Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 27th of May 2007 (Sun)   #1
burge
Default Portbale small light & background unit - very small budget!
I'm keen to try some product photography and the like and want to have a small setup in my garage. It need to be collapsable so I can move it out the way and would also therefore be portable.
I've been looking around for some DIY ideas and as well as the DIY lightbox thread on POTN I've found this:
http://www.diyphotography.net/homest...backdrop-stand
I like the idea of the halogen lights being attached to the stand itself. I was going to modify and rather than it just holding the backdrop I was going to give it a 3D effect thus giving me the ability to mount lights coming in from the side onto the subject and possibly even front lighting. I will make it so the lights can be moved around on the pipework
One of the main concerns is by using the halogen style lights will the light be too harsh as no diffuser is being used?
This setup would give me the option to photography larger object than with a lightbox and would be more storage friendly.
Am I going to be wasting my time here or will it work?
Thanks in advance.
Body: Canon 40D w/grip, Canon 400D w/BG-E3 Grip. Glass: Canon 70-200mm f4 L , Canon 50mm f1.8, Tamron 17-50mm f2.8. Flash: Canon 580exII, Canon 430ex. Accessories: Pocket Wizard Mini TT1 and Flex TT5.
burge is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Setting Up a Small In-Home Studio on a Large Budget DwightMcCann Small Flash and Studio Lighting 289 7th of July 2012 (Sat) 18:02
Small flash unit options for 5D? JohnWolf Small Flash and Studio Lighting 6 1st of October 2006 (Sun) 13:26
Looking for a small flash unit for Canon 5D msvirick Small Flash and Studio Lighting 4 8th of August 2006 (Tue) 19:10
On a small budget.. ArenGh Small Flash and Studio Lighting 3 29th of July 2006 (Sat) 15:22
Setting up a small studio on a budget tonytony Small Flash and Studio Lighting 18 30th of June 2005 (Thu) 01:37
