FORUMS Canon Cameras, Lenses & Accessories Small Compact Digitals by Canon
Thread started 13 May 2004 (Thursday) 21:54
A70 - Indoor Pics Too Dark
Beretta
Joined May 2004
May 13, 2004 21:54 |  #1
I'm new to this forum, so I don't know if this topic has been addressed?
I really like my A70 which I have had for 5 months now. Takes great pics, which I generally take at 2mb. However, most of my indoor shots are just too dark, and I have to lighten them with software. I am taking the pics in the Auto mode, and the flash is being used on each of these pics. I admit I have not tried any other mode, but can anyone help me with this issue??? I would rather not have to lighten my pics, as I lose the pics embedded info, as well as swelling the file size immensely.
HELP!!!! ?!
Thanks!
Penguin_101_1
Joined Feb 2004
May 14, 2004 05:53 |  #2
If you don't want to go into manual mode:
Make sure you have a good amount of light in the room and then the pics will come out brighter.
If you do want to go into manual mode:
Go to Tv mode. You are going to make sure the flash is on and set the shutter speed at 1/60. For me that is the longest exposure I can take without it being blurry. If you do or don't have steddy hands then you can give or take the shutter speed. If you want to go even lower then I would use a tripod. Before you try this at a big event that you will always want the pictures I would pratice.
I hope this helps!
stopbath
Joined Jul 2003
May 14, 2004 06:12 |  #3
Without samples of photos it's hard to tell if there is a problem and what the solution may be...
That being, AUTO on the camera should work for most instances. May not have the artistic results you desire, but you should get a properly exposed picture if one can be made by the camera.
The flash on the A70 is not powerful. It does have a limited range.
All light looses intensity as it disperses, therefore the light hitting a subject at 3 feet is much more intense than it would be if the same light hit a subject at 9 feet. To expose the subject at 9 feet, more flash output is needed. I think the maximum is 14 feet (check the manual to be sure) and that is likely at ISO 400.
If your backgrounds are dark, that is the nature of using one flash. You will need more room light, or a longer exposure to help pick up the back lighting (there is a mode for this on the a70)
If your subject itself is too dark (on auto) then the distance is too great.
There is also a chance that the flash is under performing, and needs repair (not likely but possible.)
mvrekum
Joined Jan 2004
May 17, 2004 06:00 |  #4
Another, easier thing you can do is set the mode to "P" and set the exposure compensation ("func." and the the first menu item) to a positive value.
Try playing arround with the values. + is brighter images, - is darker images.
And yes, a few samples would be nice. :)
Good luck,
Martin
www.martinvanrekum.com (external link)
EOS 350D :: EOS 5 :: Powershot A70
EF 24-70 L :: EF 70-200 L IS :: EF 28-105 :: EF 100/2.0 :: EF 75-300
580EX :: 420EX :: 540EZ + Transistorpack E
Beretta
Joined May 2004
May 23, 2004 20:53 |  #5
Thanks for your tips! I'll try and post a couple of examples. Any & all advice is certainly welcome!
Beretta :o
bigggt
Joined May 2004
May 29, 2004 18:46 |  #6
HI Beretta
I just got an A75 and would like to know how you get 2mb pics ,i have mine on th e highest setting(i think) and can only get 1.5
Sorry if this is a stupid question but this is my first digital camera
Thanx
dshah
Joined Jul 2003
Jun 13, 2004 13:38 |  #7
SPAM PUT AWAY
This post is marked as spam.
rogersks
1 post
Nov 15, 2005 19:50 |  #8
I seem to be having the same problems.
Before, flash pictures came out just fine (I'm not concerned with color, I'm colorblind). I certainly felt that they were fine to me.
Suddenly, it seems that no matter which mode I shot in, no matter what distance from subject that I am, indoor pictures are always too dark to view.
Seems to work fine for me outdoors. Just indoors is a problem.
It is almost as if the flash and shutter are out of sync.
Any ideas?
megaweb
Joined Sep 2003
Nov 15, 2005 21:22 as a reply to  @ rogersks's post |  #9
Use a slave flash and Manual mode on A70. It works flawlessly.
See my article at http://megaweb.clubsna​p.org/articles/a70_sla​ve/ (external link)
4,936 views & 0 likes for this thread
Latest registered member is DouglasAZ
698 guests, 374 members online
