#1 |
Heyya POTN,
My Hoya Pro1 Digital Polarizer came in today, havent got a chance to test it outside as it its pretty cloudy and nasty outside. I realized that AF doesnt seem to want to work on things that are textured the same (ie a single color, same material etc). I never really noticed this, but is this normal? Also, will AF be affected by the use of a polarizer? I know I lose about 2 stops of light, but should AF be slower? Thanks Eric |
| sponsored links |
#2 |
If it is not a Circular Polarizer (but a Linear Polarizer) it very likely is confusing your AF system. Also, cheaper filters can do the same as can those that are not MRC. I'm not familiar with that exact filter so if it is a cheapie, it might be the problem. If you take it off, does the AF work fine?
AF *can* be slower if it is very dark and you are not aimed at some good contrast to help the AF. J
Obsessive Gear List "It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain |
#3 |
http://www.bhphotovideo.com/c/produc...izing_Pro.html
thats the filter i got. even with the filter removed, when i focus on something with uniform color / texture, it doesnt seem to want to focus on it. |
| sponsored links |
#4 |
The camera requires contrast - light and dark areas - in order for auto-focus to function properly. Uniform colors and textures such as a blank white wall will be difficult or impossible for auto-focus to lock onto. This and other auto-focus issues are actually docuemented in the camera's manual.
The CPL filter knocks off two stops (giving your camera only 1/4 of the actual room light) meaning that it will have extra problems trying to auto-focus in indoor- or low-light situations. This is also normal. As far as the camera is concerned, you're essentially trying to autofocus in the dark. |
#5 |
Interesting....I've never heard this before. Does this mean we would be best-advised to use manual focus when a circular polarizer is attached?
Canon EOS 40D, Digital Rebel XT; Canon 24-70/f2.8 L USM; Canon EF 70-200/f4 L IS USM; Canon 50/f1.8; Sigma DC 30/f1.4; Sigma DC 10-20/f4-5.6; Canon 1.4x Extender; Canon Speedlite 430EX My Flickr Collection |
#6 | |
#7 |
YES, the loss of light will affect the AF.
#8 |
Not typically necessary. CPL filters are generally used in bright, sunny conditions where reflections are much more likely to be a problem or where darker, bluer skies are desired.
#9 |
CPL filters will allow the AF to work just fine. You need to have some contrast in order for the AF system to be able to figure out how to focus. The more light and the more contrast, the better it will work.
J
| Thread Tools | |
| Display Modes | |
| NEVEC- am I affected? | marieD | Small Flash and Studio Lighting | 12 | 4th of December 2009 (Fri) 22:14 |
| Some questions about XTI / 400D Autofocus | Helrain | Canon EOS Digital Cameras | 5 | 25th of July 2007 (Wed) 05:17 |
| Exposure affected by TC | SaSi | Canon EF and EF-S Lenses | 0 | 13th of May 2007 (Sun) 16:16 |
| Anyone know the serial number range for the flare-affected 24-105's? | NorCalAl | Canon EF and EF-S Lenses | 5 | 31st of January 2007 (Wed) 23:26 |
| Are CF cards affected by airport x-ray? | bobgarv | Canon EOS Digital Cameras | 14 | 29th of July 2005 (Fri) 07:59 |
