Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 5th of May 2007 (Sat)   #1
jcospolich
Default f/stops, stops, light stops, etc..
is there a linear correlation b/w stops of light, regardless of if you're adjusting ISO, f, shutter?
In other words, just talking about brightness (and not clarity, quality, sharpness)....
will each of the below brighten the image similarly (+ 2 stops of light)?
- ISO 100 to 400
- slowing shutter speed from 1/125 to 1/30
- opening aperture from F8 to F4
So taking an exposure at 1/60 f11 would be allowing the same amount of light on the sensor/film as 1/250 f5.6?
This site has always been helpful-
http://www.photonhead.com/simcam/
as has this one-
http://www.uscoles.com/fstop.htm
jcospolich is offline   Reply With Quote
Old 5th of May 2007 (Sat)   #2
jcospolich
Default Re: f/stops, stops, light stops, etc..
i am slowly beginning to understand how intertwined the settings are, and how one certainly affects the other.
for my interior flash photography, I have been struggling with finding the right settings for a nicely lit picture.
I have toyed around with the following:
- P mode, ISO 200, cloudy WB, FEC +2/3, EC +2/3, auto everyting else. camera usu chooses f4.0-4.5, 1/60
- M mode, ISO 400, cloudy WB, FEC +1, EC +1/3, f5.6-6.3, 1/125-1/200
- Av mode, ISO 200-400, cloudy WB, FEC +1, EC +2/3, f9-10, 1/13
for minimal post processing, usu the P shots, and sometimes the Av shots are okay. M shots still leave a lot to be desired. I know I can play with WB a lot more, but I think that is a subject for me to tackle after I fig out exposure better.
Old 5th of May 2007 (Sat)   #3
Digger
Digger's Avatar
you have the concept and are correct in your conversions. at this point its practice and feel. dont worry you will get the hang of it. since your using flash and in control of the light i would drop your asa some more. i personally like to use as low of an ISO that i can, less grain/noise
Digger is offline   Reply With Quote
Old 5th of May 2007 (Sat)   #4
12345Michael54321
- ISO 100 to 400
Yup. Each of the examples you offer represents a change of 2 stops.
Just in case you were wondering, that's 4 times the light. Since a 1 stop change equals twice the light. (Or half the light, if you're moving in the other direction.)
Yes. Those are equivalent exposures.
Of course, depth of field would differ from f/11 to f/5.6, so the picture might look somewhat different (or maybe not - if everything in the picture is very distant, depth of field considerations can pretty much become irrelevant). But if all you're talking about is exposure, they're the same.
Give yourself a pat on the back for understanding this. It's a fundamental concept, but one of which most people are utterly oblivious.
12345Michael54321 is offline   Reply With Quote
Old 5th of May 2007 (Sat)   #5
jcospolich
thanks it is starting to make sense. I usu prefer low ISOs, but since most of my paid workends up compressed as heck on MLS and prop websites, I don't see much of a difference with ISO200 or 800.
Old 5th of May 2007 (Sat)   #6
PhotosGuy
Moderator
PhotosGuy's Avatar
This might help:
Fill light at sunset
Here's something that will help you figure light fall-off in your head.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Filter stops light siejones Canon EF and EF-S Lenses 16 18th of January 2007 (Thu) 13:57
IS: Steady for 2 stops/ 3 stops Photolistic Canon EF and EF-S Lenses 4 12th of December 2006 (Tue) 20:01
How many stops of light are there? ijohnson General Photography Talk 45 27th of May 2006 (Sat) 04:00
What are stops? Cindi Small Compact Digitals by Canon 3 10th of May 2006 (Wed) 11:15
f-stops shutter-stops vvizard Canon EOS Digital Cameras 6 19th of November 2003 (Wed) 10:09
