Reply
Thread Tools Display Modes
Old 16th of June 2002 (Sun)   #1
simmonsrandal
Default iso and f-settings.
What iso settings and f settings are best for pictures. IE, what are good for day or night shots?
flash or no flash.
I understand shutter speed but the iso and F settings give me trouble. Anyone have a link where these are explained on line?
simmonsrandal is offline   Reply With Quote
Old 30th of November 2002 (Sat)   #2
simmonsrandal
Default Re: iso and f-settings.
bump!
Old 7th of December 2002 (Sat)   #3
xolstis
ISO settings are films speeds. Not sure about the technical parts of it but basically low ISO settings (50/100 etc) are for bright sunny days. 200/300 is best used for cloudy days while 400 is touted as an all round setting. As in use in any condition, however do note that increasing ISO speeds tend to make ur pictures grainy.
Of F-stops I believe they're measurements for aperture size.....the hole which lets light into the camera on the lense. A larger hole would mean more light in and brighter pics. Something like what a long shutter speed does. But the other issue of aperture is the affect on the depth of field. I am not very good in this part of it tho so will let someone else help u out here = ). Note that a smaller number denotes a larger aperture.
xolstis is offline   Reply With Quote
Old 17th of December 2002 (Tue)   #4
trammd
Large apeture= small depth of field
Small apeture= large depth of field
Any iso above 100 will probably add much graininess to the shot for most tastes.
trammd is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ISO settings? StellerCrys General Photography Talk 6 24th of July 2007 (Tue) 01:07
ISO settings what do you use and when weka2000 General Photography Talk 21 25th of May 2006 (Thu) 23:16
HELP - Cant Get ISO Settings to Come Up Gizmo1985 Canon EOS Digital Cameras 11 17th of April 2006 (Mon) 09:13
ISO settings jbravi Canon EOS Digital Cameras 4 25th of February 2006 (Sat) 18:41
ISO Settings samdring Canon EOS Digital Cameras 8 13th of October 2003 (Mon) 03:31
