Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 31st of May 2007 (Thu)   #1
OviV
OviV's Avatar
Default Keeping dark backdrops (seamless) dark
I seem to struggle with lighting black seamless paper. I want it to stay dark but get a lot of spillover from my main light. Unfortunately, my studio is fairly small so I can not put more than about 3 feet between the backdrop and the subject. Any suggestions?
Ovi
5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
OviV is offline   Reply With Quote
Old 31st of May 2007 (Thu)   #2
Ray Marrero
Ray Marrero's Avatar
Default Re: Keeping dark backdrops (seamless) dark
Hey, try positioning the light so that it lights only the subject. What modifiers are you using? When I use umbrellas I put it high and angle it down. Works for me.
Ray
Canon 7D, 30D - 550ex & 580ex, Nikon SB-28's x3, AB800 x3, Canon 10-22mm, 18-55mm, 50mm 1.8, 85mm 1.8, 24-70mm 2.8L, 70-200mm 2.8L IS, Sigma 28-105mm 2.8, Tamron 28-75mm 2.8, CyberSyncs.
Ray Marrero is offline   Reply With Quote
Old 31st of May 2007 (Thu)   #3
airfrogusmc
If your shooting a single person or a couple put them 8 ft or so from the BD use one light with a soft box (not so much spill like with umbrellas)in close to subject and a reflector If you want to keep the subject seperate use a light on the backdrop. Not seamless but you get the idea.
airfrogusmc is offline   Reply With Quote
Old 31st of May 2007 (Thu)   #4
airfrogusmc
No light on backdrop
Old 1st of June 2007 (Fri)   #5
Saturation
User is banned from forums
One light setup with reflector, crappy old black bed sheet, subjects 3 ft. away from it, and very little PP. Just keep trying different things and you'll get it!
Saturation is offline   Reply With Quote
Old 1st of June 2007 (Fri)   #6
Wilt
Wilt's Avatar
If you are limited in the distance between subject and background, one thing you can try to do is to place the light VERY CLOSE to the subject!
Light distances can be thought of like f/stops. If your light is 5.5' from the subject, it has to be 16' from the background in order for the b/g to be -3EV in intensity (black). If the light is 3' from the subject, the light needs to be only 8' from the b/g to get the same -3EV difference in intensity.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 1st of June 2007 (Fri)   #7
mR_CaESaR
mR_CaESaR's Avatar
using grid softboxes or beauty dishes with grids will allow you to control the amount of spill you have on the background too, ideally though, you'd want to place your subject as far from the background as you possibly can.
Buy the best Lens and never buy again!
Buy once and save
Upgrade Your Epson P-3000 to 120gb tutorial
mR_CaESaR is offline   Reply With Quote
Old 1st of June 2007 (Fri)   #8
Eric DeCastro
i just put the light closer to the model, use a kicker and stop up.
eric@importculture.com
www.ImportCulture.com
4-500MML f/1.8 IS USM
Eric DeCastro is offline   Reply With Quote
Old 1st of June 2007 (Fri)   #9
TMR Design
TMR Design's Avatar
As Wilt shows in his post there is a science to this and it's not just ramdom setup mixed with trial and error.
The key to this is the maximum isolation between subject lighting and background. If you don't have the isolation you'll never achieve a black background. There must be a full 3 stops difference between the incident taking aperture and the reflective reading from the background. So if you meaure a taking aperture of f/8 then you need a reflective reading of f/2.8 or less (larger aperture) to get black.
As mentioned, moving the subject lighting closer to the subject reduces the spill and I would suggest that you work that way before you start adjust the positions of the lights (height, angle of incidence,etc.) because the whole idea is to create the lighting you want rather than having the light control you. Create the same lighting you originally had but with your main, fill, hair light, accent,etc at much closer range, keeping that lighting contained to a smaller tighter space surrounding your subject.
Of course you want maximum distance between subject and background but this can still be done with only 3 or 4 feet separation. Other methods that I have found to be quite useful in a small studio space are to use devices like barn doors, gobos and flags. Personally I use barn doors and a large black gobo and I can see and measure the difference in light that strikes the black background and the light that returns to the subject.
When I was first learning this I had tremendous trouble due to the light that was returning to the subject from the background. It takes some work to get this right but if approached methodically and logically it can be done with excellent results.
Please call me Robert or Rob, not TMR
Gear List & Feedback | My Online Portfolio
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 1st of June 2007 (Fri)   #10
Wilt
Wilt's Avatar
Originally Posted by TMR Design View Post
As mentioned, moving the subject lighting closer to the subject reduces the spill and I would suggest that you work that way before you start adjust the positions of the lights (height, angle of incidence,etc.) because the whole idea is to create the lighting you want rather than having the light control you. .
Well, that first sentence above is incomplete...you put the subject lighting closer to the subject, so that the relative distance [light-to-subject] vs. [light-to-b/g] are at greater ratio to each other. [2.8:8] vs [5.6:16] are both 3EV differences in aperture. We usually have room for a light to be 8' away from a backdrop, but few (other than pros with large studio space) can conveniently put their lights 16' away from the backdrop!
Separate from the lighting distance control is the spill control that is accomplished via 'flags' or 'gobos' or reflector shape or aiming of the light. The subject vs. background distance is assuming that you have a light at camera position providing fill on the subject, so there is NO way other than distance to background to control that light!
Old 1st of June 2007 (Fri)   #11
TMR Design
TMR Design's Avatar
Thanks for the clarification Wilt.
Old 1st of June 2007 (Fri)   #12
airfrogusmc
Also remember the closer you work with light the softer the light. Usually work with the softbox just out of the field of vision of the lens and skim the light slightly in front of the subject and onto the reflector also just out of view of the lens. In a studio I also use a soft box over head pointed slightly back to the camera so light doesn't spill on the backdrop and will spate the shoulders as well as giving a very soft hair light that when adjust properly never burn out the hair. For me and my work I have found one light on subject and a reflector gives me the quality of light that I prefer and I can't get with fill light or umbrellas.
Old 1st of June 2007 (Fri)   #13
Wilt
Wilt's Avatar
Originally Posted by airfrogusmc View Post
Also remember the closer you work with light the softer the light. .
To be most precise, the larger the apparent size of the light source, the softer the light. A tiny LED flashlight would still provide very harsh light even 1" from the subject's face!!!
Old 1st of June 2007 (Fri)   #14
airfrogusmc
Yep! I like working with a large soft box in very close. Sometimes in a studio setting I'll set a large shot through scrim and shoot a couple of WL ultras thru it with a full length reflector on the other side for fill. I really like the quality of that kind of light.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
selecting dark objects from dark backgrounds steve547 RAW, Post Processing and Printing 6 28th of December 2006 (Thu) 20:50
Keeping with the dark theme... Refemall People 3 24th of August 2006 (Thu) 15:03
Wide Seamless Paper Backdrops cigman1st The Business of Photography 1 8th of February 2006 (Wed) 09:13
A Dark, Dark Day. Forget the Silver Lining. Lens Trashed. Belmondo Canon EOS Digital Cameras 40 18th of February 2004 (Wed) 04:51
