Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 17th of July 2007 (Tue)   #1
canoflan
User is banned from forums
Default Portraits: manual flash and camera manual mode for consistency?
I have a family portrait coming up and have been experimenting with manual flash for consistency. I find I am learning what manual flash zooming does and how best to bounce for either full coverage lighting, or mood lighting from an angle.
Do you find on portrait shots where you have time to setup that you use manual flash and manual camera mode to ensure your adjustments produce consistent results from pose to pose? I think that if you can take about 5 test shots of your photo assistant (if you have one) using manual flash and manual camera mode, then you can be set and ready for simply posing the subjects vs ensuring TTL provides consistent exposures.
I will be performing a family portrait at the client's house and plan to use the flash about 80% flash/20% ambient light.
Thoughts? How would you do it?
canoflan is offline   Reply With Quote
Old 17th of July 2007 (Tue)   #2
picturecrazy
soft-hearted weenie-boy
picturecrazy's Avatar
Default Re: Portraits: manual flash and camera manual mode for consistency?
Yes, that's usually what I do. Flash in manual and camera in manual = every group photo can be batch processed later in one step! Manual rocks!
picturecrazy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
manual flash/manual camera ? sara505 Small Flash and Studio Lighting 61 17th of June 2006 (Sat) 20:03
Question on flash with camera in manual mode. LordV Canon EOS Digital Cameras 3 13th of March 2006 (Mon) 19:56
Does camera in Tv mode and flash in manual mode make sense? dphoto Canon EOS Digital Cameras 3 28th of September 2004 (Tue) 18:18
How to use Flash in Manual Mode.? Shafique Canon G-series Digital Cameras 0 15th of October 2002 (Tue) 09:37
Flash in manual mode ... ? miro Canon G-series Digital Cameras 3 22nd of October 2001 (Mon) 14:36
