Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 26th of May 2007 (Sat)   #1
pigtailpat
Default 1st time w/ extender 1.4 (baseball)
Today was the first time using the extender 1.4 with the 70-200 f/2.8. I used 500 ISO - game was 9 am - even at 9 am - the extender does cut some of the light down and autofocus was a bit slower - and some of the shots did come out a bit darker (not these posted below).
Now do you see any softness of any of these (degradation of image quality due to extender?)
Re: underexposure - what's the remedy - higher ISO? (I can post the darker shots separately if necessary).
1D-IIN, 30D, sigma 120-300, 24-105 IS f4 L, 70-200 IS f2.8 L, 50 1.4, 580 EX, Bogen 680B/3229
pigtailpat is offline   Reply With Quote
Old 26th of May 2007 (Sat)   #2
GyRob
Default Re: 1st time w/ extender 1.4 (baseball)
They look very good to me and for 500iso i dont thik you could get better.
Remedy for under exsposuer is slower shutter speed or wider apeture or higher iso or a bit of all of them.
Rob.
GyRob is offline   Reply With Quote
Old 26th of May 2007 (Sat)   #3
Sledhed
Sledhed's Avatar
They were shot at f9 and f10, open that lens up. That will let more light in and help with the bg blur. I usually overexpose a little to help with the cap bill shadows. There's no problem with the 1.4 on a 70-200, in my experience it doesn't affect IQ at all.
Chris
Gear List | Website | Sports Sample Pictures | Four Seam Images
If you’re good at something, never do it for free. - The Joker
Sledhed is offline   Reply With Quote
Old 26th of May 2007 (Sat)   #4
pigtailpat
Sledhed -
most of these were shot at shutter priority (I think maybe 1 was shot at aperture priority). In the earlier portions of the game, I did shoot at a slower shutter (I think it was 1250) then moved that up - and it was my memory that most, if not all, of the darker shots were at higher (faster) shutter priority, but at 500 iso. Would moving up the ISO in shutter priority give me a wider aperture for less underexposed shots?
I realize that composition of the shots posted were off because of feet being cut off etc. I'm still getting used to the 70-200 on a monopod, and now adding the extender. I'm starting to get a bit of the feel of the thing. I'm still not totally concentrating on composition, I feel lucky if I got sharp shots and the camera/monopod hasn't fallen out of my hands ))))::
Thanks.
Old 26th of May 2007 (Sat)   #5
Sledhed
Sledhed's Avatar
Use aperture priority and it set to f4 (with your TC, 2.8 without) and adjust your ISO to get the shutter speed you want. Try shooting in portrait orientation some too.
Chris
Old 26th of May 2007 (Sat)   #6
dekalbSTEEL
dekalbSTEEL's Avatar
are you shooting RAW?
Grippy 30D, Tokina 300f4, Sigma 18-50f2.8, Canon 70-200f4L, thrifty50mkI, PM7500DX
dekalbSTEEL is offline   Reply With Quote
Old 26th of May 2007 (Sat)   #7
bieber
bieber's Avatar
If it's underexposing in an auto exposure mode, then you need to turn the exposure comp up. Those white uniforms are probably throwing the meter off a little. When doing sports, I tend to put it in manual, find an exposure that works for me, and then leave it there, assuming nothing major changes. That way you don't have to worry about a metering foul-up ruining that one great shot (nothing's more sickening than squeezing the button, expecting a great shot, and then hearing two very distinct, separate clicks from the shutter curtains dropping too far apart).
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery
bieber is offline   Reply With Quote
Old 26th of May 2007 (Sat)   #8
pigtailpat
I plan to eventually show RAW ( so thatexposure can be adjusted from RAW). Right now, I have SO MUCH new stuff to deal with, that I just cannot handle another new thing for a while. I realize I have to shoot RAW eventually.
Old 26th of May 2007 (Sat)   #9
dekalbSTEEL
no time like the present! It's not any harder, and Canon's DPP that came with your camera is fairly simple to learn. Especially when you can always revert back to the original shot settings and start over.
Old 26th of May 2007 (Sat)   #10
bieber
bieber's Avatar
I don't know how much faster the 30D buffers than the 20D, but I always shoot sports in JPEG, and everything else in RAW. I just can't stand being limited to bursts of six frames or less...
My Gallery
Old 26th of May 2007 (Sat)   #11
MDJAK
...the definition of a noob
MDJAK's Avatar
Don't worry about the bursts. I think you'll find most shooters rarely use it, except maybe for a fast, bang, bang play, perhaps a steal at second, etc. The shots you're showing of batters requires timing more than burst speed.
Shooting RAW gives you much more latitude to fix exposure and is no more difficult or time consuming to work in once you learn it.
Good work.
mark
MDJAK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1st Attempt Baseball Home Plate Remote gromeo Sports 3 27th of May 2007 (Sun) 23:46
its baseball time lilmill Sports 2 5th of April 2007 (Thu) 20:40
1st Baseball shooting - Double Play dbett Sports 0 24th of September 2006 (Sun) 14:03
Baseball - first time bcap Sports 16 11th of August 2006 (Fri) 22:54
Baseball 1st post Miner Sports 9 2nd of May 2006 (Tue) 16:22
