Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 30th of June 2007 (Sat)   #1
bcurtis91
bcurtis91's Avatar
Exclamation RAW & Photoshop CS EOS-1Ds ok Rebel XTi not??
Latest version (2.4) of Camera Raw plugin installed - Photoshop CS opens raw images from a Canon EOS-1Ds Mark II just fine, file ext is .CR2 however when trying to open Canon Rebel XTi images in Photoshop it tells me it could not complete my request because it is not the right type of document, these also have the .CR2 extension. any ideas?
bcurtis91 is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #2
vic6string
Default Re: RAW & Photoshop CS EOS-1Ds ok Rebel XTi not??
The XTi has the new dust delete data feature that embeds some new info into the picture in order to work. My guess is that while they kept the same extension, the new data somehow confuses anything looking for the old cr2 files. The XTi has been out for some time now, so chances are there is a patch for the XTi's cr2 files on the web.
Rebel XTi, 430ex, Tammy 28-75, nifty fifty, kit lens, tons of reading, not enough practice, and two gorgeous subjects (my kiddies)
vic6string is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #3
PacAce
Moderator
PacAce's Avatar
You need at least Camera Raw 3.6 to be able to process the XTi raw files. That means you need to be on PSCS2 or later. PSCS won't be able to do that unless you convert the XTi raw file to the DNG format first with the latest version of the DNG converter program.
...Leo
PacAce is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #4
DavidW
As PacAce says, you need support in Camera Raw for your particular camera. You have two options - use DNG Converter 4.1 to convert the RAW files from the XTi to DNG, the use the DNGs with Photoshop CS / Camera Raw 2.4, or upgrade to Photoshop CS3. Whilst the latter costs money, I believe there's significant and worthwhile enhancements in Photoshop CS3 - not least all the new features of Camera Raw 4.1.
David
DavidW is offline   Reply With Quote
Old 30th of June 2007 (Sat)   #5
tzalman
Fatal attraction.
tzalman's Avatar
Every Canon model has a different version of the RAW format. Between the CRWs and the CR2s there must be better than a dozen Canon RAW formats running around out there. I think they do it just to annoy the third party companies.
Elie / אלי
"If you presume to love something, you must love the process of it much more than you love the finished product." John Irving, 5/2012. "In theory there is no difference between practice and theory, but in practice there is." Yogi Berra
Site
tzalman is offline   Reply With Quote
Old 2nd of July 2007 (Mon)   #6
bcurtis91
bcurtis91's Avatar
Thanks for info. It's pretty frustrating, but I guess I'll have to consider upgrading to CS3.
Old 2nd of July 2007 (Mon)   #7
Xico
If you are happy with cs2, (like me) and don't want to spend more money, just go with Camera Raw 3.6. Works for me.
Xico is offline   Reply With Quote
Old 2nd of July 2007 (Mon)   #8
DavidW
The original poster has Photoshop CS. With Photoshop CS2, upgrading to Camera Raw 3.7 would have solved the problem.
David
Old 5th of July 2007 (Thu)   #9
bcurtis91
bcurtis91's Avatar
Just wanted to update this thread, I had to use the DNG converter from the 3.7 Camera Raw version (not the 3.7 camera raw plugin, though) The DNG converter from my current version 2.4 camera raw, did not recognize the the xti raw files.
Thanks for all the help, I'm going to wait a little to upgrade to CS3, I know it'll be worth the $ -- I really want to get some new lenses first. This is a great forum, I'm new to the DSLR world and have spent hours reading some of the very helpful tips on this site.
Betsy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rebel XTi RAW and Photoshop CS Gerdav43 RAW, Post Processing and Printing 2 15th of December 2006 (Fri) 20:36
rebel xti raw and problems opening in ps cs2 and bridge, and raw shooter webejamn RAW, Post Processing and Printing 2 16th of November 2006 (Thu) 12:02
EOS 300D - Raw files & Adobe Photoshop 7 djonto RAW, Post Processing and Printing 6 6th of March 2005 (Sun) 18:00
Camera Raw format for 1DS Mark II and Photoshop CS jhankins Canon EOS Digital Cameras 1 3rd of December 2004 (Fri) 20:22
