#1 |
Is the Canon BP-511A good? What is the expected usage time?
Is there an option with a longer life? |
| sponsored links |
#2 | |
Worthless twinkle toes fairy
Canon EOS 5D Mark II, 100-400IS L, 24-105 L[color=black][font="] IS, 50mm f/1.4, Canon 430EX/580EX II, Kenko 1.5X, Epson R1900, Manfrotto 679B Monopod, 3021BPRO tripod, 808RC4 Head, 486RC2 Ballhead Last edited by JohnnyG : 27th of June 2007 (Wed) at 16:27. Reason: highlighted "this" |
#3 |
Oops I just saw the everything you need to know about aftermarket batteries thread.
| sponsored links |
#4 |
It's the same place I recommended! Sterlingtek.com. You really can't beat them.
Canon EOS 5D Mark II, 100-400IS L, 24-105 L[color=black][font="] IS, 50mm f/1.4, Canon 430EX/580EX II, Kenko 1.5X, Epson R1900, Manfrotto 679B Monopod, 3021BPRO tripod, 808RC4 Head, 486RC2 Ballhead |
#5 |
I just ordered 2 batteries. Thanks a lot.
#6 |
What's the diff- between the BP-511A and the straight BP-511 models?
Look.!!.. Kelp Paddy Ahead....ZZZZZZZZZZ Hoook UUPP ! !!!.. Yeee Haa... I smell Hickory Smoke Tonight... |
#7 |
#8 |
Dignity-Esteem-Compassion
I have both and the 511 is lower mAh than the 511A. The 511 is 1100 and the 511A is 1390.
Doc Klepper in the USA I am a photorealist, I like my photos with a touch of what was actually there. Polite C&C always welcome, Thanks. Gear List |
#9 | |
J.
Obsessive Gear List "It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain |
#10 |
Hey, i'm looking to buy a battery as well and ran across this post.
I thought BP-511A is 2000 mAh not 1390...no? Also, will my Canon charger be able to charge these batteries since oem battery is 720mHh Is there other brands you guys recommend that will last long? |
#11 |
#12 | |
Then the aftermarket launched batteries with numerical capacity HIGHER than the BP-511, or LOWER than the BP-511a, or HIGHER than the BP-511a, but used the generic number 'BP-511' for all types! So always look at the mAh spec for a battery, rely upon 'BP-511' only as an indication of the physical form factor (it fits!)
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php |
| Thread Tools | |
| Display Modes | |
| long exposures, battery life | Ozark | Canon EOS Digital Cameras | 4 | 16th of July 2007 (Mon) 03:54 |
| long exposures, battery life | Ozark | Canon EOS Digital Cameras | 0 | 15th of July 2007 (Sun) 23:19 |
| A300 battery life or no battery life ?? | arde | Small Compact Digitals by Canon | 4 | 4th of July 2005 (Mon) 03:02 |
| Poor Battery Life on Speedlite 580EX? or Some other problems? Battery Recommendation? | EricKonieczny | Accessories & Storage | 4 | 12th of March 2005 (Sat) 19:20 |
| Have I been on Forums too long? / Do I need a life? | Tapeman | The POTN Lounge | 4 | 6th of July 2004 (Tue) 20:57 |
