#1 |
Hello all, i just got an XTi about 2-3 weeks ago. I've been noticing my images being under exposed. I've heard the XTi having that problem. what can i do about it?
I was thinking returning the XTi and biting the bullet and getting the 30D. I rather not spend the money for something I use as a weekend hobby. What do you guys think? Thank you! |
| sponsored links |
#2 |
I think you can get the 20D for the same price as the XTi. That would be my suggestion.
_____________________________________________ Dave 50D & 20D w/grips, 17-40L, 28-135IS, 85 1.8, 70-200 2.8L, 100-400ISL, Elan 7N w/grip, 580 EX, 550 EX and lots of other fun stuff........ |
#3 |
You can either shoot raw and fix the exposure there, or just set dial the exposure up 1/3-1 stop.
EOS 5D MIII | 24-70 F2.8L | 70-200 F2.8L IS II | 35 F1.4L | 85 F1.2L II | [size=1]135 F2L | 16-35 F2.8 F2L II | 100 F2.8 Macro | Sigma 15-30 | 580EX II |
| sponsored links |
#4 |
#5 |
What exactly is raw?
I can't adjust the exposure in AUTO mode right? I've trying to compensate the exposure in P. is that correct? I have so many questions, I'll start with this one for now! |
#6 | |
I apologize as I don't know the control differences between the 5D and the XTi. If you shoot in Av or Tv you can set the exposure. And with M you can effectively do the same thing. As for "what is raw", http://en.wikipedia.org/wiki/RAW_image_format I shoot in RAW for better control of the photos, since I don't get exposure and white balance correct all the time.
#7 |
The XTi is a fine camera. Mine does not have the exposure problem. I do get some under-exposed and some over-exposed images which are easily fixed in photoshop. I would have bought the 30D, but the XTi was in my price range and I'm very happy with it.
I have no idea what your experience in the DSLR world is, but proper exposure is a skill that takes time. At least it did with me. Good luck!
6D, 60D, Various L and non-L Lenses and more gear than I have time to use. |
#8 |
"your nose is too big"
chairmnofthboard, most exposure problems are caused by the user rather than by the camera. Or, more precisely, by the user not knowing how the camera will react in any given situation and therefore not knowing when to trust the camera and when not to. Obviously this is a skill that takes some time to pick up!
The single best way to start to get a grip on exposure is to get a copy of Bryan Peterson's book "Understanding Exposure", and read it carefully. Many people here recommend it and with good reason. It's not expensive, highly readable, and enormously helpful. Other than that, I suggest posting a coule of pictures that you took and which you think are underexposed. Then the experts here will be able to see whether it is your camera or your technique.
www.LensesForHire.co.uk - complete with matching POTN discussion thread Photos: Cats | London by day | London by night I My POTN photo sharing threads | Official "Where Am I Now?" archive Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4 |
#9 |
"Fix the cigarette lighter"
Location: West Michigan--166.33 miles to the Cook County courthouse
Had the same problem but had an XT and a 1d hanging around for a direct back to back comparison so I knew the problem was in the camera.
I have to disagree with some of the people here--exposure compensation and RAW should not be required to compensate for a possible defective product. Here is an example of a shot in program mode before my XTI was sent to Canon service and after Hope this helps and welcome to the forum.
Middle age is when you can finally afford the things that a young man could truly enjoy. Tools of the trade |
#10 |
I can tell you from my experience that when I first got my XTi (coming from the P&S world), I thought there was something wrong with it. Then I read everything i could get my hands on, from the web, to magazines, to books and after a while of playing around with it and learning as much as I could, my camera all of a sudden got better. If all you do is shoot in automatic (or even P) you are basically turning the XTi into a point and shoot camera (a great one, but still a P&S) and it will inherit all of the limitations of a point and shoot. Maybe the first few shots you took were backlit, or shots with little contrast, or other things that make the autoexposure tough on the camera's processor. I say read a little and learn a little first, because if that is what happened then buying a 20d or 30d and using it on fully auto mode will give much of the same results. You could buy a 5d and it wouldn't make much difference (except that shots that do come out nice come out really nice). Your XTi may indeed be defective, but you can't know that until you know a little more about how to use it properly.
#11 | |
#12 |
ok I'll post some pix and you tell me what you guys think.
#13 | |
would YOU do this if it was yours? prolly not. that's like buying a new car and only driving it during the day because the headlights don't work.
Rob - "a photographer is a painter, in a hurry!" Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon 580EXII ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS |
#14 |
psycho clown
Location: Having breakfast at the circus, with the lions and the clowns.
Underexposure is either caused by a defective camera or inexperience. Some practise and you should be able to tell which it is. As stated earlier some samples would be great for us to use to judge for ourselves and give you better advice.
#15 |
| Thread Tools | |
| Display Modes | |
| Noob question... | chabooky386 | Canon EOS Digital Cameras | 8 | 26th of June 2007 (Tue) 10:20 |
| Hello everybody, super noob here. | beatbaby | Canon EOS Digital Cameras | 22 | 3rd of June 2007 (Sun) 13:59 |
| noob needs help (xt vs. xti vs. d40x) | romeo26 | Canon EOS Digital Cameras | 13 | 3rd of June 2007 (Sun) 13:50 |
| noob question | thekid17 | Canon EF and EF-S Lenses | 5 | 15th of March 2007 (Thu) 08:47 |
| Help A Noob With Rebel XTi Purchase | kaolinchemist | Canon EOS Digital Cameras | 19 | 5th of November 2006 (Sun) 20:11 |
