FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 01 Jun 2007 (Friday) 12:22
Sports photography with a S3 IS
ddphoto
Jun 01, 2007 12:22 |  #1
I'm looking for help in setup, recently bought a Canon S3 and I'm trying to get the settings dialed in for cycling pics.
Tried the presets like Auto and Sports and the results were dark and noisy pics. Tried the Av (aperture priority) mode with some success and recently tried the P (program) mode with some adjustments getting horrible results, most of the pics came out overexposed and out of focus.
What will be a good setup for a S3 for the kind of photography I'm trying to do?
In addition to the S3 have a Telephoto and Wide Angle lens that attach to the camera via an adapter tube. Most of the pics that I've taken have used the regular and wide angle lenses.
ddphoto
Canon 400D, Canon 18-55, Tamron 28-80, Tamron 70-300
http://www.flickr.com/​photos/dd_photo/ (external link)
janos16
Jul 17, 2007 23:52 |  #2
Hi there. I have the same camera and I use the Tv mode for action shots. Use a fast shutter speed of let's say 1/125th of a second or try 1/250th of a second. This will stop motion in your picture. In this mode the aperture is set automatically. Use a slower shutter speed of about 1/60th of a second to blur the action. Good luck.
The ­ Fox
Jul 18, 2007 13:07 |  #3
What kind of conditions are you shoting in(low light, indoors, outdoors)? And of what?
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
7D Gripped x2 | 50D Gripped | 17-50mm F2.8 | 35mm F1.4 | 50mm F1.4 | 85mm F1.8 | 70-200mm F4L IS |
pakomo
Jul 18, 2007 13:48 |  #4
Well, I don't own the camera, but the noise you're mentioning, could be because the camera is boosting the ISO, so it can boost the shutter speed.
Patrick Kofod Mogensen
Canon EOS 400D + BG-E3
16-35mm f/2.8L I,
85mm f/1.8, 18-55mm f/3.5-5.6 | 430EX + Omni-Bounce
The ­ Fox
Jul 19, 2007 13:47 |  #5
Use av mode and open the aperture all the way. Put the ISO up to 400 and that should work for low light. Leave the ISO at 100 for outdoors with av mode on.
sadowsk2
Jul 19, 2007 19:21 as a reply to  @ The Fox's post |  #6
If you're serious about it and have the luxury to do so, you might wanna upgrade to a DSLR... that right there would help you go a long way for shooting what you're wanting to shoot...
1D Mk IV, 5D Gripped, 30D
35L | 50L | 85L II | 100L | 135L |16-35L | 24-70L |[COLOR=black] 24-105L | 70-200 2.8L IS II | 100-400L | 15mm fisheye | 580EX II x2 | 430EX
Canon S3IS
7kpulldown
Jul 23, 2007 19:41 |  #7
I'm a hack, I shoot family outings and such, with an old G3. If I have the opportunity, I'll set up in Av, at 5.6 for good depth of field, ISO 100 for reasonable speed/grain, and use MF (manual focus) to eliminate shutter lag. Eliminating shutter lag is the key for sports and compact cameras, take all the thinking away from the camera. Save the settings in one of the custom functions. The G3 has two, C1 and C2. Your S3 has one custom function I believe. I'm not sure if your cycling subjects move faster than a ball like in my attached pics, but I'd give it a try. Your S3 can take fantastic shots, IMO, I would hold off on the DSLR until the S3 proves to be an insufficient tool for your photography. Learn it, live it, love it!
angryhampster
"Got a thick monopod?"
Jul 23, 2007 20:52 |  #8
7kpulldown wrote in post #3599189 (external link)
I respectfully disagree :D
I went from an A85 powershot to a Digital Rebel XT a couple years ago. It was a different world. If you want to get into DSLR photography, do it. It's getting cheaper every day.
Steve Lexa
Iowa City Wedding Photography (external link)
283CID
Joined May 2004
Jul 29, 2007 15:32 as a reply to  @ angryhampster's post |  #9
The S3 takes great 'sports' pictures; I have taken MANY! I usually set the shutter for around 1/160.. or if it is bright, higher. "Tv" mode... [let the Little Guy inside select the 'hole' size]. Outdoors in any reasonably bright day... ISO 80. Set the camera to take CONTINUOUSLY, as you hold down the button. I have a 2GB memory; I can take over 700 pictures, at highest res, so I can hold a good many such bunches of action... You are bound to get That Shot in a pile of pictures! Use the 'Optical' View Finder; you can keep up with The Action easier. I have found that using Top Res, I can get something like 30 [Bad human memory here], before the camera stops to 'catch-up' . Go to a lower Res and it is a higher number. At bottom Res, I checked and quit counting at 100...
Beats a 'heavier' camera, any day...
7kpulldown
Jul 30, 2007 21:11 |  #10
Oh, thats right... use the view finder, instead of that great big flip out screen....make that little camera, with the long reach, shoot real fast! The way 283 sets it up, works very well too.
2,624 views & 0 likes for this thread
version 2.0 /
Latest registered member is CanucksFan
373 guests, 314 members online
