Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 29th of June 2007 (Fri)   #1
GlitterPhotography
Default How to switch between the 17-55 & the 70-200?
I have a wedding tomrrow and I just received the 17-55 in the mail today Unfortunatly I have got very used to the long end of the range on the 24-105 which I love. I typically can get everything, from a full body shot and then instantly zoom in to get the couples face to fill the entire frame. I looked at my photos and they are all around 24-35 or the 70-105 range. I have the 70-200 which I love for many cases, but I am a little scared about how quickly I can switch cameras back and forth. How does everyone manage the 17-55 & 70-200 combo as everyone praises?
An example was 2 weeks ago when I was doing the wedding cake cutting, and I was zoomed out, they go to feed each other, and wam, they stick it in each others face. Luckly I was instantly able to zoom in and capture all the fun from start to finish. How would everyone else do it? It seems like 55mm is way to short to get in close.
Canon 5D, 2x20D
Canon 16-35L II,Canon 24-105LIS4, Canon 70-200L f/2.8 IS, Canon 10-22 f/3.5-4.5, Canon 17-55, Canon 50 f/1.4
GlitterPhotography is offline   Reply With Quote
Old 29th of June 2007 (Fri)   #2
mizuno
User is banned from forums
Default Re: How to switch between the 17-55 & the 70-200?
I shoot with one, have the other on my shoulder.
Takes about 1 second to swap.
mizuno is offline   Reply With Quote
Old 29th of June 2007 (Fri)   #3
Toogy
"I like pictures of myself!"
Toogy's Avatar
I've gotten totally used to it, like Mizuno said, takes about a second to grap my 20D w/ 70-200 on it off my shoulder and shoot with it.
Toogood Studios
Good Light and Shoot to the Right....
Toogy is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #4
Tish
Tish's Avatar
+1 to both Toogy & Mizuno--I prefer to shoot using two bodies at once, one on the neck with a hand strap also attached, one over the shoulder. Swapping is a breeze once you get used to it.
However, for shots like the one you describe, you also should be able to anticipate the action well enough ahead to decide how you want to shoot it. I shot entirely using one body last weekend, swapping lenses as I went. It was a great time to experiment, since I was seconding a very good photographer, and I found it a very different way to shoot than what I'm used to. I had to be more creative when an shot came up that I wasn't "ready" for--and ended up with some fabulous images as a result.
Best of luck!
Tish is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #5
GlitterPhotography
I guess it just takes pracitce. Do you all use a hand strap as well? I always feel uncomfortable having my 70-200 on my shoulder and then when I go to use it, only holding it without a strap around me neck Its weird to be holding $2K+ in my hands just waiting for a kid to knock it to the ground.
Canon 5D, 2x20D
Old 30th of June 2007 (Sat)   #6
Tish
Tish's Avatar
I leave the shoulder strap around my right shoulder, just bring the camera up to my eye level. So the camera's in a lot less danger of falling. I'm far more likely to bang it against something as I move around too quickly. Make sure you keep the hood on!
And yes, the hand strap makes a HUGE difference. Tried one of my cameras ungripped/no handstrap with the 70-200 a week or so ago & swore I'd never do that again. It's just a lot easier to hold such a big rig with the extra support of the hand strap.
Old 30th of June 2007 (Sat)   #7
GlitterPhotography
Do you have to have a grip to use the hand strap?
Canon 5D, 2x20D
Old 30th of June 2007 (Sat)   #8
tim
Light Bringer
tim's Avatar
I think you need the grip to use the hand strap. I have a hand strap somewhere but I never liked it so it's in the cupboard somewhere.
I use two cameras, with OpTech pro straps (like the POTN ones), but I only use the tiny strap so it just fits around my shoulder. Works for me, I don't much like straps. During a ceremony I keep one camera on the floor beside me and one in my hands, I swap when I need to, and sometimes I leave a camera in a pew if I need to move discretely.
tim is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #9
Eric&Susan
Eric&Susan's Avatar
No grip on my 30D and I use a handstrap
Eric
Eric&Susan is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #10
liza
I shoot with two bodies like the rest. I got used to doing this when shooting basketball games with prime lenses, so it's second nature to me now.
liza is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #11
Inspired Photography
Inspired Photography's Avatar
Eric
Is there an extra loop on the bottom or something?
I haven't had the grips off any of my gear for as long as can remember, but didn't think there was an attachment on the bottom to attach it to?
I ONLY use hand straps, i don't use shoulder straps at all anymore, i don't like them.
Rob
Robert Bell - Inspired Photography (formerly "Inspired Graphix" [and "Shooter-Boy" a long time ago])
email: info@inspiredphotography.net.au
Inspired Photography is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #12
sapearl
emailed Tim some prozac
sapearl's Avatar
I have the 24-105 mounted on one body, and the 70-200 on a second body, and both have neck straps. The smaller lens/body will be around my neck, and the long zoom is on my shoulder.
I don't have any grips, but the body with the 24-105 has a hakuba style hand strap on it.
5D x 2|580ex X 2 |17-40L |24-105 4L IS |70-200 f/2.8L IS
Hasselblad 503CW | 50, 60, 80, 150mm Zeiss
| Bogen Tripod | Newton CR Bracket
R1800 Printer | Lumiquest & Apollo Diffusers | CS3 |
MY WEBSITE - MY GALLERIES - MY BLOG
sapearl is online now   Reply With Quote
Old 30th of June 2007 (Sat)   #13
italianfemmy
Ya'll have the 70-200 just hanging on the body? Wow.. that's a lot of weight and doesn't it put a lot of torque and wear and tear on the part of the camera where the lens screws on?
italianfemmy is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #14
liza
It really isn't that heavy once you become accustomed to it. You tend to build upper body strength with frequent use. And the camera is designed to accommodate long zooms.
Old 30th of June 2007 (Sat)   #15
LeesaB
"Patience is a what? "
LeesaB's Avatar
I use two bodies, I always worry about dust when i switch lenses..
as far as weight...I work out..and do exxtra upper body for the lens...
Trust me, one wedding without working out and your shoulders feel like they are going to explode....
LeesaB
www.LisaNikole.com
LeesaB is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Might switch from 70-200/4L to 70-300IS... Mrvile Canon EF and EF-S Lenses 22 25th of July 2007 (Wed) 18:10
70-200 2.8L usm focus switch effects mxer82 General Photography Talk 10 6th of June 2007 (Wed) 11:41
Focus switch on the 70-200 f4 curiousgeorge Canon EF and EF-S Lenses 1 28th of July 2006 (Fri) 15:28
Question On the Focus distancing switch 70-200 f4L tomvill Canon EF and EF-S Lenses 4 18th of March 2006 (Sat) 10:34
Switch on Canon 70-200/2.8L jeveos Canon EOS Digital Cameras 7 29th of September 2003 (Mon) 23:17
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
