Reply
Thread Tools Display Modes
Old 14th of May 2007 (Mon)   #1
Vinni
Vinni's Avatar
Default Sigma 17-70 or Tammy 17-50?
I've got a dilemma, should I go for lens A, the Tammy, or lens B, the Sigma?
I've decided to stick to a two lens setup, if I go with the Tammy I'll get the Sigma 55-200 and if I go with the Sigma 17-70 I'll get the Sigma 70-300 DO.
The problem is whether to go with the 17-70 f/2.8-4.5 or the 17-50 f/2.8. The reach doesn't really matter to me, since I'll get it one way or another. The shots I've seen from the Sigma blow the Tammy out of the water IQ wise but the Sigma doesn't have a constant 2.8, the Tammy does.
The Tammy has a constant 2.8 but the test shots I've seen really don't look all that vivid, color-wise.
Anyone have both lenses and want to give their input? I really would like a constant 2.8 but if the lens itself is a dud I'd rather go for the f/4.5 indoors.
Vinni is offline   Reply With Quote
Old 14th of May 2007 (Mon)   #2
Big Hands
Default Re: Sigma 17-70 or Tammy 17-50?
I don't think that gap between 50mm to 70mm is of so much concern that you would need to base the purchase of your tele zoom on which wide zoom you get.
I have a hard time believing the Sigma 17-70 blows the Tamron 17-50 'out-of-the-water' because the one I tested was very sharp at f/2.8, but if you have found one that does, maybe you should get just grab it anyway.
Canon 20D w/grip, 300D, Powershot SX100 w/HF-DC1 flash, Canon 70-200 f/2.8L, 85 f/1.8, 17-55 f/2.8 IS, 50 f/1.8, 580EX and some other stuff...
Big Hands is offline   Reply With Quote
Old 14th of May 2007 (Mon)   #3
El Duderino
El Duderino's Avatar
To me, the IQ from the Tamron is slightly better. No way does the Sigma blow the Tamron out of the water.
Nikon D600 | Nikon 20mm f/2.8 AF | Nikon 24-85mm f/3.5-4.5 VR | Nikon 50mm f/1.8G | Nikon 70-300mm f/4.5-5.6 VR | Nikon 105mm f/2.8D Macro
http://500px.com/nickhenderson
El Duderino is offline   Reply With Quote
Old 14th of May 2007 (Mon)   #4
Linkzi
Linkzi's Avatar
research, research, research. Multiple samples on this forum. I went with f/2.8 all the way! Very helpful indoors.
Aloha,
Lincoln
"Be creative, don't make your photos look like everyone elses"
My Tools | Hawaiian Island Pics | Flickr | Honolulu POTN Hale (2)
Linkzi is offline   Reply With Quote
Old 14th of May 2007 (Mon)   #5
Vinni
Vinni's Avatar
Well, judging by the samples on these forums, the Sigma photographs just bleed in color -- it's astounding really.
The Tamron may be sharp, but how does it handle color?
Old 14th of May 2007 (Mon)   #6
MannP
MannP's Avatar
Why not try both in a store then decide? Like what linkzi said do a research beforehand. I don't think you'll go wrong with either lens
MannP is offline   Reply With Quote
Old 14th of May 2007 (Mon)   #7
Linkzi
Linkzi's Avatar
I have noticed my Sigma 10-20 has different contrast than the Tamron. The Sigma does have better contrast but the Tamron is sharper. PP will help both situations but again, f/2.8 indoors with a zoom is great! Don't forget to adjust the ISO. I always forget!
Aloha,
Lincoln
Old 14th of May 2007 (Mon)   #8
El Duderino
I check my ISO settings like crazy after taking half of my San Diego pictures in ISO 1600 accidentally last summer.
Old 14th of May 2007 (Mon)   #9
Tee Why
"Monkey's uncle"
Tee Why's Avatar
Tamrons have had a colder color cast, similar to Canons in my view. Sigma's color cast tends to be a bit warmer, that is what you may be seeing. This is very simply corrected by adjusting the color, so I'd consider this a trivial difference.
If it was me, I'd go with a Tamron 17-50 for it's optics and speed and then a Sigma 70-300 APO DG Macro as a two lens combo.
Good luck
Gallery: http://tomyi.smugmug.com/
Tee Why is offline   Reply With Quote
Old 15th of May 2007 (Tue)   #10
Steve in bris
Vinni
I have the Tamron and i really like it. I didn't get a chance to try the Sigma out but i thought long and hard about this lens. As a general lens i think it is really good and the colours and sharpness are both great.
The 20mm loss of reach does not bother me. i guess the final decision came down to the constant aperature that was what finally swung it i think.
Regards
Steve
Steve
Image editing ok
Steve in bris is offline   Reply With Quote
Old 15th of May 2007 (Tue)   #11
kennys350d
either way, you wont be disappointed.
Got a question..? Need some advice...? Use the search engine..
kennys350d is offline   Reply With Quote
Old 15th of May 2007 (Tue)   #12
DerekI
DerekI's Avatar
I agree the Tmaron has the edge in term of pure IQ but I think if you would like to get only one lens or your first lens , the Sigma is better and easier to use, with the lobger range and close-up.
I will have to get rid of one of them too, and I'll proabbly keep the Tamron with my Canon EF-S60(I love my EF-S60, which does not extend itself and produces great portrait, product-photos and flowers).
The Tamron is a very sharp and very very nice lens with vibrant color like the 17-40L, but the Sigma 18-50macro (not the 17-70) is also a very good lens.
If you are like me loving wheeee noisy of the Tamron, should get it , but make sure never bring it to a church , I made a big mistake once at my Church .
Canon EOS40D(2).
EF-S17-55IS,EF70-300DOISUSM,EF-S60f2.8USM, EF-S55-250IS,EF-85f1.8USM.
Nikon D300, AFS12-24, AF-S16-85VR,AF-S18-200VR, AF-S70-300VR,AF35f2D.
http://www.flickr.com/photos/izumiflowers/
DerekI is offline   Reply With Quote
Old 15th of May 2007 (Tue)   #13
DerekI
DerekI's Avatar
So Do you think which one Tamron or Sigma does have Canon-like color tone?
The Tamron has a bit warmer color in my opinion but what do you think?
Canon EOS40D(2).
Old 15th of May 2007 (Tue)   #14
DerekI
DerekI's Avatar
VEry interesting opinion and view .
Canon EOS40D(2).
Old 15th of May 2007 (Tue)   #15
Linkzi
Linkzi's Avatar
The Sigma seems to have the warmest color in my collection. More than the Canon. I'd say the Tamron is closest to the Canon in brightness and color out of the lens. With the Sigma being the warmest in colors, it is also darker in brightness than the other two. Its like the Sigma has a built in ND. A great outdoor lens. The best lens in my collection is the Canon. The "L" produces quite a bit of "pop" in color, brightness and focus. I enjoy processing those! It's all preference and you won't be disappointed in any of those. Again Post Processing will even out the playing field some.
Aloha,
Lincoln
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
help with settings on m tammy 17-50 F2.8 RLipp69 Canon EF and EF-S Lenses 3 7th of April 2007 (Sat) 11:37
Tammy 17-50 mdm Canon EF and EF-S Lenses 1 19th of March 2007 (Mon) 00:25
I can't decide Tammy 17-50 or Sigma 17-70? slyone Canon EF and EF-S Lenses 10 10th of January 2007 (Wed) 14:39
