Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 22nd of May 2007 (Tue)   #1
nikkirocks
Default Product Reflection
Hi Everyone,
I'm having a little problem with photographing a product. I'm shooting the product on glass to get its reflection, but it seems to creat a double(ghost) reflect. Now I've seen a couple example in this forum, where the reflection is so clean a crisp.
So if you have any tips or suggestions it would be a great help.
THANKS
NIKKI
nikkirocks is offline   Reply With Quote
Old 22nd of May 2007 (Tue)   #2
bzride
bzride's Avatar
Default Re: Product Reflection
maybe it's the type of glass your using?? or the lighting set-up??
bzride is offline   Reply With Quote
Old 22nd of May 2007 (Tue)   #3
RiveraRa
RiveraRa's Avatar
My guess is that the glass is to thick. You are getting a reflection off the top of the glass and the bottom of the glass. While I dont know the best thickness to use I would def. try something a little thinner.
Canon Rebel XT
Canon EF-S 18-55mm lens
Nifty
RiveraRa is offline   Reply With Quote
Old 22nd of May 2007 (Tue)   #4
TSEE
TSEE's Avatar
Have you looked into Plexiglass, I took some baby shots using a piece of plexiglass (big piece I might add), check it out: http://photography-on-the.net/forum/...d.php?t=318905
Or just try a thinner piece of glass like RiveraRa suggested.
-Sue (TSEE)
My gear list finally got too long to list under my sig.
"All of us have photographic memory, some of us just don't have film."
"I hate cameras. They are so much more sure than I am about everything."
TSEE is offline   Reply With Quote
Old 22nd of May 2007 (Tue)   #5
sfaust
sfaust's Avatar
The glass is too thick as mentioned, or has something sandwiched between it (like safety glass). For all reflection shots, I use a think piece of plexiglass. Make sure its perfect if you want a good clean crisp reflection. Any scratches, even little ones, soften the reflection.
Here are a few examples of shots with pelxiglass.
Black plexi
This one was shot on a thick piece of glass. You can see the reflection isn't as sharp.
And this one was shot on a reflective piece of poster board. A whole different look for the reflection.
Stephen
Commercial Photography
My Photography Blog
sfaust is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What is the name for this product? Lin-z Weddings and Other Family Events 20 29th of September 2006 (Fri) 22:46
product Goran Katic Critique Corner 3 1st of July 2006 (Sat) 21:41
Product/Catalog Photography: Reflection Issues parnola Still Life, B/W & Experimental 5 24th of April 2006 (Mon) 05:41
anyone here use this product? summerwind4 Accessories & Storage 6 20th of July 2005 (Wed) 08:16
Does anyone use this or know about this product morenoar Canon EOS Digital Cameras 13 18th of December 2003 (Thu) 11:02
