#1 |
Several of the members have said that some of their shots of stationary objects are often slightly out of focus using AI Servo instead of One Shot. During a wedding I usually keep it in AI Servo due to the isle walking shots and others that can turn into action and I have had no problem. what mode is most used during weddings, and has anyone ever noticed this problem in AI Servo?
1D MKIIN 30D 20D and G6 35L 85L 400L 17-40L 24-70L 24-105L 70-200 f/2.8L IS 10-22 f3.5 60 Macro |
| sponsored links |
#2 |
"I like pictures of myself!"
I 100% use one shot mode, I don't trust any other mode. But that's just me. But I am constantly re-adjusting focus, just the way I shoot. YMMV.
#3 |
User is banned from forums
| sponsored links |
#4 |
AI Servo for processional, recessional, church exit. One Shot for all else.
keep in focus... Ed Kanney Certified Professional Photographer www.kanneyphotography.com |
#5 |
I use AI servo just for the walk down the isle. everything else is one shot. I like hearing the beeps... sad but true...
5D 580EX Canon 24-70mm L F2.8 Canon 50mm 1.8 MkII Hoping to add more soon |
#6 |
Man turn off the beep!!! nothing screams amateur more than auto focus confirmation!! at least to me!
And plus if I had the beep on my camera, it would get annoying because of how often I re-adjust my focus. |
#7 |
I think I will try this next time.
#8 | |
i need to have the beep, too use to it and now it's ocd, if i'm using ssomeone else's camera and it has the beep turned off, i go nuts heh,
Sumozebra Photography Camera: Canon EOS 5D Mark II | Canon EOS 300D IR | G9 | Lumix LX3 | Printers: Canon IPF6100, Canon Pixma Pro9000, HP Indigo 3050 |
#9 | |
But you can have the best of both worlds. CF function 4 allows you to use the * button back to focus. If you set your focus button to that and use Servo focus when you have acheived focus you simply release the * button and the camera stops focussing, and then use the regular shutter button to fire the shutter. If the subject moves, simply press the * to acquire focus again. Somewhere on the web there is a white paper on the Canon AF system which is very valuable. I've lost the link but it's worth googling it as there is a lot of info there about how the whole AF system works. Many users report AF problems when they really don't understand how the cameras AF works. Mike
Newfoundland Wedding Photographer |
#10 | |
I guess I never really thought about changing it. I will have to try it without sound and see if I like it. and I am an amateur, so I guess it does suit me fairly well.
#11 |
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
Prior to owning a Mk3, all of my cameras have been set about 99% of the time to AIservo with CF 4-1
To me this is both AIservo and single shot in one setting, all that changes is how long I keep my thumb on the * button. I agree with Mike, that AIservo is just as effective if used properly. |
#12 |
Hiding Under a Rock
I only change to AI Servo when they walk in or walk out of the church (or during portraits walking). I don't like AI Focus as it kicks in the AI Servo when you least want it, so I use the Single shot about 99% of the time, and only use AI Servo during entrance and recessionals.
/Petra Hall Click here to view my geeky gear list I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink |
#13 | |
#14 | |
And another benefit is that it seperates the cameras metering and focus .. so you can lock the meter with a half-press of the shutter button and then do the focus with the * button. Mike
Newfoundland Wedding Photographer Last edited by mmahoney : 10th of July 2007 (Tue) at 13:00. |
#15 | |
Just out of curiosity, what do you use with the Mk3?
30D w/grip, 28-105 f/3.5-4.5 NIS NL, 75-300 f/4-5.6 NL, 18-55 f/3.5-5.6 NL, 550EX, lots of energy and creativity. |
| Thread Tools | |
| Display Modes | |
| drive mode (ie single shot or ai servo) | mrkeenan0 | General Photography Talk | 2 | 27th of June 2007 (Wed) 21:39 |
| 1 single Hype R shot . | DevinL. | Transportation | 6 | 18th of May 2007 (Fri) 06:36 |
| Problem with 2nd shot in Single Shot Mode | Jim Arnold | Canon EOS Digital Cameras | 3 | 21st of November 2006 (Tue) 12:16 |
| Single shot of my uni | timmytimmytimmy | Critique Corner | 5 | 16th of October 2006 (Mon) 21:26 |
| Mk2N VS 5D.....single AF point, in Servo? | SeanH | Canon EOS Digital Cameras | 13 | 20th of August 2006 (Sun) 02:27 |
