What size is the hood for the 24-105L IS?
pwm2 "Sorry for being a noob" ![]() 8,626 posts Likes: 2 Joined May 2007 Location: Sweden More info       | Jul 05, 2007 20:22 | #1 What size is the hood for the 24-105L IS? 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
JKSeidel Member 111 posts Joined Oct 2006 Location: Miami, FL More info       | Jul 05, 2007 21:08 | #2 Err, what do you mean by size? It is a petal style hood (EW-83H) that was redesigned after testers found fault with the original Canon design. The original hood never made it to market from what I understand. Jeffrey
darkvibe Senior Member 295 posts Joined Apr 2006 Location: Rochester, NY More info       | Jul 05, 2007 21:22 | #3 not sure what you're asking. It's a 77mm bayonet mount petal style. 4 3/16" diameter at the end, 1 11/16" long. http://www.darkvibe.org/gallery/
pwm2 THREAD STARTER "Sorry for being a noob" ![]() 8,626 posts Likes: 2 Joined May 2007 Location: Sweden More info       | Jul 05, 2007 22:51 | #4 darkvibe wrote in post #3494415 ![]() not sure what you're asking. It's a 77mm bayonet mount petal style. 4 3/16" diameter at the end, 1 11/16" long. Yes, with size I meant the physical dimensions. That is required information to know if lens + hood may fit in a specific bag. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
darkvibe Senior Member 295 posts Joined Apr 2006 Location: Rochester, NY More info       | Jul 05, 2007 23:37 | #5 I follow you now. Yeah, the lens hood is over 4" in diameter. The 4 3/16 was across the larger two petals, the top and bottom. Across the smaller petals on the sides it's 4 1/8". Those are to the outside of the hood. http://www.darkvibe.org/gallery/
pwm2 THREAD STARTER "Sorry for being a noob" ![]() 8,626 posts Likes: 2 Joined May 2007 Location: Sweden More info       | Jul 06, 2007 00:06 | #6 My assumption is that the lens pouch that is supplied with the lens is similar to what is supplied with the extenders. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] ![]() More info       | Jul 06, 2007 10:21 | #7 Go to http://www.lowepro.com/camera_matrices.aspx You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
pwm2 THREAD STARTER "Sorry for being a noob" ![]() 8,626 posts Likes: 2 Joined May 2007 Location: Sweden More info       | Jul 06, 2007 12:30 | #8 Can I assume that you recommend Lens Case 1W, and not Lens Case 1? 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] ![]() More info       | Jul 08, 2007 22:53 | #9 pwm2 wrote in post #3497758 ![]() Can I assume that you recommend Lens Case 1W, and not Lens Case 1? The LC1 would be a perfect fit for a 24-105 without hood. LC1 is smaller than LC1W so if your 17-55 fits snuggly in an 1W, you would have to be violent to fit it in a LC1. And if I don't buy a EW-83J separately, the original hood for the 24-105 may be even wider than the 17-55 hood. I was pointing out that a 24-105 with the usual Canon hood should fit in the Lowepro 1 case; Lowepro recommends the 1W case for my 17-55 with standard Canon hood and it fits fine. If instead you put a hood intended for a different lens, such as EW-83J on the 24-105 lens fitted on an APS-C body, the Lowepro-recommended case might not fit, since you are using a different hood with a different diameter. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
canonwire Hatchling 2 posts Joined Jun 2007 More info       | Jul 08, 2007 23:51 | #10 if you flip the hood, it should definately fit anyways, right?
pwm2 THREAD STARTER "Sorry for being a noob" ![]() 8,626 posts Likes: 2 Joined May 2007 Location: Sweden More info       | Jul 09, 2007 00:35 | #11 Part of the reason for the thread is that I think that the Lowepro list has to be taken with more than a pinch of salt. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] ![]() More info       | Jul 09, 2007 10:11 | #12 Thanks for pointing out the inconsistency of the Lowepro chart You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
pwm2 THREAD STARTER "Sorry for being a noob" ![]() 8,626 posts Likes: 2 Joined May 2007 Location: Sweden More info       | Jul 09, 2007 10:28 | #13 Ah, you are correct. I must have glanced at the 1N or 1S. 5DMk2 + BG-E6 | 40D + BG-E2N | 350D + BG-E3 + RC-1 | Elan 7E | Minolta Dimage 7U | (Gear thread)
y 1600 |
Log in |
Latest registered member is Roberto Betta 621 guests, 290 members online Simultaneous users record so far is 6430, that happened on Dec 03, 2017 |
