Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 18th of May 2007 (Fri)   #1
Vincent Vega
Default Tripod thread size for 30D
Please forgive the elementary nature of this question: what thread size should I be looking for that will allow me to mount my EOS 30D on a tripod? 1/4" or 3/8"? If it makes any difference, I am looking at a Manfrotto tripod and head (probably the 055 ProB + 486RC2).
I've done a search for an answer to this, but there doesn't seem to be anything on this forum. I have also searched Canon's web site, to no avail. The manual for the camera just tells me there's a hole on the bottom of the camera for a tripod, which isn't much use!
Vincent Vega is offline   Reply With Quote
Old 18th of May 2007 (Fri)   #2
PacAce
Moderator
PacAce's Avatar
Default Re: Tripod thread size for 30D
The camera has the 1/4" thread. The larger 3/8" is most often used to mount the tripod heads to the tripod legs.
BTW, welcome to the forum.
...Leo
PacAce is online now   Reply With Quote
Old 18th of May 2007 (Fri)   #3
SkipD
SkipD's Avatar
To take Leo's reply a little further since you are in the UK - the thread sizes are U.S. (SAE) 1/4-20 and 3/8-16.
Note that these threads are NOT Whitworth threads, though there are very similar Whitworth sizes. The two thread profiles (SAE and Whitworth) are different enough to be potentially problematic under load.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 18th of May 2007 (Fri)   #4
Vincent Vega
Thank you! Most appreciated.
Old 18th of May 2007 (Fri)   #5
René Damkot
Moderator
René Damkot's Avatar
Then again, when getting a 486RC2, you'ld be using the RC2 plate to connect camera to ballhead, and AFAIK, they only come in the correct 1/4" size...
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 20th of May 2007 (Sun)   #6
DavidW
There are RC2 plates (both standard and the 'architectural' anti-twist versions that I prefer) with 3/8" screws - though they're not common. The plates included with heads and the like have 1/4" screws.
David
DavidW is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Quarter inch in metric?(thread size for tripod mount) perfect_pixel Accessories & Storage 23 10th of April 2007 (Tue) 16:42
What thread size should I use for my tripod + head, 1/4 or 3/8? Leorooster Accessories & Storage 2 23rd of February 2007 (Fri) 12:04
thread size difference Albert Harrison, Jr. Accessories & Storage 4 8th of April 2006 (Sat) 21:00
Canon Tripod Mount thread size? jukas Canon EOS Digital Cameras 2 6th of April 2005 (Wed) 11:45
what is thread size of... CornMonkey Canon G-series Digital Cameras 2 24th of May 2002 (Fri) 17:44
