Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Sports Talk
Reply
Thread Tools Display Modes
Old 24th of June 2007 (Sun)   #1
jaypol
Default Selecting metering mode for sports
I typically shoot outdooor sports (swimming, baseball, water polo) using a Canon 350XT with a Canon 70-300 5.6. My shots have always come out ok using partial metering but I keep thinking that maybe I'm missing something.
Would evaluative, partial or center-weighted average be the best choice for sports (I always use the center point for focus.)
Thanks.
Great forum.
jaypol is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #2
Zebceponaf
Zebceponaf's Avatar
Default Re: Selecting metering mode for sports
would also like to here someone's advice on this. I'm shooting evaluative right now.
Zebceponaf is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #3
dekalbSTEEL
dekalbSTEEL's Avatar
If the lighting is relatively constant, I would use a gray card to set your exposure(in M mode) and leave it , adjust ISO as needed to get the fast shutter speed you want to freeze the action.
Grippy 30D, Tokina 300f4, Sigma 18-50f2.8, Canon 70-200f4L, thrifty50mkI, PM7500DX
dekalbSTEEL is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #4
dmwierz
dmwierz's Avatar
I believe the OP wanted to know about metering, not necessarily exposure, although D-steel's suggestion of using a gray card is a good one to set exposure and white balance.
I rarely use anything other than evaluative metering and this has worked well for me for a while. Every so often, my metering mode gets bumped to something else accidentally and my shots come up looking odd, and sure enough I discover the change in metering mode is the culprit. YMMV.
Multiple metering modes is one of those things, like 45-point AF, that I still haven't found the need for, but this is probably a limitation on my part, and not Canon's. I'm sure somebody has a need to use 45 points for AF, or some exotic metering mode, but I just haven't found either of them necessary, preferring to operate under the axiom: Keep It Simple Stupid.
http://www.denniswierzbicki.com
http://www.sportsshooter.com/dmwierz
Dennis "
Yeah, well, sometimes nothin' can be a real cool hand."
dmwierz is offline   Reply With Quote
Old 24th of June 2007 (Sun)   #5
dekalbSTEEL
Shows the limitations of my 300d, no user selectable metering modes
And if you use a gray card to set exposure, it wouldn't matter which metering mode you use, no?
Old 24th of June 2007 (Sun)   #6
dmwierz
dmwierz's Avatar
Steel - The metering mode controls how the camera interprets the light it sees, and how it looks around the frame for light and dark spots. The result of this interpretation is fed into the exposure calculation when the camera computes which shutter speed to combine with a chosen aperture and ISO, for example, in Av mode.
Which metering mode you choose could impact your exposure if you had something really bright in the corner, say, and had chosen center spot metering. The camera would assume the scene was darker than it is and over expose the image.
However, if you are shooting a gray card properly, it should be filling the frame and be shot at a fairly small aperture (like f/16), and should also be out of focus. In this instance, the light on the card should be fairly uniform so the metering mode is going to have minimal impact on the exposure.
Here is an excerpt from the 1D MkIIn's manual:
Dennis "
Old 24th of June 2007 (Sun)   #7
dekalbSTEEL
Yeah, that's what I was getting at...
And I'm familiar with the different metering modes, spot metering is one thing I miss about my film Elan ( and that big bright viewfinder)
Old 24th of June 2007 (Sun)   #8
totalbeginner
totalbeginner's Avatar
Until recently I've always used evaluative and Av. Now I've started taking a spot reading and shooting in manual.
I find this works much better and gives more consistent results. It stops the S/S jumping up and down when the meter is thrown off by something, i.e large light or dark areas. You soon get used to using certain things to meter from such as grass, pavement etc...
View my gear list HERE
Don't submit to stupid rules, be yourself and not a fool. Don't accept average habits, open your heart and PUSH THE LIMITS!
totalbeginner is offline   Reply With Quote
Old 25th of June 2007 (Mon)   #9
FZ1dave
I only used evaluative for sports so far and it's worked well, but I'm a complete newb.
Now that you've got me thinking I'm gonna have to play with partial and center weighted.
FZ1dave is offline   Reply With Quote
Old 25th of June 2007 (Mon)   #10
PhotosGuy
Moderator
PhotosGuy's Avatar
Gray cards are OK, but this is faster & the metering mode doesn't matter as much: Need an exposure crutch?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 25th of June 2007 (Mon)   #11
pagnamenta
It depends on the color and design of the uniforms. I mostly use partial or spot metering. Not to say evaluative won't do the job; I use all AF points to track the subject so I never know which point the metering is coming off of. The spot meter also allows you to check the exposure on their face, which is really important if they have hats or helmets.
When shooting white, you always have to overexposure a little. If the uniform is really dark, then you need to underexpose. Spot metering allows you to get it right.
I also shoot all manual, so when I meter with evaluative, no matter where I seem to point the camera, I get the same reading. If I use spot, the reading is different for the pants, the shirt, the face, and the background.
pagnamenta is offline   Reply With Quote
Old 25th of June 2007 (Mon)   #12
S.Horton
dǝǝɥs ɐ ʎq pǝʞuɐds
S.Horton's Avatar
Evaluative, and adjust exposure for consistency in PP in RAW.
In short, we cheat.
S.Horton is offline   Reply With Quote
Old 5th of July 2007 (Thu)   #13
PhotosGuy
Moderator
PhotosGuy's Avatar
I mostly use partial or spot metering. ...so I never know which point the metering is coming off of.
It's not like the actual light is changing... just what the meter thinks is "right". Shooting on full "M" solves that problem & allows you to concentrate on what's happening on the field. See post # 10 again.
www.FrankCizek.com
Old 2nd of January 2009 (Fri)   #14
Roy Webber
Location: Corralejo, Fuerteventura....Canary Islands Spain
Evaluative...
Canon 7D, 40D,100-400 IS L, EFS 15-85 IS, EFS 10-22-With Faulty USM, 055XPROB+488RC2, 430 & 580 II Flash, Tokina 11-16mm f/2.8-
Photos
Roy Webber is offline   Reply With Quote
Old 2nd of January 2009 (Fri)   #15
Dan-o
Dan-o's Avatar
Wow, revive a 6 month old thread for that.
Danny.
DMunsonPhoto
Cycling Illustrated
FB Fan Page
Dan-o is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
I need some basic advice..AF mode, metering mode .. xxbodkinxx Macro 3 6th of July 2006 (Thu) 23:16
selecting metering mode Dai Canon EOS Digital Cameras 1 11th of May 2006 (Thu) 16:16
Sports metering Crashoran Canon EOS Digital Cameras 7 22nd of December 2005 (Thu) 18:35
What metering mode do you use? Keiffer Canon EOS Digital Cameras 15 16th of August 2005 (Tue) 08:12
Metering mode & multi spot metering alpine62uk Canon EOS Digital Cameras 0 8th of October 2004 (Fri) 08:04
