Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 26th of May 2007 (Sat)   #1
neilswood
Default Rugby league local derby shots
Difficult light as it was played in the evening with some harsh shadows. Did my best though C&C is always appreciated.
Thanks for looking
Neil
Canon 30D Main body, Canon D30 Spare body, Canon 50mm f1.8 Mark II, Canon 70-200mm f4 L, Canon 300mm f4 IS L, Sigma 20-40mm f2.8
www.blackpoolstanley.tk
neilswood is offline   Reply With Quote
Old 27th of May 2007 (Sun)   #2
c3p1
c3p1's Avatar
Default Re: Rugby league local derby shots
Wow, I like them very much! The expression is no.1 is great. I also like the fans/coaches on the sideline and their anticipation!
Number 2-4 really show how tough the sport really is! Great captures on the action!
Paul
Thanks, Paul
Canon 60D
Sigma 10-20mm f4-5.6, Canon 85MM 1.8, Tamron 28-75mm f/2.8 xr di, Sigma 70-200mm, Sigma 30mm 1.4, Canon 50mm 1.8
c3p1 is offline   Reply With Quote
Old 27th of May 2007 (Sun)   #3
Big Hands
The captures really are excellent as far as the action goes, however I do have a couple of technical suggestions.
Two things:
1) If possible, instead of fighting the sunlight and apologizing for it, try to embrace and make it work for you by getting it behind you to keep harsh shadows minimized. Then tech issues won't have to be explained, you can just use your skill as a photographer to compose.
2) I see this in photos (but especially in sports photos) taken with the 20D and 30D quite often and I'm tuned into it because I struggled with it myself much more than I do now.
Your camera is only capable of displaying a finite number of steps of dynamic range (from light to dark) of exposure. I've heard 9 quoted as the number of steps that the 20D/30D is blessed with, so that's not a lot. The ideal camera would have many more steps of dynamic range.
If you have a lot of photos where there are blown highlights and areas of dark shadows where the detail is also lost, your in-camera contrast is set too HIGH. You are giving away at least two of those valuable steps of detail from both ends of the spectrum at the same time. Ideally, if you set your exposure too high, you should not also have areas of lost shadow detail and vice-versa. You should be able to adjust it to a happy medium using exposure compensation or at the very least, eliminate either blown highlights OR lost shadow details.
By using a custom 'parameter' setting, you can keep the other settings where you like them and lower the contrast setting. Much to my own surprise, I get the best results from my 20D by having the contrast set at "-1". This will make those steps closer together if you will, which means more differentiation where you can see it instead of larger steps which include blown highlights and lost shadow detail in the same shot.
I may still get some lost shadow detail if there just isn't enough light, but it usually isn't accompanied by blown highlights. In your case, I think you would stil have some dark shadow areas, but this would have left more detail in the brightest areas of your shots.
I hope I've explained this so it can be understood, but at any rate, try lowering the contrast setting in-camera and see if you don't think it helps with this.
Regards,
Jeff
Canon 20D w/grip, 300D, Powershot SX100 w/HF-DC1 flash, Canon 70-200 f/2.8L, 85 f/1.8, 17-55 f/2.8 IS, 50 f/1.8, 580EX and some other stuff...
Big Hands is offline   Reply With Quote
Old 28th of May 2007 (Mon)   #4
neilswood
c3p1
Thanks for your comments, glad you liked them. Looking forward to the summers league now, lots more big hits and break away tries!
Big Hands
Thanks for you comments and advice, shows why this forum is so useful.
1. I normally would have given the sideline a go, probably walking up and down with my 70-200mm but they were packed with supporters (see #1) so would have been taking back of the head shots probably.
2. Thanks for the advice about the contrast, I'll definitely give that a go at the next game I do and post the results up here. I can't remember a more difficult game I've covered due to harsh light and shadows. Living in the north of England I'm normally more concerned with bad light and rain! Roll on the summer league.
Again, thanks both for your comments, much appreciated.
Neil
Old 28th of May 2007 (Mon)   #5
jim9449
Good action shots neilswood, Jeffs comment is very good,
Jeff, I am intrested in your comment about shadows and highlights, just got a 30D. By using a custom 'parameter' setting, is that the picture style in the menu? (User Def.)
EOS 1DmkIIn, 40D +grip , EF 70-200 f2.8L IS - EF 17-40 f4 L Sigma 120-300 f2.8, Canon 580EX 11, Kenko 1.4x
jim9449 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Couple of shots from rugby league neilswood Sports 5 18th of June 2007 (Mon) 12:34
Weekend Local Rugby League - C&C PLEASE! butcha27 Sports 15 8th of April 2007 (Sun) 06:27
Local Rugby League Buttkicker Sports 5 6th of November 2005 (Sun) 03:29
NRL rugby league shots Action shots and Cheerleaders byso Sports 17 31st of October 2005 (Mon) 01:05
NRL rugby league shots byso Sports 8 12th of April 2005 (Tue) 03:14
