#1 |
I'm ordering a couple of new 4GB CF cards and I needed to know if anyone knows if the read/write speed of the CF card really makes a difference.
I contacted Canon tech support and the guy said the read/write speed on the 30D is a non-published specification and that they also did not have access to the information. All he said was that he could tell me that the speed of the card had no bearing on how fast the camera would write to it; whether the card was rated as a 33x or 133x, the camera would write to it at the same speed no matter what. Has anyone found this to be true? Should I just get 3 Sandisk Ultra II CF cards instead of 2 Sandisk Extreme IV CF cards? |
| sponsored links |
#2 |
I think the only difference will be in transfer speed from the card to the pc.
#3 |
| sponsored links |
#4 |
I'm comfortable with my masculinity
I don't buy faster than ultra II. When a camera that can write that fast comes out then I'll buy faster.
jasonhollister.com Think your camera is noisy at high ISO? Click here People will always try to stop you doing the right thing if it is unconventional |
#5 | |
http://www.robgalbraith.com/bins/mul...e.asp?cid=6007 Now how much difference is worth paying for is up to you and you have to consider future bodies too, perhaps. But my original Kingston card that was fine on my 300D is a dog on my 20D. I opted for the cheap, fast, and apparently pretty good Transcend 120x cards.
Canon 5DMkII, 7D, 40D, Elan 7E, EOS 10s, G12 50 f/1.8, 100 f/2, 400 f/5.6L, 18-55 IS, 24-105 f/4L IS, 70-200 f/4L IS Kenko 1.4x T-con, 430EX |
#6 |
from the testing that robG has done, the ultra 2, extreme 3, extreme 4 all seem to top out in the existing cameras, so not much benefit right now, so i don't buy above ultra2 either
#7 |
Boosting Ruler Sales
Check here: http://www.robgalbraith.com/bins/mul...?cid=6007-8478
Yes, card speed does matter. I don't know who you talked to at Canon, but methinks you didn't get the best information. After looking at Rob Galbraith's chart for the 30D you will have to decide whether the difference between an Extreme IV and an Ultra II is worth it to you - but certainly you would see a difference if you got a plain-jane Sandisk card. One difference you might notice is the number of frames in a burst before the camera slows down, as well as the sustained speed once the buffer is full. As opposed to older Canon DSLRs, the buffer does not have to be emptied out completely before you continue to use burst mode. Hope this helps. Have Fun, |
#8 | |
#9 |
Have to agree. Buying anything above Ultra II is... well basically a waste. And is anyone really in such a rush to get them up on screen any faster than that?
The Manufacturer point is more important. |
#10 | |
Sometimes Sandisk (and others) run specials on the fast cards that make them almost the same price as the lesser models. Think about where you will be camera-wise in the next couple years, and whether the cards you buy today will be slowpokes then - maybe stagger your purchases so you have at least one of the fast cards. Just a thought. Have Fun, |
#11 | |
Have Fun, |
#12 |
For me, it pretty much comes down to : How important is burst mode to you? Especially if you shoot raw. Copying to the PC is moot IMHO and should not be a factor in choosing a CF card.
If burst mode / rapid shooting is NOT important at all, I would have chosen the cheap 4gb microdrives ( 2x4gb for $19!! 3wks ago).
Canon 30D Canon EF 24-105mm F4L, 28-135mm F3.5-5.6, 50mm F1.8 Canon 580EX II Nexto OTG ND-2300 120gig Portable Photobank |
#13 |
I have both the Ultra 2 and Extreme 3 cards. There is a noticeable difference in how fast my camera can process the RAW pictures, when I am shooting continuously. If you don't shoot like that often, then the Ultra 2's will probably work just fine.
Canon 6D, T4i, lenses, a G1x & an S110 |
| Thread Tools | |
| Display Modes | |
| memory card read/write speed? | cronnin | Accessories & Storage | 2 | 25th of June 2007 (Mon) 16:26 |
| Does card write speed matter at all for the G7? | Toogy | Canon G-series Digital Cameras | 5 | 21st of November 2006 (Tue) 14:46 |
| powershot a510 - very slow to read and write to SD | reemas | Small Compact Digitals by Canon | 8 | 29th of November 2005 (Tue) 00:17 |
| Who knows about CF read/write speeds then? | Jonny | Accessories & Storage | 20 | 30th of September 2005 (Fri) 13:21 |
| EOS 10D - Maximum Write Speed to CF Card? | dfuccillo | Canon EOS Digital Cameras | 7 | 13th of April 2005 (Wed) 21:27 |
