Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 6th of June 2002 (Thu)   #1
Diggi
Default Canon Elph 2 Problem
I know this is not a digital camera, but it is very similar to the Canon Elph Digital in functionality and photo processing and I need your help!! I hope someone at Canon or a Canon user knows the ins and outs of this marvel camera, The Elph 2.
The problem I am having is that the camera APS film cover does not want to open. The CPU "thinks" that the cover latch is open but it is locked closed with no film inside. In this mode the camera doesn't do anything!! I tried tthe mid roll change button, I tried the rewind button, I tried removing the batteries, I tried resetting the time and date but nothing works??!! The camera is jammed in this mode!
If anyone knows how to reset the CPU (by pressing several buttons at the same time while power on or something) maybe this might do it.
Please your help is very much apppreciated and THANKS A MILLION in advance!
Diggi
Diggi is offline   Reply With Quote
Old 7th of June 2002 (Fri)   #2
Rustle
Default Re: Canon Elph 2 Problem
Wouldn't taking the batteries out for an extended period reset the CPU? Assuming that it is a CPU problem, and not a broken switch or something.
Russ
Rustle is offline   Reply With Quote
Old 9th of June 2002 (Sun)   #3
Diggi
Thanks Russ for your reply.
I did try removing the batteries for days but unfortunately that didn't help either. Somehow the camera "thinks" that the cover is open and doesn't wont to eject the latch to "re-open" the film compartment again.
I am still open for any ideas or comments and thanks to all.
Diggi
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon Elph 800 or 1000 punkeb Small Compact Digitals by Canon 1 1st of April 2007 (Sun) 01:56
Canon SD 1000 Digital Elph Yella Fella Small Compact Digitals by Canon 3 15th of March 2007 (Thu) 07:16
canon sd450 digital elph BARBIE Small Compact Digitals by Canon 1 1st of March 2006 (Wed) 09:09
Canon Powershot s400 ELPH fallingstar Canon EOS Digital Cameras 2 24th of August 2005 (Wed) 21:52
