Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 29th of June 2007 (Fri)   #1
tonyr0584
tonyr0584's Avatar
Default Preparing For Wedding Shoot
Cheerleader practice tonight so a chance to test out the new flash.
This was shot at ISO400 f5.6 1/160 with Canon XTi set at Evaluative Metering. I tried ETTL but the shots seemed darker than normal. What if anything under these conditions could have been done better. I used this as a test session to prepare for a wedding coming up..... I know big difference between weddings and cheerleader practice. The wedding reception will end up in this same kinda light in the evening so figured what better way.... anyway. Please comment.
Thanks in advance for any suggestions to help prepare.
http://www.trphotography.net
Camera Stuff
tonyr0584 is offline   Reply With Quote
Old 29th of June 2007 (Fri)   #2
tonyr0584
tonyr0584's Avatar
Default Re: Preparing For Wedding Shoot
BTW.... flash was a Sigma 500 DG Super
Camera Stuff
Old 29th of June 2007 (Fri)   #3
MDJAK
...the definition of a noob
MDJAK's Avatar
Bump your ISO up as high as you can get away with. That will brighten up the room. Also, bounce your flash off the ceiling; that will give much better results.
mark
G10: Canon 25mm II tube
Nikon D3: 16mm F2.8 Fisheye; 85 F1.4; 105mm F2.8 Macro; 24-70 F2.8; 70-300 VR; 70-200 F2.8 VR; SB-900 Speedlight x3; SB-800 Speedlight; SU-800 Speedlight Commander; SD-9 Battery Pack for speedlights; Gitzo CF Tri/Monopods; Markins M20 Ballhead.
MDJAK is offline   Reply With Quote
Old 29th of June 2007 (Fri)   #4
tonyr0584
tonyr0584's Avatar
mark
I did try a few at 1600 but by the time I adjusted ap and ss to keep from being blinded by light reflection off their faces and white shirts, I came back to the same results as shooting at 400 it seemed. For this wedding I will be outside and probably a lot closer to the individuals and of course not so spread out for snap shots. Everything up to the reception will be done in good daylight. The reception will be around 7pm until..... So for the Sigma I'm assuming shoot straight at my subject and use ETTL? I did a few with ETTL at this practice, they seemed acceptable hard to tell from so far back.
Camera Stuff
Old 29th of June 2007 (Fri)   #5
GertS
I second Mark, but expect to use a lot of energy for the flash when directing it up the ceiling. Works only with a certain distance and bright color of the ceiling.
Recycling the flash takes time too.
- left forum in protest -
GertS is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #6
wazmunstr
wazmunstr's Avatar
i wouldnt try straight on. try at a 45 degree angle. or get some sort of defuser and shoot straight up like the stofen or lightsphere.
Canon EOS 20D|Sigma 18-50mm f/2.8 EX DC|Canon 430EZ Flash|Adorama Budget Studio Strobe|Stuff|Stuff|And More Stuff
Online Portfolio:http://www.usefilm.com/photographer/33147.html
wazmunstr is offline   Reply With Quote
Old 1st of July 2007 (Sun)   #7
rammy
rammy's Avatar
The thing is it still looks like a "flashed" pic, know what I mean? You want to try and expose for the ambient light and let the flash ETTL for the people. That way you get a more natural looking shot.
Your focal length was 28mm (44.8 on the xti) so keeping everything the same, you could have dropped your shutter speed to just below 1/100 to bring in more ambient light. This would have helped with the background.
In this shot, lowering the view and getting the full reflections of the girls in the floor would have been cool.
EOS 5D MkII | EOS 50D | EOS 30D | EF 17-40 F4L | EF 24-70 F2.8L | EF 24-105 F4L IS | EF 70-200 F2.8L IS | EF 35 F1.4L | EF 50 F1.4 | EF 85 F1.8 | EF 100 F2.8 | EF 135 F2L
Gear | Portfolio & Wedding Site | Blog
rammy is offline   Reply With Quote
Old 1st of July 2007 (Sun)   #8
howzitboy
it looks flashed but i dont see any shadows (from the flash) so his exposure was perfect. id still lower the flash 1 stop so its not soo "bright".
howzitboy is offline   Reply With Quote
Old 1st of July 2007 (Sun)   #9
rammy
rammy's Avatar
Being there, you would not have seen it this way. See the lights in the back on the ceiling? They have projected some light at the back but the exposure has been set to capture the foreground only, not the ambient light.
This shot could have been so much better because I doubt very much that the background and corner of the stadium was that dark. Dialling down the flash will just make the whole scene darker. Capturing the ambient light first is important and then popping the flash to fill-in some foreground shadows.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
First wedding shoot from My friend's wedding.. critics plz!! :-) candybol Weddings and Other Family Events 7 13th of July 2007 (Fri) 13:50
First indoor lighting shots preparing for a 'shoot' TMR Design Small Compact Digitals by Canon 7 18th of September 2006 (Mon) 01:02
My sister's wedding, my 1st wedding shoot CanonRaw People 5 16th of March 2006 (Thu) 16:33
My first wedding shoot Tlucz-huba People 12 27th of September 2005 (Tue) 22:04
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
