| sponsored links |
Thread Tools | Display Modes |
#1 |
I use Alien Bees strobes, which have a specified operating temperature of 5600 degrees K.
I have my hair light behind a custom diffuser that seems to warm up the color of that strobe about 500 degrees and it's too warm for skin tones. I don't want that one light to affect the overall color temperature of my shot but I love the diffusion so I'm wondering how I can adjust the color temperature of that one strobe. Is the answer to use a gel in front of that light that lowers the color temperature by 500 degrees? Are gels available to accomplish this? Are there other methods used when mixing light sources of different color temperatures?
Please call me Robert or Rob, not TMR Gear List & Feedback | The Lighting Academy "Art is the elimination of the unnecessary." - Pablo Picasso |
| sponsored links |
#2 |
You might try one of the Rosco filters.
http://rosco.com/us/filters/roscolux.asp#Colors Roscolux #3216: Eighth Blue Boosts 3200K to 3300K Roscolux #3208: Quarter Blue Boosts 3200K to 3500K Roscolux #3206: Third Blue Boosts 3200K to 3800K Maybe one of these? |
#3 |
Thanks.
Ok so here is the question. The ones you are suggesting are all boosting temperature. How does that help with the one strobe I have that is 'hotter' than the others? I see one that's close to what I need. It's actually the first one listed and it converts 5500 degree to 4900 degrees. I need a change of about 500 degrees and that is 600 but it's the closest thing. How precise is all of this and how precise do we need to be? Will that gel do the job I need?
| sponsored links |
#4 |
Master Flasher
A clarification of terminology is in order.
Higher color temperature light creates a "cool" (blue) appearance. Lower color temperature light creates a "warm" (yellow-orange) appearance. The blue gels mentioned by Breal will increase the color temp and make the image cooler (more blue). CTO (color temperature orange) gels will decrease the color temp and make the image warmer (more orange). Confused yet?
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#5 |
If your hair light is too warm you need to convert cooler (bluer). I may have misunderstood but it seems you are saying the hair light is 500 degrees warmer than you want.
#6 |
Thanks guys,
Ok thanks for that clarification. I shoot and set white balance for 5600 K with the un-diffused light. If I shoot the same thing with the diffused light it is more orange. If I adjust the camera's color temp down to 5100 and shoot with the diffused light it matches the original with no diffusion.
#7 |
Master Flasher
Sounds like one of the blue filters will take care of that.
#8 |
Thanks Curtis and breal101.
I think I may try one of those blue gels.
#9 |
Did that blue gel work out? Are some blue and orange gels temperature rated for +/- K?
#10 |
Can you explain the components of your diffuser? I'd like to pinpoint what is warming it up.
A.J. 1D mkIII \ 24-105L \70-200 2.8IS II \ 35L \ 85 1.8 \ Kenko 1.4x \ 580EXII \ 430EX + every piece of Nikon/Photogenic equipment imaginable at the studio. |
#11 | |
The problem is that the color shift is not linear. It is different based on the color temperature you are starting from. The factor is expressed as the "Mired shift". Mathematically, this is defined as: Mired Shift = 1000 * (1000/T2 - 1000/T1) where T1 is the color temperature you have and T2 is the color temperature you desire The Rosco and Lee sites do not show the mired shift values for all "color conversion filters". However, the samples do supply the mired values. For Roscoe CTB cinegels, they are: # filter mired 3202 ctb -131 3203 3/4 ctb -100 3204 1/2 ctb -68 3206 1/3 ctb -49 3208 1/4 ctb -30 3216 1/8 ctb -12 3220 2x ctb -260 Hope this helps... Ooops....just read that you may need to go in the other direction. Same rules apply, just need to use CTO filters. The Rosco site http://www.rosco.com/us/filters/cinegel.asp has mired values for the different CTOs. Last edited by jrsforums : 18th of December 2007 (Tue) at 09:35. |
#12 | |
Been a while since this thread was active. My diffuser is not any different from small softboxes and enclosed light boxes. I've got 4 sides that are reflective white with a front diffusion panel made of white nylon ripstop. That's it.
#13 | |
| Thread Tools | |
| Display Modes | |
| Color temperature meters | jonathans9 | General Photography Talk | 6 | 24th of December 2007 (Mon) 17:21 |
| Hey all, question about color temperature. | billmob | Canon EOS Digital Cameras | 5 | 23rd of May 2006 (Tue) 17:49 |
| 20D Question on Color Temperature Setting | reneemc | Canon EOS Digital Cameras | 6 | 11th of June 2005 (Sat) 14:35 |
| Monitor color temperature | msvadi | RAW, Post Processing and Printing | 10 | 14th of January 2004 (Wed) 17:40 |
| Manual color-temperature | vvizard | Canon EOS Digital Cameras | 5 | 26th of November 2003 (Wed) 15:48 |
