Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 6th of June 2007 (Wed)   #1
drjack3
Default POWERSHOT SD300 BROKEN DISPLAY
I have a Power Shot SD300 with a broken display panel,it lights up , and I realized I needed an LED replacement.
someone is offering me an SD 450 that has a stuck lens does anybody know if that LCD screen will swap across to the SD 300 model?
Is there a list to determine which displays fit in which cameras?
Jack
drjack3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SD300 broken display drjack3 Small Compact Digitals by Canon 1 23rd of June 2007 (Sat) 13:40
4 Gigabyte SD Card on PowerShot SD300? information Small Compact Digitals by Canon 3 29th of July 2006 (Sat) 16:57
Powershot SD300 question boomer9090 Small Compact Digitals by Canon 1 29th of June 2006 (Thu) 22:03
help with broken SD300 volcomnator999 Small Compact Digitals by Canon 2 14th of June 2005 (Tue) 18:10
i have a canon powershot sd300.. lildebi Small Compact Digitals by Canon 3 4th of March 2005 (Fri) 00:35
