Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 5th of May 2007 (Sat)   #1
ACDCROCKS
321 123 33
ACDCROCKS's Avatar
Default Flower in sun
Hey all, took this today, yes I know, the aperature, but I purposely done it at f/2.8...of course I could of done it at f/32. I think the f/2.8 version draws more attenion to the single flower in the picture...Anyone agreer or dissagree?
http://i55.photobucket.com/albums/g1...D/IMG_1976.jpg
WONKA WONKA!
ACDCROCKS is offline   Reply With Quote
Old 5th of May 2007 (Sat)   #2
strmrdr
strmrdr's Avatar
Default Re: Flower in sun
too much dead space and most of what is there is oof.
with that much dead space the object has too POP to make up for it and they dont.
ΜΟΛΩΝ ΛΑΒΕ
strmrdr is offline   Reply With Quote
Old 5th of May 2007 (Sat)   #3
Glenn NK
Glenn NK's Avatar
Some comments gained from experience:
1) It takes a lot of work to get good flower shots.
2) I use a tripod whenever possible because I can try different apertures (changing depth of field) and different ISO values (to control shutter and f/stop).
3) Look critically at the composition, and change if you aren't completely satisfied. In fact take several shots from several angles/compositions.
4) When you look at it, where does your eye rest - or does your attention keep moving around looking for the "subject"?
5) The emtpy space that "stmrdrd" commented on is a bit too dominant; if the flower was more centred the empty space wouldn't be in the competition for your attention.
The thing I really like is that the colours are simplified; pink dominates, and the greens are subordinate and support the pinks. Also your background is well out of focus - good.
If you had taken multiple shots - particularly at smaller apertures - say f/5.6 or f/8, the background may have stayed OOF, and the flowers would have popped out, being more in focus.
I started taking flower shots in the mid sixties, and I'm still not satisfied.
"Be yourself - everyone else is taken". Oscar Wilde
Glenn NK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sun flower & Ladybug beachgirl Wildlife 2 23rd of June 2007 (Sat) 21:57
Sun Flower Robo814 Wildlife 7 27th of August 2006 (Sun) 17:13
Sun & shadow flower CarolP Wildlife 6 20th of July 2006 (Thu) 08:52
Sun-flower Suedezu Wildlife 15 19th of July 2006 (Wed) 01:22
Would have called it a sun flower ... JoseC Wildlife 6 3rd of April 2005 (Sun) 15:54
