#1 |
Hi,
I own a powershot G3 and i was wondering why cannon have set a 3 min video recording limit. I never found a reasonable axplanation for that so if anyone knows why please let me know. Also G5 came out with the same 3min limitation!?!?!why? Im completely satisfied with the wide range of features i get from my G3 but the 3min limitation really annoys me!I've been in many situations where i want to record more than 3min... Is there any hacked firmware availiable out yet, that bypass that limitation? |
| sponsored links |
#2 |
Must be something wrong there because i have done movie clips bigger than 3 minutes. Are you sure that is not just the limit of your CF card's capacity?
http://warman.lusiarte.net/gallery LusiARTE - My gallery http://bawarman.deviantart.com/store - My storefront in DA http://www.shutterstock.com/gallery.mhtml?id=2230&rid=2230 - Check out My Gallery Here too |
#3 | |
I use a Crucial 256mb. As you can also see from reviews about G3 : [url]http://www.dpreview.com/reviews/canong3/page2.asp and G5 [url]http://www.dpreview.com/reviews/canong5/page2.asp the limitation is clearly stated : • 320 x 240, 15 fps, max 3 mins (including audio) • 160 x 120, 15 fps, max 3 mins (including audio) Im really curious on how you actually manage to record video longer than 3min |
| sponsored links |
#4 |
Yep, you are right, i just tested it and it only recorded 3 min.
The file i had was just below 3 mins but because it took so much time i was sure it was bigger. And to satisfy your curiosity, i cant! :P
#5 |
If I'm not mistaken, the maximum time you can record with video is determined by the buffer of the G2/G3, which seems to be around 4MB (that's about the size of a 30 sec high quality video).
So if the file is larger, it has to be saved to CF, and the camera obviously can't do both ... writing to CF and recording. Best regards, Andy |
#6 |
Canon G3, Kodak DC4800, Elements3 |
#7 |
Just a personal experience...
After having had my G2 for about a year, I also decided to get a state of the art Panasonic MiniDV (NV65) camera. Great 0.8 MP video camera with a great lens and IS, takes great videos. Do I use it a lot? Nope. Main reasons is the time needed to transfer: You can only download about 15 minutes of video, this takes half an hour to download to the PC and uses up some 5 GB on the hard disk. If you decide to convert it to MPEG in order to burn it to VCD or DVD, prepare for a night of rendering for a half-hour video. That means you have to spend a lot of time on the PC, until your video is downloaded and processed. Of course, you can spend some $500 - 1000 on a Pinnacle 500 or Canopus Storm video accelerator card that allows real-time rendering, but I couldn't get myself to spend that money on something that clearly isn't as much fun as taking digital pictures. But that's just my story... bottom line is ... I wanted it badly, but when I had it, I found out I don't really like it enough to use it. Best regards, Andy |
#8 |
#9 |
I use the video feature of my G3 fairly often - great with playful animals, dog agility runs, overall pans of a classic car show, an animated Christmas lighting display, etc. They're great to play back through the TV. Three minutes is about the maximum a viewer would want to watch these "home movies."
Downloading to the PC takes about one-third the recorded time with my Lexar CF card reader. I didn't consider this mode all that valuable when I selected the G3, but now find that it's one of the more satisfying and fun features. Now if I could just figure out how to convert the .avi files into something my DVD player could read from a CD. |
#10 | |
I also have a Mini DV camera with fire wire and the download is quite fast, and the quality is much better. I beleive its at 30fps...not sure about that one though. For every 10 minutes of video, it requires 2 gig of hard disk space |
#11 |
I have a Sony TRV 25 with Carl Zeiss lense and love it and use it. The G2 and the movie cam are two seperate beasts with completely differant goals. I would never bother with movie mode with my G2 because as with the two cams I have bought them for their individual talents. But to Andy the movie cam is like anything else, you have to cave the right software and you will find burning to DVD is a breeze, simpler than shooting raw image and photoshoping and printing. My 2 cents, sorry if a little off the canon forum topic base.
#12 |
I have an IBM 1GByte smartdrive, and even when empty, video only runs for 3 minutes on my G5.
#13 |
Canon Support said that a limit of 3 minutes has been set internally and cannot be changed, however large a capacity card you have
#14 |
im not sure how long the video fragment was, but i recorded a 30MB clip with my G5 once.
I think the max lenght of the clip is determined by the size of the flash card (obviously) but dont forget that the camera also needs working memory to compress the file. this working memory comes from the flash card also and thats why you'll never be able to record a 250mb clip on a 250mb flash card but you will be able to record 250mb *worth* of material. filming a white sheet of paper will also go on for longer than filming a really busy scene the quality is not that good, but its still a good function and fun to watch. most cameras come with cables to attach to a tv and you would be surprised of the quality ... its also fun to use some ulead software (or even windows movie maker) and paste all the clips together into a movie S |
#15 |
I contacted Canon support.
Incident Number 1070065 Thank you for your recent enquiry regarding your Canon product. Please be advised that the maximum movie length which can be shot on the Powershot G3 and G5 is three minutes. It is not possible to override this length, as it is based on the buffer size of the Camera which is unable to be upgraded. We hope this information is of use to you. However, should you require any further technical assistance, please do not hesitate to contact us quoting your Incident number. To contact us via email, click on the following link: https://self-service.canon-europe.co...ss.cgi?LANG=en. Note: Please do not reply to this email using your "REPLY" tab. Kind Regards, Canon UK |
| Thread Tools | |
| Display Modes | |
| Canon S3 IS - problem transfering large video files and zoom noise recording video | little.blur | Canon G-series Digital Cameras | 1 | 27th of June 2007 (Wed) 19:59 |
| Anyone here into video recording? | fomoz | The POTN Lounge | 17 | 24th of May 2006 (Wed) 07:30 |
| Lens limitation, or camera? | RinkRat | Canon EF and EF-S Lenses | 12 | 1st of March 2005 (Tue) 09:28 |
| G3 Limitation | WW50 | Canon G-series Digital Cameras | 24 | 22nd of April 2004 (Thu) 02:00 |
| s50 as a camera / or recording video to pc | Liquidx | RAW, Post Processing and Printing | 1 | 29th of September 2003 (Mon) 20:13 |
