Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 10th of June 2004 (Thu)   #1
CyberDyneSystems
Admin - MOD OF STEEL...
CyberDyneSystems's Avatar
Default
Under Constuction!
An error has messed up Scottes' first posts in this thread. For now all the info is safe is this post..**
Originally Posted by Scottes
Rather than making every tutorial here Sticky, I'm creating this one topic which will contains links to tutorials. So when the original tutorial topics rolls to page 2 there will always be a link to it kept here in this topic.
If you create a tutorial and post it to the forum please reply to this thread with a simple description and a link to the thread.
Post Processing #1 -
Very Basic Contrast Tutorial
Post Processing #2 -
Straightening and Cropping
Post Processing #3 -
Sharpening and Saving
Post Processing #4 -
Cropping
Post Processing #5 -
Camera to JPG, Quickly
Quick and simple preparation of an image. This is - more or less - my normal PS workflow and takes about 2 minutes per image.
Post Processing #6 -
Quick Keys
Using "quick keys" to select tools, commands, etc. My cheap lazy attempt for a tutorial tonight.
Post Processing #7 -
Replacing The Sky
Thoughts and comments on replacing a sky, along with a tutorial explaining how I did one. Only 2 images, lotsa words. Compatible with just about any version of Photoshop, though somewhat advanced and certainly a lengthy process if you do it this way...
PS Tutorial - Resizing Images Using Save For Web
CA Correction with PS CS RAW Converter
Correcting Chromatic Aberration
Masking for Noise Reduction (and Sharpening! Big!)
How to create a mask to protect details when running noise reduction on your images. And more tidbits with masks.
Creating An Avatar in Photoshop & Paint Shop Pro
Step-by-Step instructions with a couple of screen-shots for Paint Shop Pro
Maderito's Exposure Challenge;
Correcting under-exposure with CURVES
Schmoelzel's Post Processing Workflow explained
PSCS RAW Workflow
rpolitsr's Depth Maps for Lens Blur Filter in PhotoShop CS
TimmyQuest's Tutorial on;
Converting to Black and White
Not a Tutorial but,
A Discussion on a number of Sharpening methods
Roger Cavanagh On Sharpening Raw files,
Camera Raw and Sharpening
Let's all keep this thread reserved for "in house" Canon Digital Tutorials ONLY
No links to other work.. only work that we generate ourselves.
Also,. Other than my own current ramblings.. (which will be here only on a temporary basis) ...we are keeping this thread for the posting of Links to tutorials only. All others will be deleted
CyberDyneSystems is offline   Reply With Quote
Old 10th of August 2004 (Tue)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default "Contrast Control" Tutorial, (sort of).
UPDATED 11/4/04
So, you've got an image of a polished aluminum aircraft in the bright sunlight, & half the pic is blown out.
Here's the Tut I used to try to fix the pic.
Selecting areas in PhotoShop
UPDATED 10/24/04
There are many ways to make selections, & they can be really difficult to get right if you only use the "automatic" methods. If you're having problems getting a good selection of a large, solid object like a car, then try this.
Need to remove a background from something?
I shot a '37 Willys last night. It seemed to be too pretty to just leave it in the parking lot! So I made a background for it.
If you're having trouble understanding what a Layer Mask does, this might help.
PS Blend modes can make a shot out of "nothing"!
This is simple stuff when you know the "secrets"! Shoot some skies with clouds, trees that would look good in the background, etc., & save them in a file... you’ll be glad that you did!
Out of Gamut: Thoughts on a Sharpening Workflow
This is a great sharpening overview that has something for everyone!
Example of Layer Masks for detailed changes.
See my posts.
It started on this thread where I posted the workflow: ***/// Creating this in CS...
Then finished in this one with an example: Airport runway shoot
Layer mask in Elements 4.0
http://photography-on-the.net/forum/...d.php?t=237985
New to layers?
Layers, Layers, Layers (Part 1 for beginners)
EXIF: EXIF info can be important when you have a problem image to ask questions for us to answer. Try to include it when you post an image because sometimes we can find things in the image & the EXIF that you haven't thought to mention.
In Photoshop this can easily be done by using "Save As", instead of "Save For Web" which gives a slightly smaller file size, but really doesn't tell us anything.
Schmoelzel's thread By popular request....workflow tutorial. on correcting blue, underexposed images.
PhotosGuy is online now   Reply With Quote
Old 26th of October 2004 (Tue)   #3
Jesper
Jesper's Avatar
Default
A number of interesting documents from Adobe:
http://www.adobe.com/digitalimag/ps_pro_primers.html
including:
Digital Workflow for Raw Processing
Calibrating the Digital Darkroom Environment
A Color Managed Raw Workflow
Making the Transition from Film to Digital
Highlight Recovery in Adobe Camera Raw
Please visit my gallery!
Canon EOS 5D
EF 24-105 f/4 L IS, EF 70-200 f/4 L IS, EF 35 f/2, EF 50 f/1.8 II, EF 100 f/2.8 Macro USM
Extender EF 1.4x II, Speedlite 550EX
Jesper is offline   Reply With Quote
Old 14th of November 2004 (Sun)   #4
PacAce
Moderator
PacAce's Avatar
Default
Using linear conversion to process RAW files may allow you to recovery details from blown areas.
Click here for details
..Leo
PacAce is online now   Reply With Quote
Old 21st of January 2005 (Fri)   #5
Jesper
Jesper's Avatar
Default Re: Post Processing Tutorials List
Lots of Photoshop tutorials, plug-ins, actions, etc. here:
http://www.photoshopsupport.com/
Canon EOS 5D
Old 10th of February 2005 (Thu)   #6
Jesper
Jesper's Avatar
Russell Brown's Photoshop Tech Tips
Lots of scripts for Photoshop, Dr. Brown's Image Processor is a "famous" script for batch processing in Photoshop.
Canon EOS 5D
Old 12th of February 2005 (Sat)   #7
gary_hendricks
gary_hendricks's Avatar
I've just created a new tutorial on organizing your digital photo collection.
Tutorial: How to Organize Your Digital Photos
Gary Hendricks
Basic-Digital-Photography.com
gary_hendricks is offline   Reply With Quote
Old 9th of March 2005 (Wed)   #8
PacAce
Moderator
PacAce's Avatar
Another link to useful articles/tutorials (check out the PDFs at the lower half of the page under Resources):
http://www.adobe.com/digitalimag/ps_pro.html
..Leo
Old 9th of March 2005 (Wed)   #9
chris.bailey
A quicky on healing and cloning in CS
http://photography-on-the.net/forum/...ad.php?t=61319
chris.bailey is offline   Reply With Quote
Old 13th of April 2005 (Wed)   #10
Tom Reid
Tom Reid's Avatar
Sports - Team Collage
Tom Reid is offline   Reply With Quote
Old 30th of May 2005 (Mon)   #11
gastroboy
Anandtech (a technology review site) posted this post-processing guide for PSE and PS. Here's the link, it may be usefull for newbies (it was for me)
http://www.anandtech.com/digitalcame...oc.aspx?i=2380
gastroboy is offline   Reply With Quote
Old 8th of June 2005 (Wed)   #12
rgravel
rgravel's Avatar
For those who want to use DPP
http://photoworkshop.com/canon/dpp/
Robert Gravel www.robertgravel.ca/
EOS 40D + grip, EF 400 f5.6 L, EF 70-200 f2.8 L, EF 100 f2.8 macro, EF 17-40 f4 L, 430 EX, EOS Elan 7N, SD-200
rgravel is offline   Reply With Quote
Old 18th of July 2005 (Mon)   #13
Rick Baker
Copyrighting Your Images and Deterring Image Theft
This article explains how to copyright your images and also some techniques to deter image theft, such as watermarking and protecting with JavaScript.
http://www.rickbakerimages.com/photo...ur_images.html
I hope this is helpful.
Check out my gallery, read photo how to articles and discuss photography here:
I love Canon and use them almost exclusively!
Rick Baker is offline   Reply With Quote
Old 18th of July 2005 (Mon)   #14
Rick Baker
Using Adobe Photoshop to Make Panoramas
Some advice on getting good photos to make panoramas with in Adobe Photoshop and then how to stitch them together with Photoshop's Photomerge feature.
http://www.rickbakerimages.com/photography_advice/photomerge_panoramics.html
Old 18th of July 2005 (Mon)   #15
Rick Baker
How to Edit, Resize and Print Your Photos in Photoshop
this is a a very basic article for beginners on how to do some very basic editing, resizing and printing in Adobe Photoshop. If you have Photoshop and a digital camera and are wondering how to brighten, darken, saturate, sharpen, crop your photos and then resize and print them check it out.
http://www.rickbakerimages.com/photo...nt_photos.html
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
-=Photography Tips and Tutorials List=- CyberDyneSystems General Photography Talk 27 12th of October 2009 (Mon) 05:51
Can anyone recommend links, tutorials or books for PhotoShop post-processing? TMR Design RAW, Post Processing and Printing 2 10th of September 2006 (Sun) 14:08
Elements 2-specific processing tutorials jfred RAW, Post Processing and Printing 5 12th of February 2006 (Sun) 23:28
Good Photoshop processing tutorials? PekkaM RAW, Post Processing and Printing 2 14th of January 2004 (Wed) 08:38
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
