Reply
Thread Tools Display Modes
Old 24th of June 2007 (Sun)   #1
siejones
siejones's Avatar
Default Do you own a consumer lens?
What consumer grade lenses do you own that you actually want to keep and are not a stop gap until you can afford a pro grade lens of the same focal range?
Do you have a consumer grade lens that you swear by?
Also I am thinking of getting me a inexpensive light weight lens to take into the mountains with me when my pack has to be minimal as possible. You know something that if it got smashed on the rocks I wouldn't feel the need to jump off the nearest cliff face. Something with acceptable sharpness will do but better than the budget range. This will sit along side my siggy 10-20 so needs to cover the range say from 24 or 28 onwards.
I have been looking at used canon 28-105's as these seem to be a popular stand up lens. It would be nice it it stretched a little longer and I have also looked at the Canon 28-200 although I can't seem to find much info on this one. I wouldn't go for the 18-200 ranges as I think they push the limits to far to be good enough and I really don't need that wide end.
So any ideas/recommendations?
Technical perfection is only ever important if it improves the asthetic. It is not the precursor to beauty. Not in art..not in music and not in photography!
My Flickr account link
siejones is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #2
kevin_c
Default Re: Do you own a consumer lens?
28-105 USM II is a great little 'consumer grade' lens - I still have mine after upgrading to the 24-105L - in all honesty there is very little difference between the two (except the IS, weight, size, oh and a red ring...)
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
kevin_c is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #3
liza
User is banned from forums
The closest thing I have that meets your criteria is a Tamron 28-75 that I use as a backup lens for weddings for my 28-70L. It's a good, solid lens, although the autofocusing mechanism leaves a bit to be desired.
liza is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #4
oic929
50mm f/1.8. The f/1.4 would be nice, but I dont plan to upgrade to it in the near future
oic929 is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #5
kahren
canon 55-200 looks like a nice enough lens, you wont miss the 20-55 range
nex-c3
kahren is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #6
samword
canon ef 85/1.8.
samword is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #7
cdifoto
Don't get pissy with me
cdifoto's Avatar
Not in EF/EOS mount.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #8
John_B
John_B's Avatar
siejones,
All of my consumer lenses (this of course depends on your definition of consumer lens) are ones I want to keep.
ex. my 28-105 f/3.5-4.5 is an excellent consumer lens
so is my 100mm f/2.8 macro and so is my 50mm f/1.4 etc...
The 28-105 f/3.5-4.5 might fit what you need well, it gives great results and is very light weight (and small).
It would be nice if there was a great consumer (low priced) 17-1200 f/1.4 lens but, well you know
John_B is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #9
SuzyView
Ms Moderator and Grandma
SuzyView's Avatar
I have the 28-105 and it's a nice lens. Should be useful if you can't afford to spend a lot. If I were you and I had $300 to spend, I'd definitely consider the 85 1.8. It's my favorite portrait lens and I have a few lenses to choose from. If you want zoom, the Tamron mentioned is popular, although I never owned one. Make sure the copy you are considering is the II version of the 28-105. I will not recommend the 28-135 IS, though. It was useful to me, but replaced it with the 24-70 and the difference was too significant to ignore. But even the kit lens can perform if you know the limitations.
5D2 7D & G12, the new iPad, iPhone 5 , 5 L's & 2 Primes 23 bags - 4 Domke, 3 Lowepro, 1 Crumpler, 2 Tamrac, 5 Kata, 3 Thinktanks, 1 Pelican, 1 Tenba bag, 1 Epiphanie Paris & 2 Coach Handbag! And no excuses.
My children are the reason, but it's the passion that drives me to get the perfect image of everything.
My Gear and Wishes
SuzyView is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #10
siejones
siejones's Avatar
Originally Posted by John_B View Post
siejones,
Cheers duely noted. It is leading the pack for me at the moment.
Theres is!
I found it on ebay and it looks just like a kit lens for £99.99 and it's shipped from Nigeria!
They said all I have to do is send them my bank account number at details and they would do the rest!...nice people
Old 24th of June 2007 (Sun)   #11
John_B
John_B's Avatar
siejones,
Yea that does seem to be popular on ebay
Old 24th of June 2007 (Sun)   #12
hackaroxp
hackaroxp's Avatar
Consumer Lens as in Silver Ringed?
hackaroxp is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #13
malla1962
malla1962's Avatar
ef50f1.4 and ef85f1.8 and love both.
malla1962 is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #14
-spam-
I heart the title fairy
-spam-'s Avatar
My somewhat new 28-135 and 50mm f1.8
Dont really have plans on upgrading those two, but i do plan on builing around them. (12-24, 30mm f1.4, 85mm 1.8 etc...)
Carp - flickr - Blog log - Get Crumpled
You say tomato, we say 1/125 @ f/5.6
-spam- is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #15
argyle
argyle's Avatar
For 'consumer' lenses, I have the 28-105 Mk II, 100/2.8 macro, and the Tamron 28-75. Even though I have a 24-105L, I plan on keeping the 28-105...its that good. The 100 macro is a 'wow' lens with regard to sharpness and is also a keeper. I bought the Tamron to see what the hype was all about. Yeah, its pretty good, but it also feels very 'cheap' to me. Of the three, this is the one that'll probably go.
Since you already have the 10-20, I'd go with the 28-105 Mk II as a light-weight, inexpensive walk-around. Here's link with a few comparison photos between the 28-105 Mk II and the 24-105L:
http://photography-on-the.net/forum/...d.php?t=318746
argyle is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
what is the most expensive consumer lens? Wobble Canon EF and EF-S Lenses 38 9th of July 2007 (Mon) 06:24
Canon Consumer Lens Copy Quality Catnippants Canon EF and EF-S Lenses 18 11th of June 2007 (Mon) 16:07
First consumer MKII appears! defordphoto Canon EOS Digital Cameras 26 9th of April 2004 (Fri) 20:39
Are all consumer labs equal? dennykyser Canon EOS Digital Cameras 7 12th of March 2004 (Fri) 11:50
