#1 |
This is another underexposed image. It was underexposed on purpose so as to not blow out the highlights in the shirt. The resulting histogram is actually pretty good. But the subject is way underexposed. The pic was actually shot in very bright sunlight
The challenge is to improve the image using only curves and sharpening. The image was converted to sRGB. |
| sponsored links |
#2 |
Oh man.... homework?!
I'll try this one (when I get home from work) ... it's a lot like what I get when shooting the Egrets.
My latest project: www.RedRockAudubon.org LazyPhotographer: One who uses a telephoto lens to shoot pictures out the car window or from a balcony. |
#3 |
Trigger Man - POTN Retired
OK, I think I went in circles a bit. I'm not so good with color casts I think, and since Maderito said "curves only" that really threw me for a loop.
I didn't like some of the red, so I wanted to bring it down a bit. Curves, Red channel, 71, 65 ; 131, 124 ; 255, 248 That brought out some greens of course, so Curves, Green channel, 255, 248 Now I went to lift out the darkness: Curves, RGB, 47, 84 ; 126, 148 ; 208, 205 Well of course that brought out the blues, so Curves, Blue channel, 15, 0 Finally, my sharpening was USM at Amount 134%, Radius 0.3, Threshold 0 And save for web. Having such a small JPG as a starting point really stinks! Way too many anomalies for my eyes. So I went with Quality 80, but also added Blur 0.28 to reduce some blockiness, but this also destroyed a bit of my sharpening. The final result - I didn't dare go much further as things started looking bad: ![]() Comments appreciated. The colors threw me, probably unecessarily. But if this was a concert stage I might have been seeing colored spots - or I may have subconsciously been seeing them. Curves only. Ugh. I would have liked to attacked this using a PS 7-compatible selective shadow recovery.
You can take my 100-400 L away when you pry it from my cold, dead fingers. Scottes' Rum Pages - Rum Reviews And Info Finally, I have a Gallery! Follower of Fidget - Joined the cult of HAMSTTR© |
| sponsored links |
#4 |
I used three curve corrections, all on adjustment layers.
1. Color cast removal The cast is not obvious. Place a sample point in a shadow of the white shirt. The one I selected was R=114 G=123, B=129 The average luminance is 122. So we'll neutralize that point to Gray=122 and thus remove the small blue cast. This is important since neutral midtones will stay gray as we make other bigger changes. - Make a curves adjustment layer, name it "Color Correction" - Set the following points near the midpoint of the individual R/G/GB channel curves (you can use your own image sample point or enter these values from the one I used): Red channel curve: 114, 122 Green channel curve: 123, 122 Blue channel curve: 129, 122 We could have accomplished the same thing by using the Set Gray Point eyedroper in the curves dialog. 2. Gamma correction The image is way too dark. You lighten by increasing gamma. But you want to lighten without blowing out the whites of the shirt. Thus the gamma adjustment should affect the shadows more than the highlights. In levels, you increase gamma by moving the middle slider to the left. In curves, you bend the curve upward and to the left. - Create the second curves adjustment layer and name it "Gamma Correction". - Set 2 points in the main RGB curve, one to bring up the overall brightness weighted towards the shadow areas, and the second to reduce the correction in the highlights so as to maintain detail in the whites of the shirt. RGB curve point #1: 34, 75 RGB curve point #2: 179, 122 I then sharpened the image but it still seemed a bit dark, so I did one final adjustment to brightness. 3. Final brightness correction - Make a final curves adjustment layer and call it "Lighten". - Set the following point near the midpoint of the RGB channel: RGB curve: 111, 133 Almost done. When bringing out detail in a severely underexposed image, you get a lot of noise, especially in the darker portions of the image. Here's a simple, well-described method to reduce this noise. 4. Noise reduction - Duplicate the original background layer. - Blur the background copy with a Gaussian Blur, radius=5.0. - Set the blending mode to color. - Merge the two image layers. - Sometimes you have to increase saturation in the final result, but I didn't think it was necessary here. |
#5 |
User is banned from forums
#6 | |
Moderator
..Leo |
#7 |
This is fun to see how differents are the results.
Here is mine using uleadphotoimpact and some neatimage filtering. Jose ![]() |
#8 |
I duplicated the image twice in screen mode. Masked the pants once and the shirt twice. I then adjusted the bright/contrast slightly untill I was satisfied.
![]() I just re read the first post and saw that I was supposed to use curves... doh. I'm an idiot. |
#9 |
Moderator
Here's my attempt:
1. Create a duplicate layer of background. 2. Make a selection out of the performer - do not use feathering when selecting. - After making selection, "Select | Modify | Expand" 1 pixel. - "Select | Feather" 3 pixels. http://www.tanseikai.com/tanseikai/i...imgdisp-B1.jpg 3. Work on the main performer: - Create new Curves adjustment layer: ("Layer | New Adjustment layer | Curves..."). - Set points as indicated: http://www.tanseikai.com/tanseikai/i...imgdisp-B2.jpg - Use Gray eyedropper to remove bluish color cast. 4. Now work on the background. Switch the selection to the background: - "Select | Reselect" - "Select | Inverse" 5. Create another Curves adjustment layer and set points as indicated: http://www.tanseikai.com/tanseikai/i...imgdisp_B3.jpg 6. Select the Background copy layer from the Layers palette. 7. Sharpen as desired. I used USM: Amount= 100% Radius= 1 pxl Threshold= 3 8. Flatten layers and save. http://www.tanseikai.com/tanseikai/i.../imgdisp_B.jpg And, BTW, here's a better rendition (I think) using 2 steps: 1. Use levels to remove color cast. 2. User Shadow/Highlight to finish "fixing" the image. You can't make it any simpler than that! http://www.tanseikai.com/tanseikai/i.../imgdisp_C.jpg
..Leo |
#10 |
Here's my attempt:
![]() I stuck to the rules and just used Curves. No other adjustments. I used two Curves adjustment layers. Each used a layer mask created with my TLR Tone Mask Toolkit. http://www.thelightsright.com/Digita...askToolkit.htm I started with a narrow tone-based mask that focused on low key features. Then I added a wide tone-based mask that focused on the middle tones. I used the Magic Wand to extend the second mask a touch to include the darker skin tones. For more info on tone-based masks, here's a tutorial: http://www.thelightsright.com/Digita...TheNumbers.pdf Each of the Curves adjustments was to the center of the RGB master curve. Cheers, Mitch |
#11 |
Oh, I forgot to sharpen the iumage.
![]() I used my TLR Sharpening Toolkit for this: I used Capture Sharpening with Highpass Filter. My Capture Sharpening action used a luminosity edge mask to keep sharpening away from surfaces (and noise). I also used my Creative Blur action to blur the background slightly, which increases the appearance of sharpness for the subject. My Creative Blur action uses Hide All layer mask and then I painted the blur over the background features. Here's some free sharpening resources (tutorial, learning gallery, and PS action set: http://www.thelightsright.com/Digita...ningSkills.pdf http://www.thelightsright.com/Digita...ingToolkit.htm http://www.thelightsright.com/Digita...ingToolkit.htm Cheers, Mitch |
#12 |
A difficult image and an interesting range of approaches to improving it. It really was shot in sunny daylight but underexposed by 3 stops.
I will post later today or tomorrow one additional post processing result for this image. Since I have the original RAW file, I can cheat a bit. I will use a "hybrid conversion" technique described here: http://www.luminous-landscape.com/tu...nversion.shtml . It combines linear and standard RAW processing. I'll do this using only curves for tone and contrast adjustments. Perhaps I'll use the a sharpening method from the gmitchel toobox. I may post the result on a followup thread since this one is overloading my DSL connection. Cheers until later... |
#13 | |
The color information in the image is then developed through routine (i.e. non-linear) RAW processing, with emphasis on extracting color information (hue and saturation) and not worrying about brightness/contrast. This second image is converted to LAB mode which has one luminosity and two color channels. The luminosity channel image is replaced with the B+W grayscale image (via "Apply Image"), thus merging the tonality of first image conversion and the color of the second image. The final result still needed further editing and adjustments. The result was pretty good. |
#14 | |
It's hard to believe that the above image was derived from the original image posted. I'm hooked.
#15 |
Moderator
I just tried using the hybrid conversion method on a few of my backlit images that were on the underexposed site and man oh man, what a difference. The hybrid conversion method really does do wonders to "hopelessly" underexposed images.
Thanks, Woody, for bringing this to our attention. This is definitely something I'm going to be using a lot of, that's for sure.
..Leo |
| Thread Tools | |
| Display Modes | |
| post processing | canonusermk3 | General Photography Talk | 9 | 24th of July 2007 (Tue) 13:33 |
| Learning curve for RAW processing | Jim Cob | RAW, Post Processing and Printing | 15 | 19th of March 2007 (Mon) 05:06 |
| Post Processing | staciecd | Weddings and Other Family Events | 2 | 18th of October 2006 (Wed) 14:26 |
| Please Post Shots That Need Post Processing! | MattyB | RAW, Post Processing and Printing | 18 | 13th of July 2005 (Wed) 07:56 |
