Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 10th of July 2007 (Tue)   #1
abqhudson
Default Which one - a different twist.
Recently my wife and I went to a horse race and watched from the rail. We tried unsuccessfully to take a picture of the horses. The problem is the time lag between pressing the button and taking a picture - our Canons were too slow. So we got pictures of the track, but, the horses were long gone. Our cameras are the Power Shot A510 and A530.
Which Canon point and shoot has the least amount of lag - I don't find this spec on the Canon web site. Maybe, I don't know what to look for.
Any help will be appreciated.
Jim
abqhudson is offline   Reply With Quote
Old 10th of July 2007 (Tue)   #2
CheesyD
CheesyD's Avatar
Default Re: Which one - a different twist.
Did you try panning?
Sorry, but I don't know the answer to your question. I'm sure somebody here does, though.
CheesyD
PowerShot S410, S80, S5 IS
http://www.flickr.com/photos/28608586@N03/
"There are no rules for good photographs, there are only good photographs." -- Ansel Adams
CheesyD is offline   Reply With Quote
Old 11th of July 2007 (Wed)   #3
Cindi
Cindi's Avatar
Would a faster speed memory card help? I'm just guessing here.
~ Cindi ~
Rebel XTi/kit lens/nifty fifty
Powershot S2 IS
Cindi is offline   Reply With Quote
Old 13th of July 2007 (Fri)   #4
iddie
iddie's Avatar
i think panning would help. point and shoots usually freeze motion if it is on the auto mode. And on point and shoots there is a shutter lag, so right when you press the shutter button, the picture isn't taken, but there is a bit of delay before the actual picture is taken. Try panning even though you aren't going for the panning effect.
Photography noob, but im learning!
Canon EOS 30D w/ BG-E2 Battery Grip // EF-S 18-55mm f/3.5-5.6 // EF 24-70mm F/2.8L USM
Bogen Manfrotto 3021 Bpro legs w/ 488RC2 head
iddie is offline   Reply With Quote
Old 13th of July 2007 (Fri)   #5
Micky Daeus
Micky Daeus's Avatar
This is a shot using an S3 IS in Auto mode in good daylight. I had it in H]]] to try to get lucky with framing. When the horses were approaching I focused mid track and held the shutter half down then let fly as they came into screen. Shutter speed from EXIF was 1/1250 @ F4.0.
Micky Daeus is offline   Reply With Quote
Old 13th of July 2007 (Fri)   #6
eccles
eccles's Avatar
MIcky has hit the nail in the head. It is the camera's autofocus that makes up most of the shutter lag. By pressing the shutter release halfway down, Micky effectively prefocussed the camera ahead of the shot. Not only that, autoexposure is precalculated as well, resulting in low shutter lag.
Did your horse win, Micky?
eccles is offline   Reply With Quote
Old 14th of July 2007 (Sat)   #7
cmcleod69
cmcleod69's Avatar
You can also set the drive mode for multiple, and just hold the shutter release button down the whole time the horses go by...resulting in 8 to 10 shots to pick the best from. You can still pan with the horses as well.
CMcLeod
PS A620
cmcleod69 is offline   Reply With Quote
Old 24th of July 2007 (Tue)   #8
Micky Daeus
Eccles, this may answer your question.... I was quite surprised at how well the shots worked overall.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Different Self- with a twist hawk911 People 9 23rd of January 2007 (Tue) 01:58
Twist pinball Birds 1 6th of September 2006 (Wed) 19:39
Twist off F40 Still Life, B/W & Experimental 1 7th of September 2005 (Wed) 22:58
