Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 18th of May 2007 (Fri)   #1
miller00
Default I really need help. [focusing]
Hey guys,
I'm going crazy here. First off I have a Canon DSLR 30D and I was using the 24-70 Canon L lens. A lot of my pictures seem to not be focused right. I always focus on the person's eyes and yet it seems like a lot of times the person isn't in focused. I.E. Exposure time: 0.0100 s (1/100) Aperture: f/7.1 ISO equiv.: 100 Flash used. It's just weird because I Know I focused on her eyes yet it seems like the block below her is more in focus. Also my pictures seem So gross at 100% crop I want to show you an example but other times they are okay like this one,This picuture is a lot closer up, does that make a difference? Exposure time: 0.0080 s (1/125)Aperture: f/3.5 ISO equiv.: 100 Flash used. Any help would be amazing! Thank you.
miller00 is offline   Reply With Quote
Old 19th of May 2007 (Sat)   #2
VegasGeorge
VegasGeorge's Avatar
Location: I live in Siena, a Summerlin village in the SW area of Las Vegas valley, Clark County, Nevada USA
Default Re: I really need help. [focusing]
Well, no matter what lens you use, assuming the focus is correct, closer means sharper, i.e. more detail. It's real hard to tell what's going on with your first shot. The uploaded image is so small that its almost impossible to judge the focus, and it pixelates at once if I zoom in on it. As it is, nothing really looks to be in critical focus, and I know that's wrong. Something in the image is bound to be in focus! Could you post a bigger image somewhere and give us a link to it?
A B&W guy in an RGB world!
NRA Life Member
Member USCCA
GOA Life Member
VegasGeorge.com
VegasGeorge is offline   Reply With Quote
Old 19th of May 2007 (Sat)   #3
Wildewinds
If you haven't done this already... Turn off the 9 or 11 point autofocus and only use the center focus spot. Aim at what you want in focus, focus (half press of button), frame the shot, then shoot.
- 20D - Tamron 28-75mm f/2.8 - Tokina 11-16mm f/2.8 - Canon EF 50mm f/1.4 -
Wildewinds is offline   Reply With Quote
Old 19th of May 2007 (Sat)   #4
miller00
Here are bigger versions of pictures http://millert.multiply.com/photos/album/14
Old 19th of May 2007 (Sat)   #5
tdodd
tdodd's Avatar
Miller, I've been looking at your photos and also found your old thread here http://photography-on-the.net/forum/...d.php?t=228995 with similar problems but with a different body and lens so I'm really struggling to see how you are getting such disappointing results even with a complete equipment change.
Even with the larger pictures in your post above I still can't figure out where the problem lays. To be honest it might help to see the original photographs, complete with Exif data intact. One thought does spring to mind - are you shooting raw and then converting to jpeg without sharpening? Or are you shooting your photos in small jpeg mode in the first place or something like that? What is your workflow for getting the photos onto the web from the originals?
tdodd is online now   Reply With Quote
Old 19th of May 2007 (Sat)   #6
tdodd
tdodd's Avatar
Another approach, if it's hard to conclude much about your technique, is to check out your equipment to see how good the focusing is. Here are three images shot with my 30D and 17-85 at 85mm and F5.6 with different focus points selected. They are presented as a single screen print within Zoombrowser, showing all three pictures at once with the respective focus points highlighted...
http://picasaweb.google.com/EezyTige...15686412878850
The shots were taken simply by lying on a carpeted floor and firing off the three shots at a very low angle (camera body roughly supported about 4-5" off the floor) to illustrate the depth of field and where the focus ended up in relation to the focus point indicators in the viewfinder. I think I have a pretty strong correlation between the intended point of focus and where focus actually occurred. If you were to repeat a similar exercise you may find your camera/lens is not focusing where it should.
Old 19th of May 2007 (Sat)   #7
Benji
This may sound dumb, but after you press the shutter button and it locks the focus on her eyes, are you SURE you are continuing to hold the shutter button down 1/2 way while you recompose the shot? If you release it, it will refocus on whatever is inside the little red square when you again press the shutter button and the shot may be OOF.
benji
Benji is offline   Reply With Quote
Old 19th of May 2007 (Sat)   #8
zacker
zacker's Avatar
not to mention the shots look a tad under exposed too boot. I did a lens focus test when i first started out with a dslr and thought all my len.ses sucked...turns out, i did...lol the next time i used my flash and had some better lighting and exposure and it made all the difference in the world
zacker is offline   Reply With Quote
Old 19th of May 2007 (Sat)   #9
PeaPicker
in the twilight zone
PeaPicker's Avatar
I never could consistently get a really sharp shot by focusing then recomposing.
I learned from RAitch to shoot once I get focus.
I usually half press several times and then shoot.
Sniper stile, take a breath and exhale half way.
My 2 cents
Jon / 40D / Pics
PeaPicker is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #10
miller00
Tdodd- I shoot Large Jpeg..I just uploaded this particular picture to my computer..resized it I think 700x..1000 or so...and saved it. I put the originals on my multiply site so you can look there. I am just getting really frustrated as I can't seem to get sharp pictures at all. To the person who was asking about Exif date, what else do you need besides shutter speed apeture and Iso?
Old 21st of May 2007 (Mon)   #11
tdodd
tdodd's Avatar
Miller, I'm not sure if I can help you. The pictures you have uploaded to the Multiply site are not the originals - you have resized them! I don't know whether you have performed any other edits like tweaking levels/curves or cropping/straightening or whether you've tried to add any sharpening. I also have no idea what sharpening parameters were set in the camera when you tookk the picture in the first place.
If all you've done is to resize the pictures with no other edits then at least we have a fair idea of what we are dealing with but I still don't know exactly what the original picture looked like. Are you aware that each time you save a jpeg you lose a little image quality? So if you opened the original and played around with it a bit and then saved it the quality will reduce a little (unless you're using Picasa or Lightroom for your editing). If you then open it again, fiddle a bit more and save it again you will lose a little bit more quality. If you are editing your original file (rather than a copy) you will be slowly destroying the original quality in your photo. When you save the photo you have an option for a quality or compression setting for your jpeg. The lower this is set the more quality you lose. I have no idea what quality setting you used when you saved the downsized image, or if you performed any edit/save operations before downsizing. So basically, without the original photograph it is impossible (for me) to judge just how good/bad the picture was out of the camera.
Even if you have not damaged the quality by multiple edit/save operations the final file size on your web images shows that a fair amount of compression has been used so that is certainly lowering the final image quality. The original Large/Fine jpeg from a 30D should be 3MB-4MB roughly, depending upon what the subject matter is in the image, but the photos on your website range from just 153KB-206KB. So you are asking us to judge the images based on about 7% of the data in the ORIGINAL photo.
I also don't know how you are downsizing - what software are you using? Are you sharpening in concert with the downsizing, because conventional wisdom is that you need to apply sharpening when downsizing, but you don't mention that.
So with all the above in mind I have no idea, from your little 150-200KB files why you might be suffering poor image quality. Having said all that, one of the pictures actually does look pretty sharp - the second one, image_0525. But in this photo the face, teeth and motiff on her top all look brighter and it seems as though you may have used flash for that photo but not the others. Also the white patches on the wall look brighter in that photo and seem sharper too. Did you use flash for all the photos or just the one?
How are you focusing? Which focus point are you using? Are you using focus/recompose? Are you using One Shot, AI Focus, AI Servo focus or manual? How steady are you when focusing - do you sway back and forth a little? How carefully are you squeezing the shutter - do you stab at it or squeeze carefully and slowly?
Anyway, I'm afraid I don't have the skills to conclude where your problem lies based on these downsized, shrunken photos with all exif data missing (including focus point data). If you could place the UNEDITED originals somewhere and tell us a bit more about your technique then I will happily take another look. If you've already edited them then is it too late to copy the originals from your card?
By the way, I'm no expert on all this, just learning myself, but in trying to help others I hope I am improving my own knowledge. Maybe the originals won't tell me any more than your web copies but I'd rather eliminate as many reasons for doubt/confusion as possible.
Old 21st of May 2007 (Mon)   #12
zacker
zacker's Avatar
tess, i went to your site...in the pics, i can clearly see the stry hairs on the models head... the pics arent that bad off.... next time, try it with a tripod and if you have a hotshoe flash... use it.. put in hispeed mode and your shutter speed should go to 1/250 and use AV mode and start off at f8 and do a test pic and using your histogram on the back... adjust just the Aperture either up or down to get it perfect...do not adjust the shutterspeed unless you cant get the bg exposed.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Focusing Baddrummerboyy Canon EOS Digital Cameras 2 2nd of November 2006 (Thu) 03:30
S2 IS help for focusing acpsiddhartha Small Compact Digitals by Canon 7 11th of July 2006 (Tue) 12:19
Still not focusing well SezzySue Canon EOS Digital Cameras 14 8th of May 2006 (Mon) 16:05
Little help on focusing flam79 Canon EF and EF-S Lenses 6 8th of May 2005 (Sun) 11:20
focusing cat4g3 Canon G-series Digital Cameras 3 8th of August 2004 (Sun) 20:41
