Reply
Thread Tools Display Modes
Old 21st of May 2007 (Mon)   #1
slyone
Default Affordable Super-Telephoto lens?
Hi everyone! I'm thinking my next lens needs to be 400. I do have the 70x200 with a 1.4tc but thinking that will be too short for HS soccer......I guess it shall be my "summer lens" only. Of course as always, I do (as most) value IQ immensely. What kind of lens does others use for this type of shooting? TIA!
40D, 70-200 f/2.8L, Tamron17-50mm f/2.8 XR Di-II, EX-580,Canon 1.4tc
slyone is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #2
Mr. Clean
Mr. Clean's Avatar
Default Re: Affordable Super-Telephoto lens?
at 400mm?
The Sigma 120-300 would be great, and 400mm 5.6, 100-400, 300mm 2.8, really depends on how much you want to spend. If you have a fairly unlimited budget I'd go for the 120-300 or 300mm 2.8 IS.
Mike
some shots @ Zenfolio
Mr. Clean is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #3
sonnyc
Affordable 400mm? I don't think there's one
How about the 300/f4 IS with 1.4x ?
Sonny
www.sonnycao.com|Gear List
sonnyc is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #4
runninmann
what the heck do I know?
runninmann's Avatar
The sometimes maligned Sigma 170-500 is less than $800 USD in the US.
runninmann is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #5
crn3371
crn3371's Avatar
The most affordable lens to give you 400mm reach would probably be the Tokina 80-400 for about $650.
crn3371 is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #6
runninmann
runninmann's Avatar
Good one! The Tamron 200-500, at a couple of hundred more than the Toki, is also well thought of.
Old 21st of May 2007 (Mon)   #7
angryhampster
"Got a thick monopod?"
angryhampster's Avatar
What does affordable mean?
It's a fairly subjective term.
angryhampster is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #8
runninmann
runninmann's Avatar
True. But the ones mentioned so far are among the most affordable that can reasonably be expected to provide generally acceptable results.
Old 21st of May 2007 (Mon)   #9
WMS
"Escargot on the Hoof"
WMS's Avatar
Location: California, the land of the politicaly corrupt and innept
how about a $125.00 or so mirror cat lens? Not terribly fast usually around an f8, manual focus they can be a bit soft especially in close, but for the price...
http://www.adorama.com/SY5008EOS.html
WMS
I'm just a simple maker of love charms and tokens,who occasionally takes a picture or two.
Gear list: more toys than I need, Fewer than I want.
WMS is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #10
slyone
Thanks for all the great ideas! Affordable= less than a grand, 5,6,700.00 would be better yet.....as far as FL, I just figured the further reach..the better? I do want VG IQ though as well as a descent build. I suppose...as others too, we start with all the possibilities and then just try to eventually "narrow it down" to an acceptable result/product.
Old 21st of May 2007 (Mon)   #11
MikeI
MikeI's Avatar
A used 400 f/5.6 L. You can find them for around $900 used. That is next on my list....
MikeI is offline   Reply With Quote
Old 21st of May 2007 (Mon)   #12
Tapeman
Sliced Bread
Tapeman's Avatar
Save for the 400 5.6L. Good quality and good value.
Canon 1D MKIV, 5D MKII, 16-35/2.8L II, 24-105/4L, 70-200/2.8L IS II, IS, 500/4 L IS II, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, & 2X MKIII, (2) 550EXs, ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880
Tapeman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If f/2.8 Lens was affordable..... petrolhead Canon EF and EF-S Lenses 53 23rd of November 2007 (Fri) 20:29
Need help picking a Super Telephoto Lens Blue-J Canon EF and EF-S Lenses 34 27th of January 2007 (Sat) 00:53
Should I go super-wide or zoom telephoto next? angryhampster Canon EF and EF-S Lenses 11 9th of September 2006 (Sat) 11:49
Vivitar 600-1000 (~2000mm) Super Telephoto Lens VegasGeorge Canon EF and EF-S Lenses 8 23rd of September 2005 (Fri) 19:09
650-1300 f8.0 super telephoto lens...... latigid soe Canon EF and EF-S Lenses 15 11th of August 2004 (Wed) 02:57
