Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 5th of July 2007 (Thu)   #1
bwolford
bwolford's Avatar
Default HDR from a single file
The OP in this thread:
http://photography-on-the.net/forum/...d.php?t=344394
Says he creates his HDR from a single file. I supposed he must create three "levels" of the image (using levels or curves) and the uses HDR to process. He also claims his source is JPG. No reason not to believe him. He does some fantastic work.
Any thoughts on how to achieve HDR like results from a single exposure?
Brice
Sample Gallery
bwolford is offline   Reply With Quote
Old 5th of July 2007 (Thu)   #2
Picture North Carolina
Gaaaaa! DOH!! Oops!
Default Re: HDR from a single file
Are you sure you posted the correct link? I see some great wedding photography there, but no shots that have anything to do with hdr. /Dan
Edit: I see now (later in the thread). Single file processing in photomatix tends to add saturation and pop. But do not be confused. Although his post-processing is great, what makes these photos work is his unique style, composition and interesting angles. Up in the air above his subject, down on the ground below, etc. /Dan
Fine Art America | Red Bubble | Website | Blog
Gear list: Mine is bigger than yours.
Picture North Carolina is offline   Reply With Quote
Old 5th of July 2007 (Thu)   #3
carpenter
I create mine from one jpeg file. I like my HDR style a little more painting like though. I use 5 exposures in 1 stop increments.
carpenter is offline   Reply With Quote
Old 5th of July 2007 (Thu)   #4
danpass
danpass's Avatar
Just set the exposure 0, -2 (and save) and +2 (and save)
then combine the three "separate" files.
Photomatix kinda freaks though "Same File!" but you can input the exposure values manually when the popup window appears.
Always seemed pretty obvious to me to do it that way; if you wanted to HDR an action shot for example.
_
Dan
Gallery | Gear/Feedback
danpass is offline   Reply With Quote
Old 5th of July 2007 (Thu)   #5
Tsmith
Formerly known as Bluedog_XT
Tsmith's Avatar
If its from a single file then it will not be an HDR, no matter how many duplicates you make with it adjusting the exposure. A single image will only allow you so much room for adjustments. Thats the beauty of the HDR process from multiple exposures is it gives you a wider Dynamic Range (hence HDR) to work with.
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS
Canon PowerShot S95
MY PBASE GALLERY
Tsmith is offline   Reply With Quote
Old 6th of July 2007 (Fri)   #6
Gaaaaa! DOH!! Oops!
Originally Posted by danpass View Post
then combine the three "separate" files... if you wanted to HDR an action shot for example.
Thankfully somebody said it. This debate goes back on potn for over a year. It seems almost pointless any more to try to get people to understand that "HDR processing" a single file does NOT create an HDR image. It would be more accurate to say you are "tone mapping" or rather "enhancing" a single file using photomatix.
An HDR image is only created from two or more separate (and differing) exposures.
Why do so many of us try to continually correct this point? It has nothing to do with who is right or wrong. I has to do with newbie photographers and newbie HDR'ers. If they are initially misinformed about what HDR is, they may never experiment with true HDR images and experience the benefits of truly increased dynamic range in an image. /Dan
Old 6th of July 2007 (Fri)   #7
carpenter
So what's the difference if you bracket your shot or later edit it in photoshop with several exposure values then generated and HDR file. Why wouldn't that image be considered an HDR image if you are merging 3-5 pictures in varying exposure taken from one jpeg file?
Now I understand you will get a wider range and more deatil and such doing an HDR file with the proper technique of using the cameras exposure to shoot 3 seperate pictures.
Old 6th of July 2007 (Fri)   #8
Gaaaaa! DOH!! Oops!
One question:
If you have a single file that contains a finite dynamic range and produce a number of different files from it, have you extended the dynamic range of that original file beyond what was originally contained in that single file? /Dan
Old 6th of July 2007 (Fri)   #9
Padawan Dad
Padawan Dad's Avatar
Personally, I agree that to take full advantage of HDR you need to do bracketing to get a broader dynamic range and to create "true" HDR.
However, in the case of the OP, and the subject of the OP, whatever you want to call it, the use of taking one image and creating several different exposures from it, create results that could not be acheived otherwise. It's a very useful tool and method to create out of the ordinary, and in some instances, breathtaking results; whether "true" HDR, or not, it produces unique images.
Nikon D700 • 50 ƒ/1.4G • 24-70 ƒ/2.8 • 70-200 ƒ/2.8 VRII SB900  iMac
Padawan Dad is offline   Reply With Quote
Old 6th of July 2007 (Fri)   #10
PacAce
Moderator
PacAce's Avatar
...Leo
PacAce is offline   Reply With Quote
Old 6th of July 2007 (Fri)   #11
Gaaaaa! DOH!! Oops!
Bill, with all due diplomacy and respect, I think you missed the entire point of the thread. None of the posters said the PP involved did not create a good image. The entire discussion is about what is and what is not a true hdr file. Regards, /Dan
Old 6th of July 2007 (Fri)   #12
Padawan Dad
The OP asked: "Any thoughts on how to acheive HDR like results from a single exposure?"
I don't believe I missed the entire point at all; I think that some people just veered a bit off of what the OP was originally asking, and are turning this into yet another "what is true HDR thread," which is NOT what the OP asked.
Old 6th of July 2007 (Fri)   #13
bwolford
bwolford's Avatar
Ah, so you think he's using Photomatix. I missed that. I agree his photos work because his style. I was just wondered how HDR could be created from 1 exposure. Thanks for the tips.
Brice
Brice
Sample Gallery
Old 6th of July 2007 (Fri)   #14
bwolford
bwolford's Avatar
I understand it's not a true HDR because of just one exposure... It just seemed to me that using a JPEG to accomplish it in PHOTOSHOP (I should have been more specific in the first post) seemed to be a not so obvious solution. Photomatix, based on the posts here, seems to be a candidate.
Although, I am not interested in more software. I'll stick with PSCS2 and start my experiments with HDR using multiple exposures.
Brice
Sample Gallery
Old 6th of July 2007 (Fri)   #15
Padawan Dad
Brice
Brice,
I actually asked him about this, and he did say he does use Photomatix.
EDIT: Wait a minute.... Actually, I read it on his website (that he uses photomatix.)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
I DID HDR FROM A SINGLE RAW!!!!!!!!!!! big files. RianFlynn HDR 109 28th of September 2008 (Sun) 01:23
Stonehenge - Single RAW File Pseudo-HDR hairycrab Nature & Landscapes 2 16th of July 2007 (Mon) 10:38
HDR vs. single frame image - your opinions are valued Picture North Carolina Critique Corner 17 26th of December 2006 (Tue) 14:17
Photomatix single file comparison Tsmith Critique Corner 2 31st of August 2006 (Thu) 11:09
Single RAW file test HDR image: opinions Tsmith Nature & Landscapes 17 24th of July 2006 (Mon) 19:44
