together the less quality you would get. So I would think that two 1.4x combined would be of less, or at best of equal quality to that of the 2.0x. The reason being that image quality loss of lens components are cummulative. But this is just an educated guess on my part since I haven't tried either combination.
...Leo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Excellent Article on Digital Exposure petecrosta General Photography Talk 7 23rd of March 2007 (Fri) 21:16
An Excellent Article GovtLawyer Small Flash and Studio Lighting 2 31st of May 2005 (Tue) 06:24
Excellent article on reducing high-ISO noise Scottes RAW, Post Processing and Printing 13 24th of December 2004 (Fri) 11:57
About teleconverters dekadem Canon G-series Digital Cameras 2 6th of June 2003 (Fri) 14:50
Teleconverters rockdean Canon G-series Digital Cameras 0 7th of May 2003 (Wed) 21:16
